[petsc-users] hypre support
Dario Isola dario.isola at newmerical.com
Fri May 16 11:49:40 CDT 2014
Thanks a lot for your answers.
I ran it with
    -ksp_type gmres -pc_type hypre -pc_hypre_type euclid
and it worked very well. Thanks.
I then tried to use boomeramg as a preconditioner coupled with
Richardson but I was not successful, it failed to solve the system and
returned nans.
    -ksp_type richardson -pc_type hypre -pc_hypre_type boomeramg
    -pc_hypre_boomeramg_relax_type_all SOR/Jacobi
    -pc_hypre_boomeramg_print_debug -ksp_view -ksp_monitor_true_residual
and i got the following
      ===== Proc = 0     Level = 0  =====
    Proc = 0    Coarsen 1st pass = 0.000000
    Proc = 0    Coarsen 2nd pass = 0.000000
    Proc = 0    Initialize CLJP phase = 0.000000
    Proc = 0  iter 1  comm. and subgraph update = 0.000000
    Proc = 0    CLJP phase = 0.000000 graph_size = 18308 nc_offd = 0
    Proc = 0  iter 2  comm. and subgraph update = 0.000000
    Proc = 0    CLJP phase = 0.000000 graph_size = 7 nc_offd = 0
      ===== Proc = 0     Level = 1  =====
    Proc = 0    Coarsen 1st pass = 0.010000
    Proc = 0    CLJP phase = 0.000000 graph_size = 8725 nc_offd = 0
    Proc = 0    CLJP phase = 0.000000 graph_size = 16 nc_offd = 0
      ===== Proc = 0     Level = 2  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 4721 nc_offd = 0
    Proc = 0    CLJP phase = 0.000000 graph_size = 13 nc_offd = 0
    Proc = 0  iter 3  comm. and subgraph update = 0.000000
    Proc = 0    CLJP phase = 0.000000 graph_size = 4 nc_offd = 0
      ===== Proc = 0     Level = 3  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 2495 nc_offd = 0
    Proc = 0    CLJP phase = 0.000000 graph_size = 22 nc_offd = 0
      ===== Proc = 0     Level = 4  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 1337 nc_offd = 0
    Proc = 0    CLJP phase = 0.000000 graph_size = 2 nc_offd = 0
      ===== Proc = 0     Level = 5  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 695 nc_offd = 0
    Proc = 0    CLJP phase = 0.000000 graph_size = 3 nc_offd = 0
      ===== Proc = 0     Level = 6  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 343 nc_offd = 0
    Proc = 0    CLJP phase = 0.000000 graph_size = 21 nc_offd = 0
      ===== Proc = 0     Level = 7  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 174 nc_offd = 0
    Proc = 0    CLJP phase = 0.000000 graph_size = 15 nc_offd = 0
      ===== Proc = 0     Level = 8  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 81 nc_offd = 0
      ===== Proc = 0     Level = 9  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 37 nc_offd = 0
    Proc = 0    CLJP phase = 0.000000 graph_size = 6 nc_offd = 0
      ===== Proc = 0     Level = 10  =====
    Proc = 0    CLJP phase = 0.000000 graph_size = 11 nc_offd = 0
       0 KSP preconditioned resid norm 7.299769365830e+14 true resid
    norm 8.197927963033e-03 ||r(i)||/||b|| 1.000000000000e+00
       1 KSP preconditioned resid norm 2.319459389445e+28 true resid
    norm 6.152576199945e+12 ||r(i)||/||b|| 7.505038136086e+14
    KSP Object: 1 MPI processes
       type: richardson
         Richardson: damping factor=1
       maximum iterations=90, initial guess is zero
       tolerances:  relative=0.1, absolute=1e-50, divergence=100000
       left preconditioning
       using PRECONDITIONED norm type for convergence test
    PC Object: 1 MPI processes
       type: hypre
         HYPRE BoomerAMG preconditioning
         HYPRE BoomerAMG: Cycle type V
         HYPRE BoomerAMG: Maximum number of levels 25
         HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
         HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
         HYPRE BoomerAMG: Threshold for strong coupling 0.25
         HYPRE BoomerAMG: Interpolation truncation factor 0
         HYPRE BoomerAMG: Interpolation: max elements per row 0
         HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
         HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
         HYPRE BoomerAMG: Maximum row sums 0.9
         HYPRE BoomerAMG: Sweeps down         1
         HYPRE BoomerAMG: Sweeps up           1
         HYPRE BoomerAMG: Sweeps on coarse    1
         HYPRE BoomerAMG: Relax down          SOR/Jacobi
         HYPRE BoomerAMG: Relax up            SOR/Jacobi
         HYPRE BoomerAMG: Relax on coarse Gaussian-elimination
         HYPRE BoomerAMG: Relax weight  (all)      1
         HYPRE BoomerAMG: Outer relax weight (all) 1
         HYPRE BoomerAMG: Using CF-relaxation
         HYPRE BoomerAMG: Measure type        local
         HYPRE BoomerAMG: Coarsen type        Falgout
         HYPRE BoomerAMG: Interpolation type  classical
       linear system matrix = precond matrix:
       Matrix Object:   1 MPI processes
         type: seqbaij
         rows=22905, cols=22905, bs=5
         total: nonzeros=785525, allocated nonzeros=785525
         total number of mallocs used during MatSetValues calls =0
             block size is 5
Do you guys have any suggestion?  Is it possible that I am haven't
initialized boomeramg properly? Or it is just my system equations that
can not be solved by AMG?
Sincerely,
Dario
On 05/16/2014 11:54 AM, Barry Smith wrote:
> On May 16, 2014, at 10:46 AM, Dario Isola <dario.isola at newmerical.com> wrote:
>> Dear all,
>> I am investigating the use of hypre+petsc. I was able to successfully configure, install, compile petsc 3.3 with the external package for hypre.
>> I tried to run it with the following options
>> -pc_type hypre -pc_type_hypre pilut -ksp_type richardson
>> and, although he did not complain, it does not solve the system either.
>     Do you meaning it did not converge? At first always run with -ksp_view (or -snes_view if using snes or -ts_view if using ts) and -ksp_monitor_true_residual to see what is going on.
> is wrong it is -pc_hypre_type pilut
> Note that pilut will generally not work with Richardson you need a “real” Krylov method like GMRES.
> Also the ilu type preconditioners don’t scale particularly well though occasionally they can be fine.
>> To what extent is hypre supported by petsc? More specifically, what kind of matrices?
>     If it cannot handle the matrix type it would give an error message.  Hypre uses a format like AIJ so you should use AIJ. Note that you can make the matrix type a runtime option so you don’t have to compile in that it is BAIJ.
>> I am using a baij matrix.
>> Thanks in advance,
>> D
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140516/1925e267/attachment.html>
