[petsc-users] hypre support
Dario Isola dario.isola at newmerical.com
Fri May 16 13:55:29 CDT 2014
I was eventually able to make it run adopting a very small time-step
(Courant number of about 1).
So either my problem is not well solved by AMG, as you said, or I am not
using it very well.
But I guess I should be able to take it from there.
Thanks again for the support!
Dario
On 05/16/2014 01:56 PM, Barry Smith wrote:
>     Algebraic multigrid is not for everything.
> On May 16, 2014, at 11:49 AM, Dario Isola <dario.isola at newmerical.com> wrote:
>> Thanks a lot for your answers.
>> I ran it with
>> -ksp_type gmres -pc_type hypre -pc_hypre_type euclid
>> and it worked very well. Thanks.
>> I then tried to use boomeramg as a preconditioner coupled with Richardson but I was not successful, it failed to solve the system and returned nans.
>> -ksp_type richardson -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_relax_type_all SOR/Jacobi -pc_hypre_boomeramg_print_debug -ksp_view -ksp_monitor_true_residual
>> and i got the following
>>   ===== Proc = 0     Level = 0  =====
>> Proc = 0    Coarsen 1st pass = 0.000000
>> Proc = 0    Coarsen 2nd pass = 0.000000
>> Proc = 0    Initialize CLJP phase = 0.000000
>> Proc = 0  iter 1  comm. and subgraph update = 0.000000
>> Proc = 0    CLJP phase = 0.000000 graph_size = 18308 nc_offd = 0
>> Proc = 0  iter 2  comm. and subgraph update = 0.000000
>> Proc = 0    CLJP phase = 0.000000 graph_size = 7 nc_offd = 0
>>   ===== Proc = 0     Level = 1  =====
>> Proc = 0    Coarsen 1st pass = 0.010000
>> Proc = 0    CLJP phase = 0.000000 graph_size = 8725 nc_offd = 0
>> Proc = 0    CLJP phase = 0.000000 graph_size = 16 nc_offd = 0
>>   ===== Proc = 0     Level = 2  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 4721 nc_offd = 0
>> Proc = 0    CLJP phase = 0.000000 graph_size = 13 nc_offd = 0
>> Proc = 0  iter 3  comm. and subgraph update = 0.000000
>> Proc = 0    CLJP phase = 0.000000 graph_size = 4 nc_offd = 0
>>   ===== Proc = 0     Level = 3  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 2495 nc_offd = 0
>> Proc = 0    CLJP phase = 0.000000 graph_size = 22 nc_offd = 0
>>   ===== Proc = 0     Level = 4  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 1337 nc_offd = 0
>> Proc = 0    CLJP phase = 0.000000 graph_size = 2 nc_offd = 0
>>   ===== Proc = 0     Level = 5  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 695 nc_offd = 0
>> Proc = 0    CLJP phase = 0.000000 graph_size = 3 nc_offd = 0
>>   ===== Proc = 0     Level = 6  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 343 nc_offd = 0
>> Proc = 0    CLJP phase = 0.000000 graph_size = 21 nc_offd = 0
>>   ===== Proc = 0     Level = 7  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 174 nc_offd = 0
>> Proc = 0    CLJP phase = 0.000000 graph_size = 15 nc_offd = 0
>>   ===== Proc = 0     Level = 8  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 81 nc_offd = 0
>>   ===== Proc = 0     Level = 9  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 37 nc_offd = 0
>> Proc = 0    CLJP phase = 0.000000 graph_size = 6 nc_offd = 0
>>   ===== Proc = 0     Level = 10  =====
>> Proc = 0    CLJP phase = 0.000000 graph_size = 11 nc_offd = 0
>>    0 KSP preconditioned resid norm 7.299769365830e+14 true resid norm 8.197927963033e-03 ||r(i)||/||b|| 1.000000000000e+00
>>    1 KSP preconditioned resid norm 2.319459389445e+28 true resid norm 6.152576199945e+12 ||r(i)||/||b|| 7.505038136086e+14
>> KSP Object: 1 MPI processes
>>    type: richardson
>>      Richardson: damping factor=1
>>    maximum iterations=90, initial guess is zero
>>    tolerances:  relative=0.1, absolute=1e-50, divergence=100000
>>    left preconditioning
>>    using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>>    type: hypre
>>      HYPRE BoomerAMG preconditioning
>>      HYPRE BoomerAMG: Cycle type V
>>      HYPRE BoomerAMG: Maximum number of levels 25
>>      HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>>      HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
>>      HYPRE BoomerAMG: Threshold for strong coupling 0.25
>>      HYPRE BoomerAMG: Interpolation truncation factor 0
>>      HYPRE BoomerAMG: Interpolation: max elements per row 0
>>      HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>>      HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>>      HYPRE BoomerAMG: Maximum row sums 0.9
>>      HYPRE BoomerAMG: Sweeps down         1
>>      HYPRE BoomerAMG: Sweeps up           1
>>      HYPRE BoomerAMG: Sweeps on coarse    1
>>      HYPRE BoomerAMG: Relax down          SOR/Jacobi
>>      HYPRE BoomerAMG: Relax up            SOR/Jacobi
>>      HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>>      HYPRE BoomerAMG: Relax weight  (all)      1
>>      HYPRE BoomerAMG: Outer relax weight (all) 1
>>      HYPRE BoomerAMG: Using CF-relaxation
>>      HYPRE BoomerAMG: Measure type        local
>>      HYPRE BoomerAMG: Coarsen type        Falgout
>>      HYPRE BoomerAMG: Interpolation type  classical
>>    linear system matrix = precond matrix:
>>    Matrix Object:   1 MPI processes
>>      type: seqbaij
>>      rows=22905, cols=22905, bs=5
>>      total: nonzeros=785525, allocated nonzeros=785525
>>      total number of mallocs used during MatSetValues calls =0
>>          block size is 5
>> Do you guys have any suggestion?  Is it possible that I am haven't initialized boomeramg properly? Or it is just my system equations that can not be solved by AMG?
>> Sincerely,
>> Dario
>> On 05/16/2014 11:54 AM, Barry Smith wrote:
>>> On May 16, 2014, at 10:46 AM, Dario Isola <dario.isola at newmerical.com>
>>>   wrote:
>>>> Dear all,
>>>> I am investigating the use of hypre+petsc. I was able to successfully configure, install, compile petsc 3.3 with the external package for hypre.
>>>> I tried to run it with the following options
>>>> -pc_type hypre -pc_type_hypre pilut -ksp_type richardson
>>>> and, although he did not complain, it does not solve the system either.
>>>     Do you meaning it did not converge? At first always run with -ksp_view (or -snes_view if using snes or -ts_view if using ts) and -ksp_monitor_true_residual to see what is going on.
>>> is wrong it is -pc_hypre_type pilut
>>> Note that pilut will generally not work with Richardson you need a “real” Krylov method like GMRES.
>>> Also the ilu type preconditioners don’t scale particularly well though occasionally they can be fine.
>>>> To what extent is hypre supported by petsc? More specifically, what kind of matrices?
>>>     If it cannot handle the matrix type it would give an error message.  Hypre uses a format like AIJ so you should use AIJ. Note that you can make the matrix type a runtime option so you don’t have to compile in that it is BAIJ.
>>>> I am using a baij matrix.
>>>> Thanks in advance,
>>>> D
