[petsc-users] petsc 3.4, mat_view and prefix problem
Klaij, Christiaan C.Klaij at marin.nl
Wed May 14 04:02:39 CDT 2014
I'm having problems using mat_view in petsc 3.4.3 in combination
with a prefix. For example in ../snes/examples/tutorials/ex70:
        mpiexec -n 2 ./ex70 -nx 16 -ny 24 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -user_ksp -a00_mat_view
does not print the matrix a00 to screen. This used to work in 3.3
versions before the single consistent -xxx_view scheme.
Similarly, if I add this at line 105 of
../ksp/ksp/examples/tutorials/ex1f.F:
      call MatSetOptionsPrefix(A,"a_",ierr)
then running with -mat_view still prints the matrix to screen but
running with -a_mat_view doesn't. I expected the opposite.
The problem only occurs with mat, not with ksp. For example, if I
add this at line 184 of ../ksp/ksp/examples/tutorials/ex1f.F:
      call KSPSetOptionsPrefix(ksp,"a_",ierr)
then running with -a_ksp_monitor does print the residuals to
screen and -ksp_monitor doesn't, as expected.
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
