[petsc-users] petsc 3.4, mat_view and prefix problem
Wed May 14 13:03:04 CDT 2014
   Yes, some of this handling of prefixes and viewing is wonky in 3.4  it is all fixed and coherent in master of the development version and will be correct in the next release.
    Barry
On May 14, 2014, at 4:02 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> I'm having problems using mat_view in petsc 3.4.3 in combination
> with a prefix. For example in ../snes/examples/tutorials/ex70:
>        mpiexec -n 2 ./ex70 -nx 16 -ny 24 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -user_ksp -a00_mat_view
> does not print the matrix a00 to screen. This used to work in 3.3
> versions before the single consistent -xxx_view scheme.
> Similarly, if I add this at line 105 of
> ../ksp/ksp/examples/tutorials/ex1f.F:
>      call MatSetOptionsPrefix(A,"a_",ierr)
> then running with -mat_view still prints the matrix to screen but
> running with -a_mat_view doesn't. I expected the opposite.
> The problem only occurs with mat, not with ksp. For example, if I
> add this at line 184 of ../ksp/ksp/examples/tutorials/ex1f.F:
>      call KSPSetOptionsPrefix(ksp,"a_",ierr)
> then running with -a_ksp_monitor does print the residuals to
> screen and -ksp_monitor doesn't, as expected.
> dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> E mailto:C.Klaij at marin.nl
> T +31 317 49 33 44
> MARIN
> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
