[petsc-users] configuration on cluster with intel compilers/mkl
Tue May 13 20:14:16 CDT 2014
  Your MPI compiler is using 32 bit pointers (why?)
TEST configureCompilerFlags from config.compilerFlags(/home/simpson/software/petsc-intel/config/BuildSystem/config/compilerFlags.py:65)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:65)
  Get the default compiler flags
          Pushing language C
sh: /cm/shared/apps/intel/mpi/4.1.1.036/bin/mpicc --version
Executing: /cm/shared/apps/intel/mpi/4.1.1.036/bin/mpicc --version
sh: gcc (GCC) 4.8.1
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
getCompilerVersion: /cm/shared/apps/intel/mpi/4.1.1.036/bin/mpicc gcc (GCC) 4.8.1
sh: /cm/shared/apps/intel/mpi/4.1.1.036/bin/mpicc -show
Executing: /cm/shared/apps/intel/mpi/4.1.1.036/bin/mpicc -show
sh: gcc -m32 -I/cm/shared/apps/intel/mpi/4.1.1.036/ia32/include -L/cm/shared/apps/intel/mpi/4.1.1.036/ia32/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /cm/shared/apps/intel/mpi/4.1.1.036/ia32/lib -Xlinker -rpath -Xlinker /opt/intel/mpi-rt/4.1 -lmpigf -lmpi -lmpigi -ldl -lrt -lpthread
  But you ask to use 64 bit pointer MKL libraries with /cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_intel_lp64.a
Cannot be done. Either use a 64 bit pointer mpicc or a 32 bit pointer mkl library.
   Barry
On May 13, 2014, at 7:59 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
> Log attached,
> -gideon
> On May 13, 2014, at 8:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   You always need to send configure.log so we can see why the library was unacceptable.
>> On May 13, 2014, at 7:16 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>> I’m trying to set up petsc on an intel cluster that has the intel compilers and the MKL, but when I try to configure, I get the error,
>>> TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:113) *******************************************************************************
>>>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
>>> You set a value for --with-blas-lapack-lib=<lib>, but ['/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_intel_lp64.a', '/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_sequential.a', '/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_core.a'] cannot be used
>>> -gideon
> <configure.log>
