[petsc-users] configuration on cluster with intel compilers/mkl
Gideon Simpson gideon.simpson at gmail.com
Tue May 13 19:59:42 CDT 2014
Log attached,
-gideon
On May 13, 2014, at 8:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   You always need to send configure.log so we can see why the library was unacceptable.
> On May 13, 2014, at 7:16 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>> I’m trying to set up petsc on an intel cluster that has the intel compilers and the MKL, but when I try to configure, I get the error,
>> TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:113) *******************************************************************************
>>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
>> You set a value for --with-blas-lapack-lib=<lib>, but ['/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_intel_lp64.a', '/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_sequential.a', '/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_core.a'] cannot be used
>> -gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140513/564e1b72/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140513/564e1b72/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140513/564e1b72/attachment-0003.html>
