[petsc-users] configuration on cluster with intel compilers/mkl
Tue May 13 19:56:27 CDT 2014
   You always need to send configure.log so we can see why the library was unacceptable.
On May 13, 2014, at 7:16 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
> I’m trying to set up petsc on an intel cluster that has the intel compilers and the MKL, but when I try to configure, I get the error,
> TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:113) *******************************************************************************
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> You set a value for --with-blas-lapack-lib=<lib>, but ['/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_intel_lp64.a', '/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_sequential.a', '/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_core.a'] cannot be used
> -gideon
