[petsc-users] configuration on cluster with intel compilers/mkl
Gideon Simpson gideon.simpson at gmail.com
Tue May 13 19:16:08 CDT 2014
I’m trying to set up petsc on an intel cluster that has the intel compilers and the MKL, but when I try to configure, I get the error,
TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:113)                                                          *******************************************************************************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
You set a value for --with-blas-lapack-lib=<lib>, but ['/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_intel_lp64.a', '/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_sequential.a', '/cm/shared/apps/intel/composer_xe/2013_sp1.1.106/mkl/lib/intel64/libmkl_core.a'] cannot be used
-gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140513/37122015/attachment.html>
