[petsc-users] PLEX depth stratum bug ?
Dharmendar Reddy dharmareddy84 at gmail.com
Mon Jan 27 14:34:28 CST 2014
On Mon, Jan 27, 2014 at 2:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jan 27, 2014 at 1:58 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
> wrote:
>> On Mon, Jan 27, 2014 at 11:18 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Thu, Jan 23, 2014 at 11:05 PM, Dharmendar Reddy
>> > wrote:
>> >> Hello,
>> >>          I am seeing inconsistent results using get stratum call.  For
>> >> a
>> >> 2d mesh
>> > Sorry, I was swamped last week. You had not interpolated your mesh. I
>> > have
>> > included modified source:
>> Agreed, But if the mesh is not interpolated, depth = topological
>> dimension  (dim) should refer to dim-cells, is not that true ?
> No, depth is depth in the DAG, not topological dimension.
Ok, I had a misunderstanding then. So, to be safe,  I should use depth
0 to access nodes and height 0 to access dim-cells.
>    Matt
>> > Successfully created DM From Cell List
>> >  Successfully interpolated mesh
>> > DM_0x84000000_0 in 2 dimensions:
>> >   0-cells: 9
>> >   1-cells: 12
>> >   2-cells: 4
>> > Labels:
>> >   depth: 3 strata of sizes (9, 12, 4)
>> >  stratum size for value           1 is          12
>> > Number of indices in set 12
>> > 0 13
>> > 1 14
>> > 2 15
>> > 3 16
>> > 4 17
>> > 5 18
>> > 6 19
>> > 7 20
>> > 8 21
>> > 9 22
>> > 10 23
>> > 11 24
>> >  Node id start=           4 node id end=          12
>> >  edge id start=          13 edge id end=          24
>> >  element id start=           0 element id end=           3
>> >  printing the cell ids based on height stratum
>> >    Matt
>> >> call DMPlexGetDepthStratum(dmMesh,2,globalidStart,globalidEnd,ierr)
>> >> prints: globalIdStart = 0 and globalIdEnd = 0
>> >> where as
>> >> call DMPlexGetHeightStratum(dmMesh,0,globalidStart,globalidEnd,ierr)
>> >> prints globalIdStart = 0 and globalIdEnd = 4
>> >> For a mesh with 4 cells. I have attached the test case. I am on petsc
>> >> version v3.4.3-2568-gb45093d
>> > What most experimenters take for granted before they begin their
>> > experiments
>> > is infinitely more interesting than any results to which their
>> > experiments
>> > lead.
>> > -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
