[petsc-users] PLEX depth stratum bug ?
Mon Jan 27 14:11:41 CST 2014
On Mon, Jan 27, 2014 at 1:58 PM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> On Mon, Jan 27, 2014 at 11:18 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Thu, Jan 23, 2014 at 11:05 PM, Dharmendar Reddy <
> > wrote:
> >> Hello,
> >>          I am seeing inconsistent results using get stratum call.  For a
> >> 2d mesh
> > Sorry, I was swamped last week. You had not interpolated your mesh. I
> have
> > included modified source:
> Agreed, But if the mesh is not interpolated, depth = topological
> dimension  (dim) should refer to dim-cells, is not that true ?
No, depth is depth in the DAG, not topological dimension.
   Matt
> > Successfully created DM From Cell List
> >  Successfully interpolated mesh
> > DM_0x84000000_0 in 2 dimensions:
> >   0-cells: 9
> >   1-cells: 12
> >   2-cells: 4
> > Labels:
> >   depth: 3 strata of sizes (9, 12, 4)
> >  stratum size for value           1 is          12
> > Number of indices in set 12
> > 0 13
> > 1 14
> > 2 15
> > 3 16
> > 4 17
> > 5 18
> > 6 19
> > 7 20
> > 8 21
> > 9 22
> > 10 23
> > 11 24
> >  Node id start=           4 node id end=          12
> >  edge id start=          13 edge id end=          24
> >  element id start=           0 element id end=           3
> >  printing the cell ids based on height stratum
> >    Matt
> >> call DMPlexGetDepthStratum(dmMesh,2,globalidStart,globalidEnd,ierr)
> >> prints: globalIdStart = 0 and globalIdEnd = 0
> >> where as
> >> call DMPlexGetHeightStratum(dmMesh,0,globalidStart,globalidEnd,ierr)
> >> prints globalIdStart = 0 and globalIdEnd = 4
> >> For a mesh with 4 cells. I have attached the test case. I am on petsc
> >> version v3.4.3-2568-gb45093d
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140127/43634d2f/attachment.html>
