[petsc-users] Setting up a PETSc section for field-split
Luc Berger-Vergiat lb2653 at columbia.edu
Mon Jan 27 13:35:10 CST 2014
Thanks Matt,
this indeed setting the number of fields earlier solve my issue!
I have now made some progress getting my DM setup but I am having
troubles setting my splitfield options.
I ran my problem with the -ksp_view option to see what is going on and I
guess that somehow the section that I define in my DM is not used by the
preconditioner to split the fields.
Here is the output of PETSc
KSP Object: 1 MPI processes
   type: gmres
     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
     GMRES: happy breakdown tolerance 1e-30
   maximum iterations=10000, initial guess is zero
   tolerances:  relative=1e-08, absolute=1e-16, divergence=1e+16
   left preconditioning
   using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
   type: fieldsplit
     FieldSplit with MULTIPLICATIVE composition: total splits = 4
     Solver info for each split is in the following KSP objects:
     Split number 0 Defined by IS
     KSP Object:    (fieldsplit_Field_0_)     1 MPI processes
       type: preonly
       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
       using NONE norm type for convergence test
     PC Object:    (fieldsplit_Field_0_)     1 MPI processes
       type: ilu
         ILU: out-of-place factorization
         0 levels of fill
         tolerance for zero pivot 2.22045e-14
         using diagonal shift on blocks to prevent zero pivot
         matrix ordering: natural
         factor fill ratio given 1, needed 1
           Factored matrix follows:
             Matrix Object:             1 MPI processes
               type: seqaij
               rows=0, cols=0
               package used to perform factorization: petsc
               total: nonzeros=0, allocated nonzeros=0
               total number of mallocs used during MatSetValues calls =0
                 not using I-node routines
       linear system matrix = precond matrix:
         type: seqaij
         rows=0, cols=0
     Split number 1 Defined by IS
     KSP Object:    (fieldsplit_Field_1_)     1 MPI processes
       type: preonly
     PC Object:    (fieldsplit_Field_1_)     1 MPI processes
       type: ilu
         0 levels of fill
               type: seqaij
               rows=0, cols=0
         type: seqaij
         rows=0, cols=0
     Split number 2 Defined by IS
     KSP Object:    (fieldsplit_Field_2_)     1 MPI processes
       type: preonly
     PC Object:    (fieldsplit_Field_2_)     1 MPI processes
       type: ilu
         0 levels of fill
               type: seqaij
               rows=0, cols=0
         type: seqaij
         rows=0, cols=0
     Split number 3 Defined by IS
     KSP Object:    (fieldsplit_Field_3_)     1 MPI processes
       type: preonly
     PC Object:    (fieldsplit_Field_3_)     1 MPI processes
       type: ilu
         0 levels of fill
               type: seqaij
               rows=0, cols=0
         type: seqaij
         rows=0, cols=0
     type: seqaij
     rows=16, cols=16
     total: nonzeros=256, allocated nonzeros=256
       using I-node routines: found 4 nodes, limit used is 5
I am also attaching part of my code which I use to generate the DM, the
KSP and the PC objects.
Best,
Luc
On 01/25/2014 10:31 AM, Matthew Knepley wrote:
> On Fri, Jan 24, 2014 at 5:10 PM, Luc Berger-Vergiat
> <lb2653 at columbia.edu <mailto:lb2653 at columbia.edu>> wrote:
>     Hi all,
>     I want to use PETSc as a solver for an FEM problem: modelization
>     of shear bands using a 4 fields mixed formulation.
>     So far I am just trying to set up a two fields in a Petsc section,
>     assign dof too each field and then set up the section to pass it
>     to a DM. I am taking this approach because in general I want for
>     fieldsplit to work purely on the algebraic level without knowledge
>     of boundary conditions or geometry.
>     As of now I have issues when I try to assign a point and its
>     associated degree of freedom to a field using:
>     PetscSectionSetFieldDof.
>     Is this the correct way to associate a dof/point to a field?
> You have to set the number of fields before the chart. I am updating
> the docs.
>  Thanks,
>     Matt
>     I attached an example code and its makefile.
>     Best,
>     Luc
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140127/071a863a/attachment-0001.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140127/071a863a/attachment-0001.bin>
