[petsc-users] Setting up a PETSc section for field-split
Tue Jan 28 09:25:14 CST 2014
On Mon, Jan 27, 2014 at 1:35 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>wrote:
>  Thanks Matt,
> this indeed setting the number of fields earlier solve my issue!
> I have now made some progress getting my DM setup but I am having troubles
> setting my splitfield options.
> I ran my problem with the -ksp_view option to see what is going on and I
> guess that somehow the section that I define in my DM is not used by the
> preconditioner to split the fields.
> Here is the output of PETSc
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-08, absolute=1e-16, divergence=1e+16
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with MULTIPLICATIVE composition: total splits = 4
>     Solver info for each split is in the following KSP objects:
>     Split number 0 Defined by IS
There are 4 splits here and they are defined by an IS. Why do you think
that is not what you asked for?
    Matt
>     KSP Object:    (fieldsplit_Field_0_)     1 MPI processes
>       type: preonly
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>       using NONE norm type for convergence test
>     PC Object:    (fieldsplit_Field_0_)     1 MPI processes
>       type: ilu
>         ILU: out-of-place factorization
>         0 levels of fill
>         tolerance for zero pivot 2.22045e-14
>         using diagonal shift on blocks to prevent zero pivot
>         matrix ordering: natural
>         factor fill ratio given 1, needed 1
>           Factored matrix follows:
>             Matrix Object:             1 MPI processes
>               type: seqaij
>               rows=0, cols=0
>               package used to perform factorization: petsc
>               total: nonzeros=0, allocated nonzeros=0
>               total number of mallocs used during MatSetValues calls =0
>                 not using I-node routines
>       linear system matrix = precond matrix:
>         type: seqaij
>         rows=0, cols=0
>     Split number 1 Defined by IS
>     KSP Object:    (fieldsplit_Field_1_)     1 MPI processes
>       type: preonly
>     PC Object:    (fieldsplit_Field_1_)     1 MPI processes
>       type: ilu
>         0 levels of fill
>               type: seqaij
>               rows=0, cols=0
>         type: seqaij
>         rows=0, cols=0
>     Split number 2 Defined by IS
>     KSP Object:    (fieldsplit_Field_2_)     1 MPI processes
>       type: preonly
>     PC Object:    (fieldsplit_Field_2_)     1 MPI processes
>       type: ilu
>         0 levels of fill
>               type: seqaij
>               rows=0, cols=0
>         type: seqaij
>         rows=0, cols=0
>     Split number 3 Defined by IS
>     KSP Object:    (fieldsplit_Field_3_)     1 MPI processes
>       type: preonly
>     PC Object:    (fieldsplit_Field_3_)     1 MPI processes
>       type: ilu
>         0 levels of fill
>               type: seqaij
>               rows=0, cols=0
>         type: seqaij
>         rows=0, cols=0
>     type: seqaij
>     rows=16, cols=16
>     total: nonzeros=256, allocated nonzeros=256
>       using I-node routines: found 4 nodes, limit used is 5
> I am also attaching part of my code which I use to generate the DM, the
> KSP and the PC objects.
> Best,
> Luc
> On 01/25/2014 10:31 AM, Matthew Knepley wrote:
>  On Fri, Jan 24, 2014 at 5:10 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>wrote:
>> Hi all,
>> I want to use PETSc as a solver for an FEM problem: modelization of shear
>> bands using a 4 fields mixed formulation.
>> So far I am just trying to set up a two fields in a Petsc section, assign
>> dof too each field and then set up the section to pass it to a DM. I am
>> taking this approach because in general I want for fieldsplit to work
>> purely on the algebraic level without knowledge of boundary conditions or
>> geometry.
>> As of now I have issues when I try to assign a point and its associated
>> degree of freedom to a field using: PetscSectionSetFieldDof.
>> Is this the correct way to associate a dof/point to a field?
>  You have to set the number of fields before the chart. I am updating the
> docs.
>   Thanks,
>      Matt
>> I attached an example code and its makefile.
>> Best,
>> Luc
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140128/f446fc20/attachment.html>
