[petsc-users] Command line option to set number iterations for Chebyshev eigenvalue estimation?
Thu Jan 23 08:32:07 CST 2014
On Thu, Jan 23, 2014 at 5:35 AM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> Is there are command line option to set the number of iterations used for
> the eigenvalue estimation inside the Chebyshev preconditioner?
>  "-gamg_est_ksp_max_it" does the trick with GAMG, but I'd also like to
> change the number of iterations when using Chebyshev smoothing with ML.
In GAMG, we use PETSc itself to do the estimate, and give it the prefix
gamg_est_. In ML, as far as I can see from the code, we use the internal
estimator, and I don't think they give us this knob.
   Matt
> Garth
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140123/aa6c0f11/attachment.html>
