[petsc-users] Command line option to set number iterations for Chebyshev eigenvalue estimation?
Garth N. Wells gnw20 at cam.ac.uk
Thu Jan 23 05:35:02 CST 2014
Is there are command line option to set the number of iterations used
for the eigenvalue estimation inside the Chebyshev preconditioner?
"-gamg_est_ksp_max_it" does the trick with GAMG, but I'd also like to
change the number of iterations when using Chebyshev smoothing with ML.
Garth
