[petsc-users] Command line option to set number iterations for Chebyshev eigenvalue estimation?
Garth N. Wells gnw20 at cam.ac.uk
Thu Jan 23 08:49:46 CST 2014
On 2014-01-23 14:32, Matthew Knepley wrote:
> On Thu, Jan 23, 2014 at 5:35 AM, Garth N. Wells <gnw20 at cam.ac.uk>
> wrote:
>> Is there are command line option to set the number of iterations
>> used for the eigenvalue estimation inside the Chebyshev
>> preconditioner?  "-gamg_est_ksp_max_it" does the trick with GAMG,
>> but I'd also like to change the number of iterations when using
>> Chebyshev smoothing with ML.
> In GAMG, we use PETSc itself to do the estimate, and give it the
> prefix gamg_est_. In ML, as far as I can see from the code, we use the
> internal
> estimator, and I don't think they give us this knob.
I'm not so interested in the what happens inside ML, but the Chebyshev
smoother that PETSc applies. With the default 10 GMRES iterations, the
eigenvalue estimate is not good enough for my problem, which leads to
the outer CG breaking down with an indefinite operator error.
I can get it working by changing
   -mg_levels_ksp_chebyshev_estimate_eigenvalues
but I'd rather do a few more iterations to get a better eigenvalue
estimate. It would also be nice to be able to switch from GMRES to CG. I
can do this with GAMG via "-gamg_est_ksp_type"
Garth
>    Matt
>> Garth
> experiments is infinitely more interesting than any results to which
> their experiments lead.
>  -- Norbert Wiener
