[petsc-users] tons of valgrind errors with simply PetscInitialize and PetscFinalize?
Wed Jan 22 17:39:15 CST 2014
On Wed, Jan 22, 2014 at 5:37 PM, David Liu <daveliu at mit.edu> wrote:
> Hi, I'm running a very simple code, consisting of just PetscFinalize and
> PetscInitialize and nothing else.
> I'm running it with valgrind using the command
> "valgrind ./run"
> I also tried (as the petsc homepage suggests)
> ${PETSC_DIR}/bin/petscmpiexec -valgrind -n 1 ./run -malloc off
> For both cases, I get tons of error messages like
> "Conditional jump or move depends on uninitialised value(s)"
> "Use of uninitialised value of size 8"
> "Invalid read of size 8"
> "Address 0xc15a998 is 40 bytes inside a block of size 47 alloc'd"
> with a final valgrind summary that includes things like
> ==29401==    definitely lost: 5,956 bytes in 55 blocks
> ==29401==    indirectly lost: 3,722 bytes in 22 blocks
> ==29401== ERROR SUMMARY: 619 errors from 8 contexts (suppressed: 4 from 4)
> Is this normal or is there something wrong with my petsc/valgrind
> installation? For the record, valgrind was already there when I compiled
> petsc.
You could include the log so we could verify, but this is common due to MPI
which is rarely valgrind clean.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140122/ca31b845/attachment.html>
