[petsc-users] SNESSetConvergenceTest
Wed Jan 22 17:33:34 CST 2014
On Wed, Jan 22, 2014 at 4:50 PM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> I take back my earlier email...
Do you have the threadcomm stuff turned on?
   Matt
> I see the error  irrespective of valgrind options. I did a clean
> compile to test it few times now.
> See the attached valgrind.log
> Now the difference between, ex5f90.F and my code is that i use
> DMSNESSetFunctionLocal in the case where the code fails.
> I have also attached the solver.F90 which wraps the calls to snes, Now
> the solver has to interface (1) for equations which are handled with a
> DM and (2) for equation with out DM , here i use SNESSetFunction, and
> this part of the code runs fine with the test case in the code which
> can be compiled with -DTestSolver and standard petsc makefile
> The case with DM is linked deeply into my code, i am trying to get to
> a test case for that.
> thanks
> Reddy
> On Wed, Jan 22, 2014 at 4:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    The thing to use in valgrind is -q --tool=memcheck
> >     This checks for corrupted and illegally accessed memory,
> uninitialized memory etc  It shows the exact lines that memory is used
> incorrectly so you can fix your code.
> >    Barry
> > On Jan 22, 2014, at 4:02 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
> wrote:
> >> Hello,
> >>        The code works fine if i run with valgrind --leak-check=yes
> exename args
> >> it fails if i run  valgrind exename args
> >> Any suggestions on what to look for my code?
> >> Thanks
> >> Reddy
> >> On Wed, Jan 22, 2014 at 3:31 PM, Dharmendar Reddy
> >> <dharmareddy84 at gmail.com> wrote:
> >>> Hello,
> >>>        I tried using the SNESSetConvergenceTest in ex5f90.F using my
> >>> subroutine. Works as expected. I will try to run my code through
> >>> valgrind.
> >>> Thanks
> >>> Reddy
> >>> On Wed, Jan 22, 2014 at 2:33 PM, Dharmendar Reddy
> >>>> Hello,
> >>>>         I will also try to create a stand alone test case.
> >>>> Thanks
> >>>> Reddy
> >>>> On Wed, Jan 22, 2014 at 1:53 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >>>>> On Wed, Jan 22, 2014 at 1:52 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >>>>>>  We need more information to track this down. Could you make a
> simple
> >>>>>> standalone code that reproduces the problem? Just creates a this,
> creates a
> >>>>>> SNES, sets the function, sets the test code and then crashes when
> runs.
> >>>>>>   But since it is not crashing in the SNESConvergenceTest_snes
> routine I
> >>>>>> suspect it may be memory corruption. Have you run your code under
> valgrind?
> >>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> >>>>> I am putting his convergence test into ex5f right now. This can be
> >>>>> valgrinded. I will send an update when it runs.
> >>>>>  Matt
> >>>>>>   Barry
> >>>>>> On Jan 20, 2014, at 7:14 PM, Dharmendar Reddy <
> >>>>>> wrote:
> >>>>>>> Hello,
> >>>>>>>        I am getting a segmentation fault when i use
> >>>>>>> SNESSetConvergenceTest from Fortran.
> >>>>>>> I use the following:
> >>>>>>> call SNESSetConvergenceTest(this%snes, SNESConvergenceTest_snes,
> >>>>>>> this,PETSC_NULL_FUNCTION, ierr)   (Line 1)
> >>>>>>> where the soubtoutine is
> >>>>>>> subroutine
> >>>>>>> SNESConvergenceTest_snes(snes,it,xnorm,gnorm,fnorm,reason,this,
> ierr)
> >>>>>>> implicit none
> >>>>>>> #include "finclude/petsc.h"
> >>>>>>> ! IO Variables
> >>>>>>> SNES :: snes
> >>>>>>> integer :: it
> >>>>>>> PetscReal :: xnorm
> >>>>>>> PetscReal :: gnorm
> >>>>>>> PetscReal :: fnorm
> >>>>>>> SNESConvergedReason :: reason
> >>>>>>> type(Solver_t) :: this
> >>>>>>> PetscErrorCode :: ierr
> >>>>>>> ! Local Variables
> >>>>>>> Vec :: X, dX
> >>>>>>> Vec :: F, W, G
> >>>>>>> real(WP) :: lambda
> >>>>>>> print*, 'Calling custom test',it,xnorm,fnorm,gnorm
> >>>>>>> !call SNESLineSearchGetLambda(this%linesearch, lambda, ierr)
> >>>>>>> !call SNESLineSearchGetVecs(this%linesearch, X, F, dX, W, G, ierr)
> >>>>>>> !call this%SNESConvergenceTest(it, fnorm, lambda, X, dX, reason,
> ierr)
> >>>>>>> reason = SNES_DIVERGED_FUNCTION_COUNT
> >>>>>>> end subroutine SNESConvergenceTest_snes
> >>>>>>> Code works fine if  the call at Line 1 is commented i.e, if i donot
> >>>>>>> set the convergencetest
> >>>>>>> I have attached the stack trace when the code fails (traceFail.log)
> >>>>>>> and stack trace of the code which runs well (tracePass.log).
> >>>>>>> Thanks
> >>>>>>> Reddy
> >>>>>>> <traceFail.log><tracePass.log>
> >>>>> What most experimenters take for granted before they begin their
> experiments
> >>>>> is infinitely more interesting than any results to which their
> experiments
> >>>>> lead.
> >>>>> -- Norbert Wiener
> >>>> Dharmendar Reddy Palle
> >>>> Graduate Student
> >>>> Microelectronics Research center,
> >>>> University of Texas at Austin,
> >>>> 10100 Burnet Road, Bldg. 160
> >>>> MER 2.608F, TX 78758-4445
> >>>> e-mail: dharmareddy84 at gmail.com
> >>>> Phone: +1-512-350-9082
> >>>> United States of America.
> >>>> Homepage: https://webspace.utexas.edu/~dpr342
> >>> Graduate Student
> >> Graduate Student
> Graduate Student
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140122/8853dc25/attachment.html>
