[petsc-users] SNESSetConvergenceTest
Dharmendar Reddy dharmareddy84 at gmail.com
Wed Jan 22 16:50:01 CST 2014
I take back my earlier email...
I see the error  irrespective of valgrind options. I did a clean
compile to test it few times now.
See the attached valgrind.log
Now the difference between, ex5f90.F and my code is that i use
DMSNESSetFunctionLocal in the case where the code fails.
I have also attached the solver.F90 which wraps the calls to snes, Now
the solver has to interface (1) for equations which are handled with a
DM and (2) for equation with out DM , here i use SNESSetFunction, and
this part of the code runs fine with the test case in the code which
can be compiled with -DTestSolver and standard petsc makefile
The case with DM is linked deeply into my code, i am trying to get to
a test case for that.
thanks
Reddy
On Wed, Jan 22, 2014 at 4:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    The thing to use in valgrind is -q --tool=memcheck
>     This checks for corrupted and illegally accessed memory, uninitialized memory etc  It shows the exact lines that memory is used incorrectly so you can fix your code.
>    Barry
> On Jan 22, 2014, at 4:02 PM, Dharmendar Reddy <dharmareddy84 at gmail.com> wrote:
>> Hello,
>>        The code works fine if i run with valgrind --leak-check=yes exename args
>> it fails if i run  valgrind exename args
>> Any suggestions on what to look for my code?
>> Thanks
>> Reddy
>> On Wed, Jan 22, 2014 at 3:31 PM, Dharmendar Reddy
>>> Hello,
>>>        I tried using the SNESSetConvergenceTest in ex5f90.F using my
>>> subroutine. Works as expected. I will try to run my code through
>>> valgrind.
>>> Thanks
>>> Reddy
>>> On Wed, Jan 22, 2014 at 2:33 PM, Dharmendar Reddy
>>>> Hello,
>>>>         I will also try to create a stand alone test case.
>>>> Thanks
>>>> Reddy
>>>> On Wed, Jan 22, 2014 at 1:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>>> On Wed, Jan 22, 2014 at 1:52 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>>  We need more information to track this down. Could you make a simple
>>>>>> standalone code that reproduces the problem? Just creates a this, creates a
>>>>>> SNES, sets the function, sets the test code and then crashes when runs.
>>>>>>   But since it is not crashing in the SNESConvergenceTest_snes routine I
>>>>>> suspect it may be memory corruption. Have you run your code under valgrind?
>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>> I am putting his convergence test into ex5f right now. This can be
>>>>> valgrinded. I will send an update when it runs.
>>>>>  Matt
>>>>>>   Barry
>>>>>> On Jan 20, 2014, at 7:14 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
>>>>>> wrote:
>>>>>>> Hello,
>>>>>>>        I am getting a segmentation fault when i use
>>>>>>> SNESSetConvergenceTest from Fortran.
>>>>>>> I use the following:
>>>>>>> call SNESSetConvergenceTest(this%snes, SNESConvergenceTest_snes,
>>>>>>> this,PETSC_NULL_FUNCTION, ierr)   (Line 1)
>>>>>>> where the soubtoutine is
>>>>>>> subroutine
>>>>>>> SNESConvergenceTest_snes(snes,it,xnorm,gnorm,fnorm,reason,this, ierr)
>>>>>>> implicit none
>>>>>>> #include "finclude/petsc.h"
>>>>>>> ! IO Variables
>>>>>>> SNES :: snes
>>>>>>> integer :: it
>>>>>>> PetscReal :: xnorm
>>>>>>> PetscReal :: gnorm
>>>>>>> PetscReal :: fnorm
>>>>>>> SNESConvergedReason :: reason
>>>>>>> type(Solver_t) :: this
>>>>>>> PetscErrorCode :: ierr
>>>>>>> ! Local Variables
>>>>>>> Vec :: X, dX
>>>>>>> Vec :: F, W, G
>>>>>>> real(WP) :: lambda
>>>>>>> print*, 'Calling custom test',it,xnorm,fnorm,gnorm
>>>>>>> !call SNESLineSearchGetLambda(this%linesearch, lambda, ierr)
>>>>>>> !call SNESLineSearchGetVecs(this%linesearch, X, F, dX, W, G, ierr)
>>>>>>> !call this%SNESConvergenceTest(it, fnorm, lambda, X, dX, reason, ierr)
>>>>>>> reason = SNES_DIVERGED_FUNCTION_COUNT
>>>>>>> end subroutine SNESConvergenceTest_snes
>>>>>>> Code works fine if  the call at Line 1 is commented i.e, if i donot
>>>>>>> set the convergencetest
>>>>>>> I have attached the stack trace when the code fails (traceFail.log)
>>>>>>> and stack trace of the code which runs well (tracePass.log).
>>>>>>> Thanks
>>>>>>> Reddy
>>>>>>> <traceFail.log><tracePass.log>
>>>>> What most experimenters take for granted before they begin their experiments
>>>>> is infinitely more interesting than any results to which their experiments
>>>>> lead.
>>>>> -- Norbert Wiener
>>>> Dharmendar Reddy Palle
>>>> Graduate Student
>>>> Microelectronics Research center,
>>>> University of Texas at Austin,
>>>> 10100 Burnet Road, Bldg. 160
>>>> MER 2.608F, TX 78758-4445
>>>> e-mail: dharmareddy84 at gmail.com
>>>> Phone: +1-512-350-9082
>>>> United States of America.
>>>> Homepage: https://webspace.utexas.edu/~dpr342
>>> Graduate Student
>> Graduate Student
Graduate Student
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140122/44843fa2/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140122/44843fa2/attachment-0003.obj>
