[petsc-users] SNESSetConvergenceTest
Dharmendar Reddy dharmareddy84 at gmail.com
Wed Jan 22 17:37:59 CST 2014
On Wed, Jan 22, 2014 at 5:33 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 22, 2014 at 4:50 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
> wrote:
>> I take back my earlier email...
> Do you have the threadcomm stuff turned on?
I do not know what this means. Is related to compile time flags for my
fortran code ? I link to mkl which is threaded. But otherwise, i
guess, the answer is no.
>    Matt
>> I see the error  irrespective of valgrind options. I did a clean
>> compile to test it few times now.
>> See the attached valgrind.log
>> Now the difference between, ex5f90.F and my code is that i use
>> DMSNESSetFunctionLocal in the case where the code fails.
>> I have also attached the solver.F90 which wraps the calls to snes, Now
>> the solver has to interface (1) for equations which are handled with a
>> DM and (2) for equation with out DM , here i use SNESSetFunction, and
>> this part of the code runs fine with the test case in the code which
>> can be compiled with -DTestSolver and standard petsc makefile
>> The case with DM is linked deeply into my code, i am trying to get to
>> a test case for that.
>> thanks
>> Reddy
>> On Wed, Jan 22, 2014 at 4:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> >    The thing to use in valgrind is -q --tool=memcheck
>> >     This checks for corrupted and illegally accessed memory,
>> > uninitialized memory etc  It shows the exact lines that memory is used
>> > incorrectly so you can fix your code.
>> >    Barry
>> > On Jan 22, 2014, at 4:02 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
>> > wrote:
>> >> Hello,
>> >>        The code works fine if i run with valgrind --leak-check=yes
>> >> exename args
>> >> it fails if i run  valgrind exename args
>> >> Any suggestions on what to look for my code?
>> >> Thanks
>> >> Reddy
>> >> On Wed, Jan 22, 2014 at 3:31 PM, Dharmendar Reddy
>> >> <dharmareddy84 at gmail.com> wrote:
>> >>> Hello,
>> >>>        I tried using the SNESSetConvergenceTest in ex5f90.F using my
>> >>> subroutine. Works as expected. I will try to run my code through
>> >>> valgrind.
>> >>> Thanks
>> >>> Reddy
>> >>> On Wed, Jan 22, 2014 at 2:33 PM, Dharmendar Reddy
>> >>>> Hello,
>> >>>>         I will also try to create a stand alone test case.
>> >>>> Thanks
>> >>>> Reddy
>> >>>> On Wed, Jan 22, 2014 at 1:53 PM, Matthew Knepley <knepley at gmail.com>
>> >>>> wrote:
>> >>>>> On Wed, Jan 22, 2014 at 1:52 PM, Barry Smith <bsmith at mcs.anl.gov>
>> >>>>> wrote:
>> >>>>>>  We need more information to track this down. Could you make a
>> >>>>>> simple
>> >>>>>> standalone code that reproduces the problem? Just creates a this,
>> >>>>>> creates a
>> >>>>>> SNES, sets the function, sets the test code and then crashes when
>> >>>>>> runs.
>> >>>>>>   But since it is not crashing in the SNESConvergenceTest_snes
>> >>>>>> routine I
>> >>>>>> suspect it may be memory corruption. Have you run your code under
>> >>>>>> valgrind?
>> >>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> >>>>> I am putting his convergence test into ex5f right now. This can be
>> >>>>> valgrinded. I will send an update when it runs.
>> >>>>>  Matt
>> >>>>>>   Barry
>> >>>>>> On Jan 20, 2014, at 7:14 PM, Dharmendar Reddy
>> >>>>>> wrote:
>> >>>>>>> Hello,
>> >>>>>>>        I am getting a segmentation fault when i use
>> >>>>>>> SNESSetConvergenceTest from Fortran.
>> >>>>>>> I use the following:
>> >>>>>>> call SNESSetConvergenceTest(this%snes, SNESConvergenceTest_snes,
>> >>>>>>> this,PETSC_NULL_FUNCTION, ierr)   (Line 1)
>> >>>>>>> where the soubtoutine is
>> >>>>>>> subroutine
>> >>>>>>> SNESConvergenceTest_snes(snes,it,xnorm,gnorm,fnorm,reason,this,
>> >>>>>>> ierr)
>> >>>>>>> implicit none
>> >>>>>>> #include "finclude/petsc.h"
>> >>>>>>> ! IO Variables
>> >>>>>>> SNES :: snes
>> >>>>>>> integer :: it
>> >>>>>>> PetscReal :: xnorm
>> >>>>>>> PetscReal :: gnorm
>> >>>>>>> PetscReal :: fnorm
>> >>>>>>> SNESConvergedReason :: reason
>> >>>>>>> type(Solver_t) :: this
>> >>>>>>> PetscErrorCode :: ierr
>> >>>>>>> ! Local Variables
>> >>>>>>> Vec :: X, dX
>> >>>>>>> Vec :: F, W, G
>> >>>>>>> real(WP) :: lambda
>> >>>>>>> print*, 'Calling custom test',it,xnorm,fnorm,gnorm
>> >>>>>>> !call SNESLineSearchGetLambda(this%linesearch, lambda, ierr)
>> >>>>>>> !call SNESLineSearchGetVecs(this%linesearch, X, F, dX, W, G, ierr)
>> >>>>>>> !call this%SNESConvergenceTest(it, fnorm, lambda, X, dX, reason,
>> >>>>>>> ierr)
>> >>>>>>> reason = SNES_DIVERGED_FUNCTION_COUNT
>> >>>>>>> end subroutine SNESConvergenceTest_snes
>> >>>>>>> Code works fine if  the call at Line 1 is commented i.e, if i
>> >>>>>>> donot
>> >>>>>>> set the convergencetest
>> >>>>>>> I have attached the stack trace when the code fails
>> >>>>>>> (traceFail.log)
>> >>>>>>> and stack trace of the code which runs well (tracePass.log).
>> >>>>>>> Thanks
>> >>>>>>> Reddy
>> >>>>>>> <traceFail.log><tracePass.log>
>> >>>>> What most experimenters take for granted before they begin their
>> >>>>> experiments
>> >>>>> is infinitely more interesting than any results to which their
>> >>>>> experiments
>> >>>>> lead.
>> >>>>> -- Norbert Wiener
>> >>>> Dharmendar Reddy Palle
>> >>>> Graduate Student
>> >>>> Microelectronics Research center,
>> >>>> University of Texas at Austin,
>> >>>> 10100 Burnet Road, Bldg. 160
>> >>>> MER 2.608F, TX 78758-4445
>> >>>> e-mail: dharmareddy84 at gmail.com
>> >>>> Phone: +1-512-350-9082
>> >>>> United States of America.
>> >>>> Homepage: https://webspace.utexas.edu/~dpr342
>> >>> Graduate Student
>> >> Graduate Student
>> Graduate Student
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Graduate Student
