[petsc-users] help with vecSetValuesSectionF90
Dharmendar Reddy dharmareddy84 at gmail.com
Sat Jan 11 02:13:00 CST 2014
Okay. Thanks.
On Fri, Jan 10, 2014 at 8:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 10, 2014 at 8:38 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
> wrote:
>> Hello,
>>         I am getting an error using VecSetValuesSectionF90. I had this
>> working before, i do not know whats wrong now. The call is deep inside
>> my code so i am not able to create a test case.
> I believe this is our bug, from the name change. If you look in
>   include/finclude/ftn-custom/petscvec.h90:43
> you see that the function name is wrong. This causes the Fortran compiler to
> emit wrong code and
> never tell us about it. If you change the name here and recompile it should
> work. I will push this fix
> tomorrow.
>   Thanks,
>      Matt
>> I am using: Petsc Development GIT revision:
>> b45093d79c132b908a729253318f899155602205  GIT Date: 2013-11-11 1
>> 6:19:16 -0600
>> Hope the code chunk below, can help identify the issue.
>>  The following is the sequence of calls:
>>     DM :: dm
>>   Vec :: localX
>>   InsertMode :: mode
>>   PetscErrorCode :: ierr
>>   PetscSection :: section ! defualt section
>>   PetscScalar,allocatable :: values(:) ! size numDofPerPoint
>>   integer :: vertexId
>>   integer :: vertexIdStart, vertexIdEnd
>>   integer :: vertextdim
>>   integer :: numConstrainedDOF
>>   integer :: rgnId,bcId,offset
>>   integer :: IdStart,IdEnd
>>   integer :: fc
>>   vertextdim = 0
>>   call DMPlexGetDepthStratum(dm,vertextdim,vertexIdStart,vertexIdEnd,
>> ierr)
>>   call DMGetDefaultSection(dm, section, ierr)
>>   call PetscSectionView(section,PETSC_VIEWER_STDOUT_SELF,ierr)
>>   allocate(values(this%dofMap%numFieldComp))
>>   print*, 'size of values is',this%dofMap%numFieldComp
>>   do vertexId=vertexIdStart,vertexIdEnd-1
>>     call
>> PetscSectionGetConstraintDof(section,vertexId,numConstrainedDOF,ierr)
>>     print*,'vertex dof',vertexId,numConstrainedDOF
>>     if(numConstrainedDOF > 0) then
>>       call DMPlexGetLabelValue(dm,'Boundary',vertexId,rgnId, ierr)
>>         values = 0.0_WP
>>         offset = 0
>>         do fc = 1,this%numField
>>         ! check if Field at vertextId is contained
>>         IdStart = offset + 1
>>         IdEnd = offset + this%numComp(fc)
>>         !if(fieldIdisconstrained) then
>>           bcId = this%getBCId(fc,rgnId)
>>           values(IdStart:IdEnd) = this%BC(bcId)%getBC()
>>         !end if
>>         offset = offset + this%numComp(fc)
>>         end do
>>         print*,'Setting bc value',values(1),'at vertex',vertexId,rgnId
>>         call VecSetValuesSectionF90(localX, section, vertexId,
>> values,Mode,ierr)
>>       end if
>>   end do
>>   deallocate(values)
>>  The three print statements above print the following lines.
>>  size of values is           1
>>  vertex dof         600           1
>>  Setting bc value  -35.7688912272406      at vertex         600
>> 1
>>  So, i am passing the correct size array to VecSetValuesSectionF90.
>> However, when i run the code through intel debugger, i get the
>> following:
>>  size of values is           1
>>  vertex dof         600           1
>> 1
>> Program received signal SIGSEGV
>> VecSetValuesSection (v=0x2bf5620, s=0x2b41a60, point=600,
>> values=0x447e3d3b071996fc, mode=INSERT_BC_VALUES
>> ) at
>> /home1/00924/Reddy135/LocalApps/petsc/src/vec/vec/utils/vsection.c:185
>> 185                 if (doBC) array[i] = values[i]; /* Constrained update
>> (idb) print values[0]
>> $1 = <no value>
>> The value i passed from Fortran code is not missing.
>> The relevant call trace is:
>> (idb) bt
>> #0  0x00002b477a299b2d in VecSetValuesSection (v=0x2bf5620,
>> s=0x2b41a60, point=600, values=0x447e3d3b071996fc, mode
>> =INSERT_BC_VALUES) at
>> #1  0x00002b477a29aead in vecsetvaluessectionf90_ (v=0x7fff16adce30,
>> section=0x7fff16adc790, point=0x7fff16adc6f4,
>> ptr=0x2b12740, mode=0x9aa990, __ierr=0x7fff16adce08) at
>> /home1/00924/Reddy135/LocalApps/petsc/src/vec/vec/utils/f90
>> -custom/zvsectionf90.c:17
>> Am i doing some thing wrong ?
>> Thanks
>> Reddy
>> Dharmendar Reddy Palle
>> Graduate Student
>> Microelectronics Research center,
>> University of Texas at Austin,
>> 10100 Burnet Road, Bldg. 160
>> MER 2.608F, TX 78758-4445
>> e-mail: dharmareddy84 at gmail.com
>> Phone: +1-512-350-9082
>> United States of America.
>> Homepage: https://webspace.utexas.edu/~dpr342
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Graduate Student
