[petsc-users] help with vecSetValuesSectionF90
Sat Jan 11 08:54:11 CST 2014
On Sat, Jan 11, 2014 at 2:13 AM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> Okay. Thanks.
Pushed to next.
     Matt
> On Fri, Jan 10, 2014 at 8:56 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Fri, Jan 10, 2014 at 8:38 PM, Dharmendar Reddy <
> > wrote:
> >> Hello,
> >>         I am getting an error using VecSetValuesSectionF90. I had this
> >> working before, i do not know whats wrong now. The call is deep inside
> >> my code so i am not able to create a test case.
> > I believe this is our bug, from the name change. If you look in
> >   include/finclude/ftn-custom/petscvec.h90:43
> > you see that the function name is wrong. This causes the Fortran
> compiler to
> > emit wrong code and
> > never tell us about it. If you change the name here and recompile it
> should
> > work. I will push this fix
> > tomorrow.
> >   Thanks,
> >      Matt
> >> I am using: Petsc Development GIT revision:
> >> b45093d79c132b908a729253318f899155602205  GIT Date: 2013-11-11 1
> >> 6:19:16 -0600
> >> Hope the code chunk below, can help identify the issue.
> >>  The following is the sequence of calls:
> >>     DM :: dm
> >>   Vec :: localX
> >>   InsertMode :: mode
> >>   PetscErrorCode :: ierr
> >>   PetscSection :: section ! defualt section
> >>   PetscScalar,allocatable :: values(:) ! size numDofPerPoint
> >>   integer :: vertexId
> >>   integer :: vertexIdStart, vertexIdEnd
> >>   integer :: vertextdim
> >>   integer :: numConstrainedDOF
> >>   integer :: rgnId,bcId,offset
> >>   integer :: IdStart,IdEnd
> >>   integer :: fc
> >>   vertextdim = 0
> >>   call DMPlexGetDepthStratum(dm,vertextdim,vertexIdStart,vertexIdEnd,
> >> ierr)
> >>   call DMGetDefaultSection(dm, section, ierr)
> >>   call PetscSectionView(section,PETSC_VIEWER_STDOUT_SELF,ierr)
> >>   allocate(values(this%dofMap%numFieldComp))
> >>   print*, 'size of values is',this%dofMap%numFieldComp
> >>   do vertexId=vertexIdStart,vertexIdEnd-1
> >>     call
> >> PetscSectionGetConstraintDof(section,vertexId,numConstrainedDOF,ierr)
> >>     print*,'vertex dof',vertexId,numConstrainedDOF
> >>     if(numConstrainedDOF > 0) then
> >>       call DMPlexGetLabelValue(dm,'Boundary',vertexId,rgnId, ierr)
> >>         values = 0.0_WP
> >>         offset = 0
> >>         do fc = 1,this%numField
> >>         ! check if Field at vertextId is contained
> >>         IdStart = offset + 1
> >>         IdEnd = offset + this%numComp(fc)
> >>         !if(fieldIdisconstrained) then
> >>           bcId = this%getBCId(fc,rgnId)
> >>           values(IdStart:IdEnd) = this%BC(bcId)%getBC()
> >>         !end if
> >>         offset = offset + this%numComp(fc)
> >>         end do
> >>         print*,'Setting bc value',values(1),'at vertex',vertexId,rgnId
> >>         call VecSetValuesSectionF90(localX, section, vertexId,
> >> values,Mode,ierr)
> >>       end if
> >>   end do
> >>   deallocate(values)
> >>  The three print statements above print the following lines.
> >>  size of values is           1
> >>  vertex dof         600           1
> >>  Setting bc value  -35.7688912272406      at vertex         600
> >> 1
> >>  So, i am passing the correct size array to VecSetValuesSectionF90.
> >> However, when i run the code through intel debugger, i get the
> >> following:
> >>  size of values is           1
> >>  vertex dof         600           1
> >> 1
> >> Program received signal SIGSEGV
> >> VecSetValuesSection (v=0x2bf5620, s=0x2b41a60, point=600,
> >> values=0x447e3d3b071996fc, mode=INSERT_BC_VALUES
> >> ) at
> >> /home1/00924/Reddy135/LocalApps/petsc/src/vec/vec/utils/vsection.c:185
> >> 185                 if (doBC) array[i] = values[i]; /* Constrained
> update
> >> (idb) print values[0]
> >> $1 = <no value>
> >> The value i passed from Fortran code is not missing.
> >> The relevant call trace is:
> >> (idb) bt
> >> #0  0x00002b477a299b2d in VecSetValuesSection (v=0x2bf5620,
> >> s=0x2b41a60, point=600, values=0x447e3d3b071996fc, mode
> >> =INSERT_BC_VALUES) at
> >> #1  0x00002b477a29aead in vecsetvaluessectionf90_ (v=0x7fff16adce30,
> >> section=0x7fff16adc790, point=0x7fff16adc6f4,
> >> ptr=0x2b12740, mode=0x9aa990, __ierr=0x7fff16adce08) at
> >> /home1/00924/Reddy135/LocalApps/petsc/src/vec/vec/utils/f90
> >> -custom/zvsectionf90.c:17
> >> Am i doing some thing wrong ?
> >> Thanks
> >> Reddy
> >> Dharmendar Reddy Palle
> >> Graduate Student
> >> Microelectronics Research center,
> >> University of Texas at Austin,
> >> 10100 Burnet Road, Bldg. 160
> >> MER 2.608F, TX 78758-4445
> >> e-mail: dharmareddy84 at gmail.com
> >> Phone: +1-512-350-9082
> >> United States of America.
> >> Homepage: https://webspace.utexas.edu/~dpr342
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
> Graduate Student
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140111/97671a3a/attachment-0001.html>
