[petsc-users] help with vecSetValuesSectionF90
Fri Jan 10 20:56:07 CST 2014
On Fri, Jan 10, 2014 at 8:38 PM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> Hello,
>         I am getting an error using VecSetValuesSectionF90. I had this
> working before, i do not know whats wrong now. The call is deep inside
> my code so i am not able to create a test case.
I believe this is our bug, from the name change. If you look in
  include/finclude/ftn-custom/petscvec.h90:43
you see that the function name is wrong. This causes the Fortran compiler
to emit wrong code and
never tell us about it. If you change the name here and recompile it should
work. I will push this fix
tomorrow.
     Matt
> I am using: Petsc Development GIT revision:
> b45093d79c132b908a729253318f899155602205  GIT Date: 2013-11-11 1
> 6:19:16 -0600
> Hope the code chunk below, can help identify the issue.
>  The following is the sequence of calls:
>     DM :: dm
>   Vec :: localX
>   InsertMode :: mode
>   PetscErrorCode :: ierr
>   PetscSection :: section ! defualt section
>   PetscScalar,allocatable :: values(:) ! size numDofPerPoint
>   integer :: vertexId
>   integer :: vertexIdStart, vertexIdEnd
>   integer :: vertextdim
>   integer :: numConstrainedDOF
>   integer :: rgnId,bcId,offset
>   integer :: IdStart,IdEnd
>   integer :: fc
>   vertextdim = 0
>   call DMPlexGetDepthStratum(dm,vertextdim,vertexIdStart,vertexIdEnd, ierr)
>   call DMGetDefaultSection(dm, section, ierr)
>   call PetscSectionView(section,PETSC_VIEWER_STDOUT_SELF,ierr)
>   allocate(values(this%dofMap%numFieldComp))
>   print*, 'size of values is',this%dofMap%numFieldComp
>   do vertexId=vertexIdStart,vertexIdEnd-1
>     call
> PetscSectionGetConstraintDof(section,vertexId,numConstrainedDOF,ierr)
>     print*,'vertex dof',vertexId,numConstrainedDOF
>     if(numConstrainedDOF > 0) then
>       call DMPlexGetLabelValue(dm,'Boundary',vertexId,rgnId, ierr)
>         values = 0.0_WP
>         offset = 0
>         do fc = 1,this%numField
>         ! check if Field at vertextId is contained
>         IdStart = offset + 1
>         IdEnd = offset + this%numComp(fc)
>         !if(fieldIdisconstrained) then
>           bcId = this%getBCId(fc,rgnId)
>           values(IdStart:IdEnd) = this%BC(bcId)%getBC()
>         !end if
>         offset = offset + this%numComp(fc)
>         end do
>         print*,'Setting bc value',values(1),'at vertex',vertexId,rgnId
>         call VecSetValuesSectionF90(localX, section, vertexId,
> values,Mode,ierr)
>       end if
>   end do
>   deallocate(values)
>  The three print statements above print the following lines.
>  size of values is           1
>  vertex dof         600           1
>  Setting bc value  -35.7688912272406      at vertex         600           1
>  So, i am passing the correct size array to VecSetValuesSectionF90.
> However, when i run the code through intel debugger, i get the
> following:
>  size of values is           1
>  vertex dof         600           1
> Program received signal SIGSEGV
> VecSetValuesSection (v=0x2bf5620, s=0x2b41a60, point=600,
> values=0x447e3d3b071996fc, mode=INSERT_BC_VALUES
> ) at /home1/00924/Reddy135/LocalApps/petsc/src/vec/vec/utils/vsection.c:185
> 185                 if (doBC) array[i] = values[i]; /* Constrained update
> (idb) print values[0]
> $1 = <no value>
> The value i passed from Fortran code is not missing.
> The relevant call trace is:
> (idb) bt
> #0  0x00002b477a299b2d in VecSetValuesSection (v=0x2bf5620,
> s=0x2b41a60, point=600, values=0x447e3d3b071996fc, mode
> =INSERT_BC_VALUES) at
> #1  0x00002b477a29aead in vecsetvaluessectionf90_ (v=0x7fff16adce30,
> section=0x7fff16adc790, point=0x7fff16adc6f4,
> ptr=0x2b12740, mode=0x9aa990, __ierr=0x7fff16adce08) at
> /home1/00924/Reddy135/LocalApps/petsc/src/vec/vec/utils/f90
> -custom/zvsectionf90.c:17
> Am i doing some thing wrong ?
> Thanks
> Reddy
> Dharmendar Reddy Palle
> Graduate Student
> Microelectronics Research center,
> University of Texas at Austin,
> 10100 Burnet Road, Bldg. 160
> MER 2.608F, TX 78758-4445
> e-mail: dharmareddy84 at gmail.com
> Phone: +1-512-350-9082
> United States of America.
> Homepage: https://webspace.utexas.edu/~dpr342
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140110/d2490055/attachment.html>
