[petsc-users] Modeling a Network with DMPlex?
Florian Meier florian.meier at koalo.de
Fri Feb 14 11:25:55 CST 2014
Ok, that was just a stupid typo.
I have now build the first attempt of an example.
I am sure that can be programmed in a much better way,
so I would be very glad about any comment. What is your
preferred review procedure?
Greetings,
Florian
static char help[] = "This example demonstrates the DMCircuit interface for a radio network flow problem.\n\
                      The available solver options are in the alohaoptions file.\n\
                      The file links.txt contains the network description.\n\
                      Run this program: mpiexec -n <n> ./PF\n					\
                      mpiexec -n <n> ./PF -pfdata <filename>\n";
This computes a greatly simplified model of a radio network.
Each node in the network generates packets conforming to a poisson distribution (given rate R_gen).
These packets are routed along fixed paths to a sink. When two packets are send at the same time,
they are dropped. No channel sensing or retransmission takes place.
Each active link (i.e. each radio link that will eventually transmit data) is modeled as a vertex.
Between those vertices there exist two kinds of relations:
A relation of type REL_INTERFERENCE(affected, source), implies that whenever the source link tries
to send at the same time than the affected link, the packet will collide and is not received properly.
A relation of type REL_INFLOW(affected, source) implies that each packet that is send via the source
link and does not collide, adds up to the amount of packets send via the affected link.
The overall rate of accessing a radio link i is
R_access,i = R_gen,i + SUM_OVER_INFLOWS( R_success,j )
The probability that no other link interfering with i accesses the channel at a given point in time is
P_free,i = PRODUCT_OVER_INTERFERERS( 1 - R_access,j )
Finally, the overall rate of successful transmissions over link i is
R_success,i = R_access,i * P_free,i
The input file is structured as follows:
The first line contains L, the number of links, I, the number of interferences and F, the number of inflow relations.
Then L lines follow with the packet generation rate for each link.
The subsequent I lines describe the affected and the source link of the respective interference relation.
The final F lines represent the inflow relations.
#include <petsc.h>
#include <petscdmcircuit.h>
#include <fstream>
#include <iostream>
using namespace std;
enum {
  REL_INTERFERENCE,
  REL_INFLOW
enum {
  VAR_ACCESS,
  VAR_SUCCESS,
  VAR_NVARS
struct _p_LINKDATA{
  PetscScalar 	packet_generation;
typedef struct _p_LINKDATA *LINKDATA;
struct _p_RELATIONDATA{
  PetscInt      source;
  PetscInt      affected;
  PetscInt	type;
typedef struct _p_RELATIONDATA *RELATIONDATA;
typedef struct {
  PetscInt    nlinks,nrelations; /* # of nodes,relations */
  LINKDATA links;
  RELATIONDATA relations;
} PFDATA;
PetscMPIInt rank;
#undef __FUNCT__
#define __FUNCT__ "FormFunction"
PetscErrorCode FormFunction(SNES snes,Vec X, Vec F,void *appctx)
  PetscErrorCode ierr;
  DM             circuitdm;
  Vec           localX,localF;
  PetscInt      e;
  PetscInt      v,vStart,vEnd,vaffected,vsource;
  const PetscScalar *xarr;
  PetscScalar   *farr;
  PetscInt      offset,offsetsource,offsetlink,offsetrel;
  DMCircuitComponentGenericDataType *arr;
  PetscFunctionBegin;
  ierr = SNESGetDM(snes,&circuitdm);CHKERRQ(ierr);
  ierr = DMGetLocalVector(circuitdm,&localX);CHKERRQ(ierr);
  ierr = DMGetLocalVector(circuitdm,&localF);CHKERRQ(ierr);
  ierr = VecSet(F,0.0);CHKERRQ(ierr);
  ierr = DMGlobalToLocalBegin(circuitdm,X,INSERT_VALUES,localX);CHKERRQ(ierr);
  ierr = DMGlobalToLocalEnd(circuitdm,X,INSERT_VALUES,localX);CHKERRQ(ierr);
  ierr = DMGlobalToLocalBegin(circuitdm,F,INSERT_VALUES,localF);CHKERRQ(ierr);
  ierr = DMGlobalToLocalEnd(circuitdm,F,INSERT_VALUES,localF);CHKERRQ(ierr);
  ierr = VecGetArrayRead(localX,&xarr);CHKERRQ(ierr);
  ierr = VecGetArray(localF,&farr);CHKERRQ(ierr);
  ierr = DMCircuitGetVertexRange(circuitdm,&vStart,&vEnd);CHKERRQ(ierr);
  ierr = DMCircuitGetComponentDataArray(circuitdm,&arr);CHKERRQ(ierr);
  for (v=vStart; v < vEnd; v++) {
    PetscBool   ghostvtex;
    ierr = DMCircuitIsGhostVertex(circuitdm,v,&ghostvtex);CHKERRQ(ierr);
    if (ghostvtex) {
      continue; // TODO is that ok?
    PetscInt keyv;
    ierr = DMCircuitGetComponentTypeOffset(circuitdm,v,0,&keyv,&offsetlink);CHKERRQ(ierr);
    LINKDATA link = (LINKDATA)(arr+offsetlink);
    PetscScalar inflow = link->packet_generation;
    PetscScalar Pfree = 1;
    PetscInt nconnedges;
    const PetscInt *connedges;
    ierr = DMCircuitGetSupportingEdges(circuitdm,v,&nconnedges,&connedges);CHKERRQ(ierr);
    for (PetscInt i = 0; i < nconnedges; i++) {
      e = connedges[i];
      const PetscInt *cone;
      ierr = DMCircuitGetConnectedNodes(circuitdm,e,&cone);CHKERRQ(ierr);
      vaffected = cone[0];
      vsource   = cone[1];
      if (vaffected == v) {
	PetscInt keye;
        ierr = DMCircuitGetComponentTypeOffset(circuitdm,e,0,&keye,&offsetrel);CHKERRQ(ierr);
        RELATIONDATA relation = (RELATIONDATA)(arr+offsetrel);
        ierr = DMCircuitGetVariableOffset(circuitdm,vsource,&offsetsource);CHKERRQ(ierr);
        switch (relation->type) {
          case REL_INTERFERENCE:
            Pfree *= 1 - xarr[offsetsource+VAR_ACCESS];
            break;
          case REL_INFLOW:
            inflow += xarr[offsetsource+VAR_SUCCESS];
            break;
    ierr = DMCircuitGetVariableOffset(circuitdm,v,&offset);CHKERRQ(ierr);
    farr[offset+VAR_ACCESS] = inflow - xarr[offset+VAR_ACCESS];
    farr[offset+VAR_SUCCESS] = xarr[offset+VAR_ACCESS]*Pfree - xarr[offset+VAR_SUCCESS];
  ierr = VecRestoreArrayRead(localX,&xarr);CHKERRQ(ierr);
  ierr = VecRestoreArray(localF,&farr);CHKERRQ(ierr);
  ierr = DMRestoreLocalVector(circuitdm,&localX);CHKERRQ(ierr);
  ierr = DMLocalToGlobalBegin(circuitdm,localF,ADD_VALUES,F);CHKERRQ(ierr);
  ierr = DMLocalToGlobalEnd(circuitdm,localF,ADD_VALUES,F);CHKERRQ(ierr);
  ierr = DMRestoreLocalVector(circuitdm,&localF);CHKERRQ(ierr);
  PetscFunctionReturn(0);
#undef __FUNCT__
#define __FUNCT__ "FormJacobian"
PetscErrorCode FormJacobian(SNES snes,Vec X, Mat *J,Mat *Jpre,MatStructure *flg,void *appctx)
  DM            circuitdm;
  Vec           localX;
  PetscInt      e;
  PetscInt      offsetrel;
  PetscInt      row[1],col[1];
  PetscScalar   values[1];
  PetscFunctionBegin;
  *flg = SAME_NONZERO_PATTERN; // TODO ok for this problem?
  ierr = MatZeroEntries(*J);CHKERRQ(ierr);
    PetscInt    offset,goffset,offsetsource,goffsetsource;
    if (ghostvtex) {
    ierr = DMCircuitGetVariableGlobalOffset(circuitdm,v,&goffset);CHKERRQ(ierr);
    // TODO some derivatives are constant, can this be handled in SetInitialValues?
    // TODO can I combine these two MatSetValues?
    row[0] = goffset+VAR_ACCESS;
    col[0] = goffset+VAR_ACCESS;
    values[0] = -1.0;
    ierr = MatSetValues(*J,1,row,1,col,values,ADD_VALUES);CHKERRQ(ierr);
    row[0] = goffset+VAR_SUCCESS;
    col[0] = goffset+VAR_SUCCESS;
    values[0] = -1.0;
    // Calculate Pfree
    // TODO Pfree was already calculated in FromFunction, can I access that?
      e = connedges[i];
      vsource   = cone[1];
	PetscInt keye;
        if (relation->type == REL_INTERFERENCE) {
    values[0] = Pfree;
    // Set the derivatives
    PetscScalar inflow = xarr[offset+VAR_ACCESS];
      e = connedges[i];
      vsource   = cone[1];
	PetscInt keye;
        ierr = DMCircuitGetVariableGlobalOffset(circuitdm,vsource,&goffsetsource);CHKERRQ(ierr);
            // TODO Ok to set the entries one by one or is there a better way?
            col[0] = goffsetsource+VAR_ACCESS;
            values[0] = -inflow*(Pfree/(1-xarr[offsetsource+VAR_ACCESS]));
            break;
          case REL_INFLOW:
            col[0] = goffsetsource+VAR_SUCCESS;
            values[0] = 1.0;
            break;
  ierr = MatAssemblyBegin(*J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  ierr = MatAssemblyEnd(*J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
#undef __FUNCT__
#define __FUNCT__ "SetInitialValues"
PetscErrorCode SetInitialValues(DM circuitdm,Vec X,void *appctx)
  PetscInt       v, vStart, vEnd;
  Vec            localX;
  PetscScalar    *xarr;
  PetscFunctionBegin;
  ierr = VecSet(X,0.0);CHKERRQ(ierr);
  ierr = VecGetArray(localX,&xarr);CHKERRQ(ierr);
  for (v = vStart; v < vEnd; v++) {
    if (ghostvtex) {
    PetscInt offsetlink, offset;
    PetscInt keyv;
    xarr[offset+VAR_ACCESS] = link->packet_generation;
    xarr[offset+VAR_SUCCESS] = link->packet_generation;
  ierr = VecRestoreArray(localX,&xarr);CHKERRQ(ierr);
  ierr = DMLocalToGlobalBegin(circuitdm,localX,ADD_VALUES,X);CHKERRQ(ierr);
  ierr = DMLocalToGlobalEnd(circuitdm,localX,ADD_VALUES,X);CHKERRQ(ierr);
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char ** argv)
  string	       inputFile = "links.txt";
  PFDATA               pfdata;
  PetscInt             numEdges=0,numVertices=0;
  int                  *edges = NULL;
  PetscInt             i;
  DM                   circuitdm;
  PetscInt             componentkey[2];
  PetscLogStage        stage1,stage2;
  PetscInt             size;
  PetscInitialize(&argc,&argv,"alohaoptions",help);
  ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
  /* Create an empty circuit object */
  ierr = DMCircuitCreate(PETSC_COMM_WORLD,&circuitdm);CHKERRQ(ierr);
  /* Register the components in the circuit */
  ierr = DMCircuitRegisterComponent(circuitdm,"linkstruct",sizeof(struct _p_LINKDATA),&componentkey[0]);CHKERRQ(ierr);
  ierr = DMCircuitRegisterComponent(circuitdm,"relationstruct",sizeof(struct _p_RELATIONDATA),&componentkey[1]);CHKERRQ(ierr);
  ierr = PetscLogStageRegister("Read Data",&stage1);CHKERRQ(ierr);
  PetscLogStagePush(stage1);
  /* READ THE DATA */
  if (!rank) {
    /* Only rank 0 reads the data */
    ifstream linksF(inputFile.c_str());
    int ninterferences, ninflows;
    linksF >> pfdata.nlinks >> ninterferences >> ninflows;
    numVertices = pfdata.nlinks;
    numEdges = pfdata.nrelations = ninterferences + ninflows;
    ierr = PetscMalloc1(pfdata.nlinks,&pfdata.links);CHKERRQ(ierr);
    ierr = PetscMalloc1(pfdata.nrelations,&pfdata.relations);CHKERRQ(ierr);
    for(int i = 0; i < numVertices; i++) {
      linksF >> pfdata.links[i].packet_generation;
    ierr = PetscMalloc1(2*numEdges,&edges);CHKERRQ(ierr);
    for(int i = 0; i < numEdges; i++) {
      linksF >> pfdata.relations[i].affected >> pfdata.relations[i].source;
      pfdata.relations[i].type = (i < ninterferences) ? REL_INTERFERENCE : REL_INFLOW;
      edges[2*i] = pfdata.relations[i].affected;
      edges[2*i+1] = pfdata.relations[i].source;
    linksF.close();
  PetscLogStagePop();
  MPI_Barrier(PETSC_COMM_WORLD);
  ierr = PetscLogStageRegister("Create circuit",&stage2);CHKERRQ(ierr);
  PetscLogStagePush(stage2);
  /* Set number of nodes/edges */
  ierr = DMCircuitSetSizes(circuitdm,numVertices,numEdges,PETSC_DETERMINE,PETSC_DETERMINE);CHKERRQ(ierr);
  /* Add edge connectivity */
  ierr = DMCircuitSetEdgeList(circuitdm,edges);CHKERRQ(ierr);
  /* Set up the circuit layout */
  ierr = DMCircuitLayoutSetUp(circuitdm);CHKERRQ(ierr);
  if (!rank) {
    ierr = PetscFree(edges);CHKERRQ(ierr);
  /* Add circuit components */
  PetscInt eStart, eEnd, vStart, vEnd;
  for (i = vStart; i < vEnd; i++) {
    ierr = DMCircuitAddComponent(circuitdm,i,componentkey[0],&pfdata.links[i-vStart]);CHKERRQ(ierr);
    /* Add number of variables */
    ierr = DMCircuitAddNumVariables(circuitdm,i,VAR_NVARS);CHKERRQ(ierr);
  ierr = DMCircuitGetEdgeRange(circuitdm,&eStart,&eEnd);CHKERRQ(ierr);
  for (i = eStart; i < eEnd; i++) {
    ierr = DMCircuitAddComponent(circuitdm,i,componentkey[1],&pfdata.relations[i-eStart]);CHKERRQ(ierr);
  /* Set up DM for use */
  ierr = DMSetUp(circuitdm);CHKERRQ(ierr);
  if (!rank) {
    ierr = PetscFree(pfdata.links);CHKERRQ(ierr);
    ierr = PetscFree(pfdata.relations);CHKERRQ(ierr);
  ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
  if (size > 1) {
    DM distcircuitdm;
    /* Circuit partitioning and distribution of data */
    ierr = DMCircuitDistribute(circuitdm,&distcircuitdm);CHKERRQ(ierr);
    ierr = DMDestroy(&circuitdm);CHKERRQ(ierr);
    circuitdm = distcircuitdm;
  PetscLogStagePop();
  Vec X,F;
  ierr = DMCreateGlobalVector(circuitdm,&X);CHKERRQ(ierr);
  ierr = VecDuplicate(X,&F);CHKERRQ(ierr);
  Mat J;
  ierr = DMCreateMatrix(circuitdm,&J);CHKERRQ(ierr);
  ierr = MatSetOption(J,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);CHKERRQ(ierr);
  ierr = SetInitialValues(circuitdm,X,NULL);CHKERRQ(ierr);
  SNES snes;
  /* HOOK UP SOLVER */
  ierr = SNESCreate(PETSC_COMM_WORLD,&snes);CHKERRQ(ierr);
  ierr = SNESSetDM(snes,circuitdm);CHKERRQ(ierr);
  ierr = SNESSetFunction(snes,F,FormFunction,NULL);CHKERRQ(ierr);
  ierr = SNESSetJacobian(snes,J,J,FormJacobian,NULL);CHKERRQ(ierr);
  ierr = SNESSetFromOptions(snes);CHKERRQ(ierr);
  ierr = SNESSolve(snes,NULL,X);CHKERRQ(ierr);
  ierr = VecView(X,NULL);CHKERRQ(ierr);
  ierr = VecDestroy(&X);CHKERRQ(ierr);
  ierr = VecDestroy(&F);CHKERRQ(ierr);
  ierr = MatDestroy(&J);CHKERRQ(ierr);
  ierr = SNESDestroy(&snes);CHKERRQ(ierr);
  PetscFinalize();
  return 0;
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140214/8e4387e2/attachment-0001.pdf>
Type: application/x-bzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140214/8e4387e2/attachment-0001.bin>
