[petsc-users] Modeling a Network with DMPlex?
Abhyankar, Shrirang G. abhyshr at mcs.anl.gov
Fri Feb 14 13:48:54 CST 2014
Florian,
  Thanks for the example! I'll take a look at it and get back to you.
Shri
On 2/14/14 11:25 AM, "Florian Meier" <florian.meier at koalo.de> wrote:
>Ok, that was just a stupid typo.
>I have now build the first attempt of an example.
>I am sure that can be programmed in a much better way,
>so I would be very glad about any comment. What is your
>preferred review procedure?
>Greetings,
>Florian
>static char help[] = "This example demonstrates the DMCircuit interface
>for a radio network flow problem.\n\
>                      The available solver options are in the
>alohaoptions file.\n\
>                      The file links.txt contains the network
>description.\n\
>                      Run this program: mpiexec -n <n> ./PF\n					\
>                      mpiexec -n <n> ./PF -pfdata <filename>\n";
>This computes a greatly simplified model of a radio network.
>Each node in the network generates packets conforming to a poisson
>distribution (given rate R_gen).
>These packets are routed along fixed paths to a sink. When two packets
>are send at the same time,
>they are dropped. No channel sensing or retransmission takes place.
>Each active link (i.e. each radio link that will eventually transmit
>data) is modeled as a vertex.
>Between those vertices there exist two kinds of relations:
>A relation of type REL_INTERFERENCE(affected, source), implies that
>whenever the source link tries
>to send at the same time than the affected link, the packet will collide
>and is not received properly.
>A relation of type REL_INFLOW(affected, source) implies that each packet
>that is send via the source
>link and does not collide, adds up to the amount of packets send via the
>affected link.
>The overall rate of accessing a radio link i is
>R_access,i = R_gen,i + SUM_OVER_INFLOWS( R_success,j )
>The probability that no other link interfering with i accesses the
>channel at a given point in time is
>P_free,i = PRODUCT_OVER_INTERFERERS( 1 - R_access,j )
>Finally, the overall rate of successful transmissions over link i is
>R_success,i = R_access,i * P_free,i
>The input file is structured as follows:
>The first line contains L, the number of links, I, the number of
>interferences and F, the number of inflow relations.
>Then L lines follow with the packet generation rate for each link.
>The subsequent I lines describe the affected and the source link of the
>respective interference relation.
>The final F lines represent the inflow relations.
>#include <petsc.h>
>#include <petscdmcircuit.h>
>#include <fstream>
>#include <iostream>
>using namespace std;
>enum {
>  REL_INTERFERENCE,
>  REL_INFLOW
>enum {
>  VAR_ACCESS,
>  VAR_SUCCESS,
>  VAR_NVARS
>struct _p_LINKDATA{
>  PetscScalar 	packet_generation;
>typedef struct _p_LINKDATA *LINKDATA;
>struct _p_RELATIONDATA{
>  PetscInt      source;
>  PetscInt      affected;
>  PetscInt	type;
>typedef struct _p_RELATIONDATA *RELATIONDATA;
>typedef struct {
>  PetscInt    nlinks,nrelations; /* # of nodes,relations */
>  LINKDATA links;
>  RELATIONDATA relations;
>} PFDATA;
>PetscMPIInt rank;
>#undef __FUNCT__
>#define __FUNCT__ "FormFunction"
>PetscErrorCode FormFunction(SNES snes,Vec X, Vec F,void *appctx)
>  PetscErrorCode ierr;
>  DM             circuitdm;
>  Vec           localX,localF;
>  PetscInt      e;
>  PetscInt      v,vStart,vEnd,vaffected,vsource;
>  const PetscScalar *xarr;
>  PetscScalar   *farr;
>  PetscInt      offset,offsetsource,offsetlink,offsetrel;
>  DMCircuitComponentGenericDataType *arr;
>  PetscFunctionBegin;
>  ierr = SNESGetDM(snes,&circuitdm);CHKERRQ(ierr);
>  ierr = DMGetLocalVector(circuitdm,&localX);CHKERRQ(ierr);
>  ierr = DMGetLocalVector(circuitdm,&localF);CHKERRQ(ierr);
>  ierr = VecSet(F,0.0);CHKERRQ(ierr);
>  ierr =
>DMGlobalToLocalBegin(circuitdm,X,INSERT_VALUES,localX);CHKERRQ(ierr);
>  ierr =
>DMGlobalToLocalEnd(circuitdm,X,INSERT_VALUES,localX);CHKERRQ(ierr);
>  ierr =
>DMGlobalToLocalBegin(circuitdm,F,INSERT_VALUES,localF);CHKERRQ(ierr);
>  ierr =
>DMGlobalToLocalEnd(circuitdm,F,INSERT_VALUES,localF);CHKERRQ(ierr);
>  ierr = VecGetArrayRead(localX,&xarr);CHKERRQ(ierr);
>  ierr = VecGetArray(localF,&farr);CHKERRQ(ierr);
>  ierr = DMCircuitGetVertexRange(circuitdm,&vStart,&vEnd);CHKERRQ(ierr);
>  ierr = DMCircuitGetComponentDataArray(circuitdm,&arr);CHKERRQ(ierr);
>  for (v=vStart; v < vEnd; v++) {
>    PetscBool   ghostvtex;
>    ierr = DMCircuitIsGhostVertex(circuitdm,v,&ghostvtex);CHKERRQ(ierr);
>    if (ghostvtex) {
>      continue; // TODO is that ok?
>    PetscInt keyv;
>    ierr =
>DMCircuitGetComponentTypeOffset(circuitdm,v,0,&keyv,&offsetlink);CHKERRQ(i
>err);
>    LINKDATA link = (LINKDATA)(arr+offsetlink);
>    PetscScalar inflow = link->packet_generation;
>    PetscScalar Pfree = 1;
>    PetscInt nconnedges;
>    const PetscInt *connedges;
>    ierr =
>DMCircuitGetSupportingEdges(circuitdm,v,&nconnedges,&connedges);CHKERRQ(ie
>rr);
>    for (PetscInt i = 0; i < nconnedges; i++) {
>      e = connedges[i];
>      const PetscInt *cone;
>      ierr = DMCircuitGetConnectedNodes(circuitdm,e,&cone);CHKERRQ(ierr);
>      vaffected = cone[0];
>      vsource   = cone[1];
>      if (vaffected == v) {
>	PetscInt keye;
>        ierr =
>DMCircuitGetComponentTypeOffset(circuitdm,e,0,&keye,&offsetrel);CHKERRQ(ie
>rr);
>        RELATIONDATA relation = (RELATIONDATA)(arr+offsetrel);
>        ierr =
>DMCircuitGetVariableOffset(circuitdm,vsource,&offsetsource);CHKERRQ(ierr);
>        switch (relation->type) {
>          case REL_INTERFERENCE:
>            Pfree *= 1 - xarr[offsetsource+VAR_ACCESS];
>            break;
>          case REL_INFLOW:
>            inflow += xarr[offsetsource+VAR_SUCCESS];
>            break;
>    ierr = DMCircuitGetVariableOffset(circuitdm,v,&offset);CHKERRQ(ierr);
>    farr[offset+VAR_ACCESS] = inflow - xarr[offset+VAR_ACCESS];
>    farr[offset+VAR_SUCCESS] = xarr[offset+VAR_ACCESS]*Pfree -
>xarr[offset+VAR_SUCCESS];
>  ierr = VecRestoreArrayRead(localX,&xarr);CHKERRQ(ierr);
>  ierr = VecRestoreArray(localF,&farr);CHKERRQ(ierr);
>  ierr = DMRestoreLocalVector(circuitdm,&localX);CHKERRQ(ierr);
>  ierr =
>DMLocalToGlobalBegin(circuitdm,localF,ADD_VALUES,F);CHKERRQ(ierr);
>  ierr = DMLocalToGlobalEnd(circuitdm,localF,ADD_VALUES,F);CHKERRQ(ierr);
>  ierr = DMRestoreLocalVector(circuitdm,&localF);CHKERRQ(ierr);
>  PetscFunctionReturn(0);
>#undef __FUNCT__
>#define __FUNCT__ "FormJacobian"
>PetscErrorCode FormJacobian(SNES snes,Vec X, Mat *J,Mat
>*Jpre,MatStructure *flg,void *appctx)
>  DM            circuitdm;
>  Vec           localX;
>  PetscInt      e;
>  PetscInt      offsetrel;
>  PetscInt      row[1],col[1];
>  PetscScalar   values[1];
>  PetscFunctionBegin;
>  *flg = SAME_NONZERO_PATTERN; // TODO ok for this problem?
>  ierr = MatZeroEntries(*J);CHKERRQ(ierr);
>  ierr =
>  ierr =
>    PetscInt    offset,goffset,offsetsource,goffsetsource;
>    if (ghostvtex) {
>    ierr =
>DMCircuitGetVariableGlobalOffset(circuitdm,v,&goffset);CHKERRQ(ierr);
>    // TODO some derivatives are constant, can this be handled in
>SetInitialValues?
>    // TODO can I combine these two MatSetValues?
>    row[0] = goffset+VAR_ACCESS;
>    col[0] = goffset+VAR_ACCESS;
>    values[0] = -1.0;
>    ierr = MatSetValues(*J,1,row,1,col,values,ADD_VALUES);CHKERRQ(ierr);
>    row[0] = goffset+VAR_SUCCESS;
>    col[0] = goffset+VAR_SUCCESS;
>    values[0] = -1.0;
>    // Calculate Pfree
>    // TODO Pfree was already calculated in FromFunction, can I access
>that?
>    ierr =
>rr);
>      e = connedges[i];
>      vsource   = cone[1];
>	PetscInt keye;
>        ierr =
>rr);
>        ierr =
>        if (relation->type == REL_INTERFERENCE) {
>    values[0] = Pfree;
>    // Set the derivatives
>    PetscScalar inflow = xarr[offset+VAR_ACCESS];
>      e = connedges[i];
>      vsource   = cone[1];
>	PetscInt keye;
>        ierr =
>rr);
>        ierr =
>        ierr =
>DMCircuitGetVariableGlobalOffset(circuitdm,vsource,&goffsetsource);CHKERRQ
>(ierr);
>            // TODO Ok to set the entries one by one or is there a better
>way?
>            col[0] = goffsetsource+VAR_ACCESS;
>            values[0] = -inflow*(Pfree/(1-xarr[offsetsource+VAR_ACCESS]));
>            ierr =
>            break;
>          case REL_INFLOW:
>            col[0] = goffsetsource+VAR_SUCCESS;
>            values[0] = 1.0;
>            ierr =
>            break;
>  ierr = MatAssemblyBegin(*J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>  ierr = MatAssemblyEnd(*J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>#undef __FUNCT__
>#define __FUNCT__ "SetInitialValues"
>PetscErrorCode SetInitialValues(DM circuitdm,Vec X,void *appctx)
>  PetscInt       v, vStart, vEnd;
>  Vec            localX;
>  PetscScalar    *xarr;
>  PetscFunctionBegin;
>  ierr = VecSet(X,0.0);CHKERRQ(ierr);
>  ierr =
>  ierr =
>  ierr = VecGetArray(localX,&xarr);CHKERRQ(ierr);
>  for (v = vStart; v < vEnd; v++) {
>    if (ghostvtex) {
>    PetscInt offsetlink, offset;
>    PetscInt keyv;
>    ierr =
>err);
>    xarr[offset+VAR_ACCESS] = link->packet_generation;
>    xarr[offset+VAR_SUCCESS] = link->packet_generation;
>  ierr = VecRestoreArray(localX,&xarr);CHKERRQ(ierr);
>  ierr =
>DMLocalToGlobalBegin(circuitdm,localX,ADD_VALUES,X);CHKERRQ(ierr);
>  ierr = DMLocalToGlobalEnd(circuitdm,localX,ADD_VALUES,X);CHKERRQ(ierr);
>#undef __FUNCT__
>#define __FUNCT__ "main"
>int main(int argc,char ** argv)
>  string	       inputFile = "links.txt";
>  PFDATA               pfdata;
>  PetscInt             numEdges=0,numVertices=0;
>  int                  *edges = NULL;
>  PetscInt             i;
>  DM                   circuitdm;
>  PetscInt             componentkey[2];
>  PetscLogStage        stage1,stage2;
>  PetscInt             size;
>  PetscInitialize(&argc,&argv,"alohaoptions",help);
>  ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
>  /* Create an empty circuit object */
>  ierr = DMCircuitCreate(PETSC_COMM_WORLD,&circuitdm);CHKERRQ(ierr);
>  /* Register the components in the circuit */
>  ierr = DMCircuitRegisterComponent(circuitdm,"linkstruct",sizeof(struct
>_p_LINKDATA),&componentkey[0]);CHKERRQ(ierr);
>  ierr =
>DMCircuitRegisterComponent(circuitdm,"relationstruct",sizeof(struct
>_p_RELATIONDATA),&componentkey[1]);CHKERRQ(ierr);
>  ierr = PetscLogStageRegister("Read Data",&stage1);CHKERRQ(ierr);
>  PetscLogStagePush(stage1);
>  /* READ THE DATA */
>  if (!rank) {
>    /* Only rank 0 reads the data */
>    ifstream linksF(inputFile.c_str());
>    int ninterferences, ninflows;
>    linksF >> pfdata.nlinks >> ninterferences >> ninflows;
>    numVertices = pfdata.nlinks;
>    numEdges = pfdata.nrelations = ninterferences + ninflows;
>    ierr = PetscMalloc1(pfdata.nlinks,&pfdata.links);CHKERRQ(ierr);
>    ierr =
>PetscMalloc1(pfdata.nrelations,&pfdata.relations);CHKERRQ(ierr);
>    for(int i = 0; i < numVertices; i++) {
>      linksF >> pfdata.links[i].packet_generation;
>    ierr = PetscMalloc1(2*numEdges,&edges);CHKERRQ(ierr);
>    for(int i = 0; i < numEdges; i++) {
>      linksF >> pfdata.relations[i].affected >>
>pfdata.relations[i].source;
>      pfdata.relations[i].type = (i < ninterferences) ? REL_INTERFERENCE
>: REL_INFLOW;
>      edges[2*i] = pfdata.relations[i].affected;
>      edges[2*i+1] = pfdata.relations[i].source;
>    linksF.close();
>  PetscLogStagePop();
>  MPI_Barrier(PETSC_COMM_WORLD);
>  ierr = PetscLogStageRegister("Create circuit",&stage2);CHKERRQ(ierr);
>  PetscLogStagePush(stage2);
>  /* Set number of nodes/edges */
>  ierr =
>DMCircuitSetSizes(circuitdm,numVertices,numEdges,PETSC_DETERMINE,PETSC_DET
>ERMINE);CHKERRQ(ierr);
>  /* Add edge connectivity */
>  ierr = DMCircuitSetEdgeList(circuitdm,edges);CHKERRQ(ierr);
>  /* Set up the circuit layout */
>  ierr = DMCircuitLayoutSetUp(circuitdm);CHKERRQ(ierr);
>  if (!rank) {
>    ierr = PetscFree(edges);CHKERRQ(ierr);
>  /* Add circuit components */
>  PetscInt eStart, eEnd, vStart, vEnd;
>  for (i = vStart; i < vEnd; i++) {
>    ierr =
>DMCircuitAddComponent(circuitdm,i,componentkey[0],&pfdata.links[i-vStart])
>;CHKERRQ(ierr);
>    /* Add number of variables */
>    ierr = DMCircuitAddNumVariables(circuitdm,i,VAR_NVARS);CHKERRQ(ierr);
>  ierr = DMCircuitGetEdgeRange(circuitdm,&eStart,&eEnd);CHKERRQ(ierr);
>  for (i = eStart; i < eEnd; i++) {
>    ierr =
>DMCircuitAddComponent(circuitdm,i,componentkey[1],&pfdata.relations[i-eSta
>rt]);CHKERRQ(ierr);
>  /* Set up DM for use */
>  ierr = DMSetUp(circuitdm);CHKERRQ(ierr);
>  if (!rank) {
>    ierr = PetscFree(pfdata.links);CHKERRQ(ierr);
>    ierr = PetscFree(pfdata.relations);CHKERRQ(ierr);
>  ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
>  if (size > 1) {
>    DM distcircuitdm;
>    /* Circuit partitioning and distribution of data */
>    ierr = DMCircuitDistribute(circuitdm,&distcircuitdm);CHKERRQ(ierr);
>    ierr = DMDestroy(&circuitdm);CHKERRQ(ierr);
>    circuitdm = distcircuitdm;
>  PetscLogStagePop();
>  Vec X,F;
>  ierr = DMCreateGlobalVector(circuitdm,&X);CHKERRQ(ierr);
>  ierr = VecDuplicate(X,&F);CHKERRQ(ierr);
>  Mat J;
>  ierr = DMCreateMatrix(circuitdm,&J);CHKERRQ(ierr);
>  ierr =
>MatSetOption(J,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);CHKERRQ(ierr);
>  ierr = SetInitialValues(circuitdm,X,NULL);CHKERRQ(ierr);
>  SNES snes;
>  /* HOOK UP SOLVER */
>  ierr = SNESCreate(PETSC_COMM_WORLD,&snes);CHKERRQ(ierr);
>  ierr = SNESSetDM(snes,circuitdm);CHKERRQ(ierr);
>  ierr = SNESSetFunction(snes,F,FormFunction,NULL);CHKERRQ(ierr);
>  ierr = SNESSetJacobian(snes,J,J,FormJacobian,NULL);CHKERRQ(ierr);
>  ierr = SNESSetFromOptions(snes);CHKERRQ(ierr);
>  ierr = SNESSolve(snes,NULL,X);CHKERRQ(ierr);
>  ierr = VecView(X,NULL);CHKERRQ(ierr);
>  ierr = VecDestroy(&X);CHKERRQ(ierr);
>  ierr = VecDestroy(&F);CHKERRQ(ierr);
>  ierr = MatDestroy(&J);CHKERRQ(ierr);
>  ierr = SNESDestroy(&snes);CHKERRQ(ierr);
>  PetscFinalize();
>  return 0;
