[petsc-users] How can PETSc configure with MSMPI
Jed Brown jed at jedbrown.org
Sun Feb 2 13:50:16 CST 2014
Satish Balay <balay at mcs.anl.gov> writes:
> We are not bundling it. We are using it for our nightly tests.
But are we recommending that people use it?
> Also the comparision to using petsc doesn't apply here. PETSc changes
> API with every release. As long as we say we support MPI-2 - such
> things shold work. In that sense - its good to have some testsuites
> with such old stuff.
Yes, testing in private is different from recommending that people use
it.
> Supporting windows is a mess. There is no single 'easily' supported
> thingy here.
> Sure we should probably also have a different test infracture with
> latest compilers, latest supported mpi etc.. But that doesn't mean
> testing with alternatives does not have value..
> 'gcc is now at 4.8 - so we shoud not support older versions of gcc...'
It would be different if we got a bug report with the latest compiler
and we told people to use an old compiler.  (Some DOE people have gotten
mileage out of that tactic, but we find it abhorrent.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140202/3f233d64/attachment.pgp>
