[petsc-users] with hdf5 dir
Wed Dec 17 09:36:16 CST 2014
On Wed, Dec 17, 2014 at 9:30 AM, paul zhang <paulhuaizhang at gmail.com> wrote:
> Attached.
You HDF5 installation is incomplete. It is missing
  libhdf5_hl.a
     Matt
> Thanks,
> Paul
> Huaibao (Paul) Zhang
> *Gas Surface Interactions Lab*
> Department of Mechanical Engineering
> University of Kentucky,
> Lexington,
> KY, 40506-0503
> *Office*: 216 Ralph G. Anderson Building
> *Web*:gsil.engineering.uky.edu
> On Wed, Dec 17, 2014 at 10:19 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Dec 17, 2014 at 8:58 AM, paul zhang <paulhuaizhang at gmail.com>
>> wrote:
>>> Hi All,
>>> I attempted to include hdf5 dir in my configuration, but failed.
>>> --with-hdf5-dir=$HDF5PATH
>>> I tried HDF5PATH=/share/cluster/SLES9/x86_64/apps/hdf5/1.8.3, but it
>>> shows
>> When you get a failure like this, you have to send configure.log
>>   Thanks,
>>      Matt
>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>> for details):
>>> --with-hdf5-dir=/share/cluster/SLES9/x86_64/apps/hdf5/1.8.3 did not work
>>> As I run $module show hdf5, I got
>>> */usr/share/Modules/modulefiles/hdf5/1.8.3/icc/default:*
>>> *module-whatis load HDF5 environment *
>>> *prepend-path PATH /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/bin *
>>> *append-path LD_LIBRARY_PATH
>>> /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/lib *
>>> *prepend-path MANPATH
>>> /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/share/man *
>>> *setenv HDF_INCL
>>> /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/include *
>>> What is my HDF5PATH?
>>> Thanks,
>>> Paul
>>> Lexington,
>>> KY, 40506-0503
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141217/678d48f4/attachment.html>
