[petsc-users] with hdf5 dir
paul zhang paulhuaizhang at gmail.com
Wed Dec 17 09:30:33 CST 2014
Attached.
Paul
Huaibao (Paul) Zhang
*Gas Surface Interactions Lab*
Department of Mechanical Engineering
University of Kentucky,
Lexington,
KY, 40506-0503
*Office*: 216 Ralph G. Anderson Building
*Web*:gsil.engineering.uky.edu
On Wed, Dec 17, 2014 at 10:19 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Dec 17, 2014 at 8:58 AM, paul zhang <paulhuaizhang at gmail.com>
> wrote:
>> Hi All,
>> I attempted to include hdf5 dir in my configuration, but failed.
>> --with-hdf5-dir=$HDF5PATH
>> I tried HDF5PATH=/share/cluster/SLES9/x86_64/apps/hdf5/1.8.3, but it
>> shows
> When you get a failure like this, you have to send configure.log
>   Thanks,
>      Matt
>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>> details):
>> --with-hdf5-dir=/share/cluster/SLES9/x86_64/apps/hdf5/1.8.3 did not work
>> As I run $module show hdf5, I got
>> */usr/share/Modules/modulefiles/hdf5/1.8.3/icc/default:*
>> *module-whatis load HDF5 environment *
>> *prepend-path PATH /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/bin *
>> *append-path LD_LIBRARY_PATH
>> /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/lib *
>> *prepend-path MANPATH
>> /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/share/man *
>> *setenv HDF_INCL /share/cluster/SLES9/x86_64/apps/hdf5/1.8.3/icc/include *
>> What is my HDF5PATH?
>> Thanks,
>> Paul
>> Lexington,
>> KY, 40506-0503
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141217/bf51d0a2/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141217/bf51d0a2/attachment-0001.bin>
