[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Ashwin Srinath ashwinsrnth at gmail.com
Fri Aug 29 10:50:24 CDT 2014
Satish,
Thank you, you're right - the issue is with nvcc. Thanks for your time!
Ashwin
On Fri, Aug 29, 2014 at 11:43 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> The primary issue here is - 'nvcc' is broken as installed.
> So you should be able to test it witout petsc.
> Once you have it working on a test code [without petsc] - you can try
> running configure again.
> Satish
> On Fri, 29 Aug 2014, Ashwin Srinath wrote:
> > I'm running code on a university cluster. I'll find out where those
> > variables
> > are being set, and let you know if something works. Thanks!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/895b712b/attachment.html>
