[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Fri Aug 29 10:52:05 CDT 2014
https://bitbucket.org/petsc/petsc/commits/6e4329e6b
+    if language == 'CUDA': # do not check CUDA linker since it is never used (and is broken on Mac with -m64)
+      self.popLanguage()
+      return
But we use self.checkRun() in configure - which is using nvcc as linker.
Perhaps this code should be removed?  [and whatever issue was on Mac -
should be fixed in a better way..]
Or somehow check and set clinker as cudalinker?
satish
On Fri, 29 Aug 2014, Satish Balay wrote:
> The primary issue here is - 'nvcc' is broken as installed.
> So you should be able to test it witout petsc.
> Once you have it working on a test code [without petsc] - you can try
> running configure again.
> Satish
> On Fri, 29 Aug 2014, Ashwin Srinath wrote:
> > I'm running code on a university cluster. I'll find out where those
> > variables
> > are being set, and let you know if something works. Thanks!
