[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Fri Aug 29 10:43:04 CDT 2014
The primary issue here is - 'nvcc' is broken as installed.
So you should be able to test it witout petsc.
Once you have it working on a test code [without petsc] - you can try
running configure again.
Satish
On Fri, 29 Aug 2014, Ashwin Srinath wrote:
> I'm running code on a university cluster. I'll find out where those
> variables
> are being set, and let you know if something works. Thanks!
