[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Fri Aug 29 09:31:57 CDT 2014
On Fri, Aug 29, 2014 at 9:35 AM, Dominic Meiser <dmeiser at txcorp.com> wrote:
>  On 08/29/2014 08:08 AM, Matthew Knepley wrote:
>  On Fri, Aug 29, 2014 at 8:35 AM, Christophe Ortiz <
> christophe.ortiz at ciemat.es> wrote:
>> Sorry about that.
>>  Please find in attachment the configure.log file. Hope it will help you
>> find the error.
>  Here is the problem:
>  Possible ERROR while running preprocessor: nvcc warning : The
> 'compute_10' and 'sm_10' architectures are deprecated, and may be removed
> in a future release.
> error message = {nvcc warning : The 'compute_10' and 'sm_10' architectures
> are deprecated, and may be removed in a future release.
>  meaning the nvcc compiler does not "work" as provided. Here is a
> workaround:
>       --with-cudac='nvcc --arch=sm_35'
>  Dominic, I think that thrust.py should depend on cuda.py. Do you know
> why it does not?
> In principle you are right, thrust.py should depend on cuda.py.
> However, in my opinion, thrust.py should go away as a separate package
> altogether. Thrust is shipped as part of any recent version of the cuda
> toolkit (I forget since which version, Paul might know) and it's always
> installed in $CUDA_TOOLKIT_ROOT/include/thrust. Thus we can automatically
> deduct the thrust location from the cuda location. Thrust should be
> considered part of cuda.
That does not mean the configure modules should be organized that way.
Thrust is a package included in CUDA, thus
it should have an independent module, but depend on the CUDA module.
   Matt
> Cheers,
> Dominic
>    Thanks,
>        Matt
>>  Christophe
>> CIEMAT
>> Laboratorio Nacional de Fusión por Confinamiento Magnético
>> Unidad de Materiales
>> Edificio 2 - Planta 0 - Despacho 28m
>> Avenida Complutense 40,
>> 28040 Madrid, Spain
>> Tel: +34 91496 2582 <%2B34%2091496%202582>
>> Fax: +34 91346 6442 <%2B34%2091346%206442>
>> Q
>> Por favor, piense en el medio ambiente antes de imprimir este mensaje.
>> Please consider the environment before printing this email.
>> On Fri, Aug 29, 2014 at 3:28 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> Always attach configure.log or we cannot see what went wrong.
>>>      Matt
>>> On Fri, Aug 29, 2014 at 2:35 AM, Christophe Ortiz <
>>>>   Hi Dominic and Paul,
>>>>  Thanks for your answers. Unfortunately, it did not work. Same error
>>>> message related to the thrust directory:
>>>>  ./configure --with-x=1 --with-mpi=0 --with-cc=icc --with-cxx=icpc
>>>> --with-clanguage=cxx --with-fc=ifort --with-cuda=1
>>>> --with-cuda-dir=/usr/local/cuda-6.0 --with-cuda-arch=sm_35 --with-thrust=1
>>>> --with-thrust-dir=/usr/local/cuda-6.0/include --with-cusp=1
>>>> --with-cusp-dir=/usr/local/cuda-6.0/include --with-debugging=1
>>>> --with-scalar-type=real --with-precision=double --download-fblaslapack
>>>>              Configuring PETSc to compile on your system
>>>> TESTING: checkInclude from
>>>> config.headers(config/BuildSystem/config/headers.py:86)
>>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>>> for details):
>>>> --with-thrust-dir=/usr/local/cuda-6.0/include did not work
>>>>  I do not see what else to do...I have a standard CUDA installation
>>>> that came with thrust.
>>>> I am using ubuntu 12.04, I do not know if that could help.
>>>> I tried with PETSc 3.4.1 and 3.5.1. Same problem.
>>>>  Christophe
>>>>> Message: 3
>>>>> Date: Thu, 28 Aug 2014 08:38:12 -0600
>>>>> From: Dominic Meiser <dmeiser at txcorp.com>
>>>>> To: petsc-users at mcs.anl.gov
>>>>> Subject: Re: [petsc-users] Unable to configure PETSc with CUDA:
>>>>> Message-ID: <53FF3ED4.1090002 at txcorp.com>
>>>>> Content-Type: text/plain; charset=UTF-8; format=flowed
>>>>> Can you try configuring with
>>>>> I.e. omit the 'thrust' at the end of the path. Probably you'll need the
>>>>> same fix with cusp:
>>>>> Cheers,
>>>>> Dominic
>>>>> On 08/28/2014 08:13 AM, Christophe Ortiz wrote:
>>>>> > Hi all,
>>>>> > I have implemented a problem of coupled diffusion equations in 1D
>>>>> > using PETSc. I was able to configure PETSC with and without MPI. The
>>>>> > code runs well in both cases.
>>>>> > Now I would like to test CUDA but I am unable to configure it. I get
>>>>> > an error message related to thrust directory.
>>>>> > The options I use to configure are the following:
>>>>> > --with-cudac=/usr/local/cuda/bin/nvcc --with-thrust=1
>>>>> > --with-thrust-dir=/usr/local/cuda-6.0/include/thrust --with-cusp=1
>>>>> > --with-cusp-dir=/usr/local/cuda-6.0/include/cusp
>>>>> > --download-txpetscgpu=1 --with-debugging=1 --with-scalar-type=real
>>>>> > --with-precision=double --download-f-blas-lapack
>>>>> > The error message I get is:
>>>>> > for details):
>>>>> > --with-thrust-dir=/usr/local/cuda-6.0/include/thrust did not work
>>>>> > Did I miss something ?
>>>>> > My GPU is a GeForce Titan Black and I am using CUDA 6.0.
>>>>> > Many thanks in advance for your help.
>>>>> > Christophe
>>>>> Dominic Meiser
>>>>> Tech-X Corporation
>>>>> 5621 Arapahoe Avenue
>>>>> Boulder, CO 80303
>>>>> USA
>>>>> Telephone: 303-996-2036
>>>>> Fax: 303-448-7756
>>>>> www.txcorp.com
>>>>> Message: 4
>>>>> Date: Thu, 28 Aug 2014 08:30:40 -0600
>>>>> From: Paul Mullowney <paulmullowney at gmail.com>
>>>>> To: Dominic Meiser <dmeiser at txcorp.com>
>>>>> Cc: petsc-users at mcs.anl.gov
>>>>> Message-ID:
>>>>>         <CAMJ8fwroFUxG-rpbMpaJEw=
>>>>> 0aQdyNm9NMxMzsxWVGGPWZqhGCQ at mail.gmail.com>
>>>>> Content-Type: text/plain; charset="utf-8"
>>>>> Also, get rid of --download-txpetscgpu=1. That doesn't exist anymore.
>>>>> -Paul
>>>>> On Thu, Aug 28, 2014 at 8:38 AM, Dominic Meiser <dmeiser at txcorp.com>
>>>>> the
>>>>> > same fix with cusp:
>>>>> > Cheers,
>>>>> > Dominic
>>>>> >> Hi all,
>>>>> using
>>>>> >> PETSc. I was able to configure PETSC with and without MPI. The code
>>>>> runs
>>>>> >> well in both cases.
>>>>> get an
>>>>> >> --with-debugging=1 --with-scalar-type=real --with-precision=double
>>>>> >> TESTING: checkInclude from config.headers(config/
>>>>> >> BuildSystem/config/headers.py:86) ******************************
>>>>> configure.log for
>>>>> >> details):
>>>>> >> Christophe
>>>>> > Dominic Meiser
>>>>> > Tech-X Corporation
>>>>> > Boulder, CO 80303
>>>>> > USA
>>>>> > Fax: 303-448-7756
>>>>> > www.txcorp.com
>>>>> -------------- next part --------------
>>>>> An HTML attachment was scrubbed...
>>>>> URL: <
>>>>> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140828/70c223ee/attachment-0001.html
>>>>> _______________________________________________
>>>>> petsc-users mailing list
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>>>>> End of petsc-users Digest, Vol 68, Issue 63
>>>>> Confidencialidad:
>>>>> Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su
>>>>> destinatario y puede contener información privilegiada o confidencial. Si
>>>>> no es vd. el destinatario indicado, queda notificado de que la utilización,
>>>>> divulgación y/o copia sin autorización está prohibida en virtud de la
>>>>> legislación vigente. Si ha recibido este mensaje por error, le rogamos que
>>>>> nos lo comunique inmediatamente respondiendo al mensaje y proceda a su
>>>>> destrucción.
>>>>> Disclaimer:
>>>>> This message and its attached files is intended exclusively for its
>>>>> recipients and may contain confidential information. If you received this
>>>>> e-mail in error you are hereby notified that any dissemination, copy or
>>>>> disclosure of this communication is strictly prohibited and may be
>>>>> unlawful. In this case, please notify us by a reply and delete this email
>>>>> and its contents immediately.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> Dominic Meiser
> Tech-X Corporation
> Boulder, CO 80303
> USA
> Fax: 303-448-7756www.txcorp.com
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/2ccd5508/attachment-0001.html>
