[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Dominic Meiser dmeiser at txcorp.com
Fri Aug 29 09:35:57 CDT 2014
On 08/29/2014 08:08 AM, Matthew Knepley wrote:
> On Fri, Aug 29, 2014 at 8:35 AM, Christophe Ortiz
> <christophe.ortiz at ciemat.es <mailto:christophe.ortiz at ciemat.es>> wrote:
>     Sorry about that.
>     Please find in attachment the configure.log file. Hope it will
>     help you find the error.
> Here is the problem:
> Possible ERROR while running preprocessor: nvcc warning : The
> 'compute_10' and 'sm_10' architectures are deprecated, and may be
> removed in a future release.
> error message = {nvcc warning : The 'compute_10' and 'sm_10'
> architectures are deprecated, and may be removed in a future release.
> meaning the nvcc compiler does not "work" as provided. Here is a
> workaround:
>      --with-cudac='nvcc --arch=sm_35'
> Dominic, I think that thrust.py should depend on cuda.py. Do you know
> why it does not?
In principle you are right, thrust.py should depend on cuda.py.
However, in my opinion, thrust.py should go away as a separate package
altogether. Thrust is shipped as part of any recent version of the cuda
toolkit (I forget since which version, Paul might know) and it's always
installed in $CUDA_TOOLKIT_ROOT/include/thrust. Thus we can
automatically deduct the thrust location from the cuda location. Thrust
should be considered part of cuda.
Cheers,
Dominic
>   Thanks,
>       Matt
>     Christophe
>     CIEMAT
>     Laboratorio Nacional de Fusión por Confinamiento Magnético
>     Unidad de Materiales
>     Edificio 2 - Planta 0 - Despacho 28m
>     Avenida Complutense 40,
>     28040 Madrid, Spain
>     Tel: +34 91496 2582 <tel:%2B34%2091496%202582>
>     Fax: +34 91346 6442 <tel:%2B34%2091346%206442>
>     Q
>     Por favor, piense en el medio ambiente antes de imprimir este
>     mensaje.
>     Please consider the environment before printing this email.
>     On Fri, Aug 29, 2014 at 3:28 PM, Matthew Knepley
>     <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>         Always attach configure.log or we cannot see what went wrong.
>             Matt
>         On Fri, Aug 29, 2014 at 2:35 AM, Christophe Ortiz
>             Hi Dominic and Paul,
>             Thanks for your answers. Unfortunately, it did not work.
>             Same error message related to the thrust directory:
>             ./configure --with-x=1 --with-mpi=0 --with-cc=icc
>             --with-cxx=icpc --with-clanguage=cxx --with-fc=ifort
>             --with-cuda=1 --with-cuda-dir=/usr/local/cuda-6.0
>             --with-cuda-arch=sm_35 --with-thrust=1
>             --with-thrust-dir=/usr/local/cuda-6.0/include
>             --with-cusp=1 --with-cusp-dir=/usr/local/cuda-6.0/include
>             --with-debugging=1 --with-scalar-type=real
>             --with-precision=double --download-fblaslapack
>                          Configuring PETSc to compile on your system
>             TESTING: checkInclude from
>             config.headers(config/BuildSystem/config/headers.py:86)
>                      UNABLE to CONFIGURE with GIVEN OPTIONS    (see
>             configure.log for details):
>             --with-thrust-dir=/usr/local/cuda-6.0/include did not work
>             I do not see what else to do...I have a standard CUDA
>             installation that came with thrust.
>             I am using ubuntu 12.04, I do not know if that could help.
>             I tried with PETSc 3.4.1 and 3.5.1. Same problem.
>             Christophe
>                 Message: 3
>                 Date: Thu, 28 Aug 2014 08:38:12 -0600
>                 From: Dominic Meiser <dmeiser at txcorp.com
>                 <mailto:dmeiser at txcorp.com>>
>                 To: petsc-users at mcs.anl.gov
>                 <mailto:petsc-users at mcs.anl.gov>
>                 Subject: Re: [petsc-users] Unable to configure PETSc
>                 with CUDA:
>                 Message-ID: <53FF3ED4.1090002 at txcorp.com
>                 <mailto:53FF3ED4.1090002 at txcorp.com>>
>                 Content-Type: text/plain; charset=UTF-8; format=flowed
>                 Can you try configuring with
>                 I.e. omit the 'thrust' at the end of the path.
>                 Probably you'll need the
>                 same fix with cusp:
>                 Cheers,
>                 Dominic
>                 On 08/28/2014 08:13 AM, Christophe Ortiz wrote:
>                 > Hi all,
>                 > I have implemented a problem of coupled diffusion
>                 equations in 1D
>                 > using PETSc. I was able to configure PETSC with and
>                 without MPI. The
>                 > code runs well in both cases.
>                 > Now I would like to test CUDA but I am unable to
>                 configure it. I get
>                 > an error message related to thrust directory.
>                 > The options I use to configure are the following:
>                 > --with-x=1 --with-mpi=0 --with-cc=icc --with-cxx=icpc
>                 > --with-clanguage=cxx --with-fc=ifort --with-cuda=1
>                 > --with-cudac=/usr/local/cuda/bin/nvcc --with-thrust=1
>                 > --with-thrust-dir=/usr/local/cuda-6.0/include/thrust
>                 --with-cusp=1
>                 > --with-cusp-dir=/usr/local/cuda-6.0/include/cusp
>                 > --download-txpetscgpu=1 --with-debugging=1
>                 > --with-precision=double --download-f-blas-lapack
>                 > The error message I get is:
>                 (see configure.log
>                 > for details):
>                 did not work
>                 > Did I miss something ?
>                 > My GPU is a GeForce Titan Black and I am using CUDA 6.0.
>                 > Many thanks in advance for your help.
>                 > Christophe
>                 Dominic Meiser
>                 Tech-X Corporation
>                 5621 Arapahoe Avenue
>                 Boulder, CO 80303
>                 USA
>                 Telephone: 303-996-2036 <tel:303-996-2036>
>                 Fax: 303-448-7756 <tel:303-448-7756>
>                 www.txcorp.com <http://www.txcorp.com>
>                 Message: 4
>                 Date: Thu, 28 Aug 2014 08:30:40 -0600
>                 From: Paul Mullowney <paulmullowney at gmail.com
>                 <mailto:paulmullowney at gmail.com>>
>                 To: Dominic Meiser <dmeiser at txcorp.com
>                 Cc: petsc-users at mcs.anl.gov
>                 with CUDA:
>                 Message-ID:
>                 <CAMJ8fwroFUxG-rpbMpaJEw=0aQdyNm9NMxMzsxWVGGPWZqhGCQ at mail.gmail.com
>                 <mailto:0aQdyNm9NMxMzsxWVGGPWZqhGCQ at mail.gmail.com>>
>                 Content-Type: text/plain; charset="utf-8"
>                 Also, get rid of --download-txpetscgpu=1. That doesn't
>                 exist anymore.
>                 -Paul
>                 On Thu, Aug 28, 2014 at 8:38 AM, Dominic Meiser
>                 <dmeiser at txcorp.com <mailto:dmeiser at txcorp.com>> wrote:
>                 > same fix with cusp:
>                 > Cheers,
>                 > Dominic
>                 >> Hi all,
>                 equations in 1D using
>                 without MPI. The code runs
>                 >> well in both cases.
>                 configure it. I get an
>                 --with-cusp=1
>                 system
>                 >> TESTING: checkInclude from config.headers(config/
>                 (see configure.log for
>                 >> details):
>                 did not work
>                 6.0.
>                 >> Christophe
>                 > Dominic Meiser
>                 > Tech-X Corporation
>                 > Boulder, CO 80303
>                 > USA
>                 -------------- next part --------------
>                 An HTML attachment was scrubbed...
>                 URL:
>                 <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140828/70c223ee/attachment-0001.html>
>                 _______________________________________________
>                 petsc-users mailing list
>                 petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
>                 https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>                 End of petsc-users Digest, Vol 68, Issue 63
>                 Confidencialidad:
>                 Este mensaje y sus ficheros adjuntos se dirige
>                 exclusivamente a su destinatario y puede contener
>                 información privilegiada o confidencial. Si no es vd.
>                 el destinatario indicado, queda notificado de que la
>                 utilización, divulgación y/o copia sin autorización
>                 está prohibida en virtud de la legislación vigente. Si
>                 ha recibido este mensaje por error, le rogamos que nos
>                 lo comunique inmediatamente respondiendo al mensaje y
>                 proceda a su destrucción.
>                 Disclaimer:
>                 This message and its attached files is intended
>                 exclusively for its recipients and may contain
>                 confidential information. If you received this e-mail
>                 in error you are hereby notified that any
>                 dissemination, copy or disclosure of this
>                 communication is strictly prohibited and may be
>                 unlawful. In this case, please notify us by a reply
>                 and delete this email and its contents immediately.
>         What most experimenters take for granted before they begin
>         their experiments is infinitely more interesting than any
>         results to which their experiments lead.
>         -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
Dominic Meiser
Tech-X Corporation
Boulder, CO 80303
USA
Fax: 303-448-7756
www.txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/c29ee488/attachment-0001.html>
