[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Christophe Ortiz christophe.ortiz at ciemat.es
Fri Aug 29 02:35:22 CDT 2014
Hi Dominic and Paul,
Thanks for your answers. Unfortunately, it did not work. Same error message
related to the thrust directory:
./configure --with-x=1 --with-mpi=0 --with-cc=icc --with-cxx=icpc
--with-clanguage=cxx --with-fc=ifort --with-cuda=1
--with-cuda-dir=/usr/local/cuda-6.0 --with-cuda-arch=sm_35 --with-thrust=1
--with-thrust-dir=/usr/local/cuda-6.0/include --with-cusp=1
--with-cusp-dir=/usr/local/cuda-6.0/include --with-debugging=1
--with-scalar-type=real --with-precision=double --download-fblaslapack
             Configuring PETSc to compile on your system
TESTING: checkInclude from
config.headers(config/BuildSystem/config/headers.py:86)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
--with-thrust-dir=/usr/local/cuda-6.0/include did not work
I do not see what else to do...I have a standard CUDA installation that
came with thrust.
I am using ubuntu 12.04, I do not know if that could help.
I tried with PETSc 3.4.1 and 3.5.1. Same problem.
Christophe
> Message: 3
> Date: Thu, 28 Aug 2014 08:38:12 -0600
> From: Dominic Meiser <dmeiser at txcorp.com>
> To: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] Unable to configure PETSc with CUDA:
> Message-ID: <53FF3ED4.1090002 at txcorp.com>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Can you try configuring with
> I.e. omit the 'thrust' at the end of the path. Probably you'll need the
> same fix with cusp:
> Cheers,
> Dominic
> On 08/28/2014 08:13 AM, Christophe Ortiz wrote:
> > Hi all,
> > I have implemented a problem of coupled diffusion equations in 1D
> > using PETSc. I was able to configure PETSC with and without MPI. The
> > code runs well in both cases.
> > Now I would like to test CUDA but I am unable to configure it. I get
> > an error message related to thrust directory.
> > The options I use to configure are the following:
> > --with-cudac=/usr/local/cuda/bin/nvcc --with-thrust=1
> > --with-thrust-dir=/usr/local/cuda-6.0/include/thrust --with-cusp=1
> > --with-cusp-dir=/usr/local/cuda-6.0/include/cusp
> > --download-txpetscgpu=1 --with-debugging=1 --with-scalar-type=real
> > --with-precision=double --download-f-blas-lapack
> > The error message I get is:
> > for details):
> > --with-thrust-dir=/usr/local/cuda-6.0/include/thrust did not work
> > Did I miss something ?
> > My GPU is a GeForce Titan Black and I am using CUDA 6.0.
> > Many thanks in advance for your help.
> > Christophe
> Dominic Meiser
> Tech-X Corporation
> 5621 Arapahoe Avenue
> Boulder, CO 80303
> USA
> Telephone: 303-996-2036
> Fax: 303-448-7756
> www.txcorp.com
> Message: 4
> Date: Thu, 28 Aug 2014 08:30:40 -0600
> From: Paul Mullowney <paulmullowney at gmail.com>
> To: Dominic Meiser <dmeiser at txcorp.com>
> Cc: petsc-users at mcs.anl.gov
> Message-ID:
>         <CAMJ8fwroFUxG-rpbMpaJEw=
> 0aQdyNm9NMxMzsxWVGGPWZqhGCQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Also, get rid of --download-txpetscgpu=1. That doesn't exist anymore.
> -Paul
> On Thu, Aug 28, 2014 at 8:38 AM, Dominic Meiser <dmeiser at txcorp.com>
> > same fix with cusp:
> > Cheers,
> > Dominic
> >> Hi all,
> >> I have implemented a problem of coupled diffusion equations in 1D using
> >> PETSc. I was able to configure PETSC with and without MPI. The code runs
> >> well in both cases.
> >> Now I would like to test CUDA but I am unable to configure it. I get an
> >> --with-cusp-dir=/usr/local/cuda-6.0/include/cusp --download-txpetscgpu=1
> >> --with-debugging=1 --with-scalar-type=real --with-precision=double
> >> TESTING: checkInclude from config.headers(config/
> >> BuildSystem/config/headers.py:86) ******************************
> for
> >> details):
> >> Christophe
> > Dominic Meiser
> > Tech-X Corporation
> > Boulder, CO 80303
> > USA
> > Fax: 303-448-7756
> > www.txcorp.com
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140828/70c223ee/attachment-0001.html
> petsc-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> End of petsc-users Digest, Vol 68, Issue 63
> Confidencialidad:
> Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su
> destinatario y puede contener información privilegiada o confidencial. Si
> no es vd. el destinatario indicado, queda notificado de que la utilización,
> divulgación y/o copia sin autorización está prohibida en virtud de la
> legislación vigente. Si ha recibido este mensaje por error, le rogamos que
> nos lo comunique inmediatamente respondiendo al mensaje y proceda a su
> destrucción.
> Disclaimer:
> This message and its attached files is intended exclusively for its
> recipients and may contain confidential information. If you received this
> e-mail in error you are hereby notified that any dissemination, copy or
> disclosure of this communication is strictly prohibited and may be
> unlawful. In this case, please notify us by a reply and delete this email
> and its contents immediately.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/96a644fc/attachment-0001.html>
