[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Fri Aug 29 08:28:28 CDT 2014
Always attach configure.log or we cannot see what went wrong.
    Matt
On Fri, Aug 29, 2014 at 2:35 AM, Christophe Ortiz <
christophe.ortiz at ciemat.es> wrote:
> Hi Dominic and Paul,
> Thanks for your answers. Unfortunately, it did not work. Same error
> message related to the thrust directory:
> ./configure --with-x=1 --with-mpi=0 --with-cc=icc --with-cxx=icpc
> --with-clanguage=cxx --with-fc=ifort --with-cuda=1
> --with-cuda-dir=/usr/local/cuda-6.0 --with-cuda-arch=sm_35 --with-thrust=1
> --with-thrust-dir=/usr/local/cuda-6.0/include --with-cusp=1
> --with-cusp-dir=/usr/local/cuda-6.0/include --with-debugging=1
> --with-scalar-type=real --with-precision=double --download-fblaslapack
>              Configuring PETSc to compile on your system
> TESTING: checkInclude from
> config.headers(config/BuildSystem/config/headers.py:86)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> --with-thrust-dir=/usr/local/cuda-6.0/include did not work
> I do not see what else to do...I have a standard CUDA installation that
> came with thrust.
> I am using ubuntu 12.04, I do not know if that could help.
> I tried with PETSc 3.4.1 and 3.5.1. Same problem.
> Christophe
>> Message: 3
>> Date: Thu, 28 Aug 2014 08:38:12 -0600
>> From: Dominic Meiser <dmeiser at txcorp.com>
>> To: petsc-users at mcs.anl.gov
>> Subject: Re: [petsc-users] Unable to configure PETSc with CUDA:
>> Message-ID: <53FF3ED4.1090002 at txcorp.com>
>> Content-Type: text/plain; charset=UTF-8; format=flowed
>> Can you try configuring with
>> I.e. omit the 'thrust' at the end of the path. Probably you'll need the
>> same fix with cusp:
>> Cheers,
>> Dominic
>> On 08/28/2014 08:13 AM, Christophe Ortiz wrote:
>> > Hi all,
>> > I have implemented a problem of coupled diffusion equations in 1D
>> > using PETSc. I was able to configure PETSC with and without MPI. The
>> > code runs well in both cases.
>> > Now I would like to test CUDA but I am unable to configure it. I get
>> > an error message related to thrust directory.
>> > The options I use to configure are the following:
>> > --with-cudac=/usr/local/cuda/bin/nvcc --with-thrust=1
>> > --with-thrust-dir=/usr/local/cuda-6.0/include/thrust --with-cusp=1
>> > --with-cusp-dir=/usr/local/cuda-6.0/include/cusp
>> > --download-txpetscgpu=1 --with-debugging=1 --with-scalar-type=real
>> > --with-precision=double --download-f-blas-lapack
>> > The error message I get is:
>> > for details):
>> > --with-thrust-dir=/usr/local/cuda-6.0/include/thrust did not work
>> > Did I miss something ?
>> > My GPU is a GeForce Titan Black and I am using CUDA 6.0.
>> > Many thanks in advance for your help.
>> > Christophe
>> Dominic Meiser
>> Tech-X Corporation
>> 5621 Arapahoe Avenue
>> Boulder, CO 80303
>> USA
>> Telephone: 303-996-2036
>> Fax: 303-448-7756
>> www.txcorp.com
>> Message: 4
>> Date: Thu, 28 Aug 2014 08:30:40 -0600
>> From: Paul Mullowney <paulmullowney at gmail.com>
>> To: Dominic Meiser <dmeiser at txcorp.com>
>> Cc: petsc-users at mcs.anl.gov
>> Message-ID:
>>         <CAMJ8fwroFUxG-rpbMpaJEw=
>> 0aQdyNm9NMxMzsxWVGGPWZqhGCQ at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Also, get rid of --download-txpetscgpu=1. That doesn't exist anymore.
>> -Paul
>> On Thu, Aug 28, 2014 at 8:38 AM, Dominic Meiser <dmeiser at txcorp.com>
>> > same fix with cusp:
>> > Cheers,
>> > Dominic
>> >> Hi all,
>> >> I have implemented a problem of coupled diffusion equations in 1D using
>> >> PETSc. I was able to configure PETSC with and without MPI. The code
>> runs
>> >> well in both cases.
>> >> Now I would like to test CUDA but I am unable to configure it. I get an
>> >> --with-debugging=1 --with-scalar-type=real --with-precision=double
>> >> TESTING: checkInclude from config.headers(config/
>> >> BuildSystem/config/headers.py:86) ******************************
>> for
>> >> details):
>> >> Christophe
>> > Dominic Meiser
>> > Tech-X Corporation
>> > Boulder, CO 80303
>> > USA
>> > Fax: 303-448-7756
>> > www.txcorp.com
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140828/70c223ee/attachment-0001.html
>> petsc-users mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>> End of petsc-users Digest, Vol 68, Issue 63
>> Confidencialidad:
>> Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su
>> destinatario y puede contener información privilegiada o confidencial. Si
>> no es vd. el destinatario indicado, queda notificado de que la utilización,
>> divulgación y/o copia sin autorización está prohibida en virtud de la
>> legislación vigente. Si ha recibido este mensaje por error, le rogamos que
>> nos lo comunique inmediatamente respondiendo al mensaje y proceda a su
>> destrucción.
>> Disclaimer:
>> This message and its attached files is intended exclusively for its
>> recipients and may contain confidential information. If you received this
>> e-mail in error you are hereby notified that any dissemination, copy or
>> disclosure of this communication is strictly prohibited and may be
>> unlawful. In this case, please notify us by a reply and delete this email
>> and its contents immediately.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/a8616253/attachment.html>
