[petsc-users] Using KSPSetOperators with SAME_NONZERO_PATTERN
Thu Aug 28 04:45:59 CDT 2014
On Thu, Aug 28, 2014 at 3:33 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> I've been using :
> call KSPSetOperators(ksp_semi_xyz,A_semi_xyz,A_semi_xyz,SAME_
> NONZERO_PATTERN,ierr)
> in my code for a long time when solving for the linear equations.
> However, recently I found that my code can't run properly (diverged,
> segmentation fault). After debugging, I realised that I had to change from
> the above to
> call KSPSetOperators(ksp_semi_xyz,A_semi_xyz,A_semi_xyz,ierr)
> May I know if something has changed in the new versions of PETSc?
Yes, this is in the Changes file. We automatically determine whether the PC
matrix
has changed, and whether it has the same structure.
   Matt
> Thank you
> Yours sincerely,
> TAY wee-beng
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140828/e69af751/attachment.html>
