[petsc-users] Using KSPSetOperators with SAME_NONZERO_PATTERN
TAY wee-beng zonexo at gmail.com
Thu Aug 28 03:33:13 CDT 2014
I've been using :
call
KSPSetOperators(ksp_semi_xyz,A_semi_xyz,A_semi_xyz,SAME_NONZERO_PATTERN,ierr)
in my code for a long time when solving for the linear equations.
However, recently I found that my code can't run properly (diverged,
segmentation fault). After debugging, I realised that I had to change
from the above to
call KSPSetOperators(ksp_semi_xyz,A_semi_xyz,A_semi_xyz,ierr)
May I know if something has changed in the new versions of PETSc?
Thank you
Yours sincerely,
TAY wee-beng
