[petsc-users] eps_target malloc issue
jifeng zhao jifengzhao2015 at u.northwestern.edu
Tue Aug 5 10:43:52 CDT 2014
Hello Hong,
There is no problem. You can add the following description:
"The matrices come from Jifeng Zhao, Northwestern University,
zhaojf06 at gmail.com. The stiffness and mass matrices arise from a extended
finite element model to predict phononic band gap of a three-dimensional
two-phase composite with periodic SCC crystal structure. In addition,
periodic boundary conditions are applied on the primary unit cell by
employing Bloch wave analysis."
In addition, do want to let you know that I tried the runtime command you
gave me using PETSC/3.4.4 (3.5 is not ready yet for me), it failed to
converge.
PETSC ERROR: !
PETSC ERROR: KSP did not converge (reason=DIVERGED_ITS)*!*
*I also tried to different preconditioners:*
minres/bjacobi/ icc
minres/bjacobi/ asm
minres/bjacobi/ gamg
All of them failed by the same error. I can try to increase the maximum
iteration number to remove this error message, but it will converge very
slow for sure.
Since I am already using -aij command, I am not sure if these slow
convergence performance will disappear if I upgrade to PETSC/3.5. Is there
anything else I can try on?
Thank you so much,
Jifeng Zhao
On Mon, Aug 4, 2014 at 11:18 PM, hong at aspiritech.org <hong at aspiritech.org>
wrote:
> jifeng :
> > I just want to check with you if there is any updates on why the code
> > crashes under -sbaij?
> It is a bug in petsc. I've fixed it in the brach hzhang/mataxpy-bugfix:
> https://bitbucket.org/petsc/petsc/branch/hzhang/mataxpy-bugfix
> which will be merged to 'next' branch for tests, then patch to petsc-3.5.
> You can use this branch if you like.
> Again, I like to add your matrices into petsc matrix collection.
> Can you give me a short sentence describing your matrices, e.g.,
> "The following matrices come from Rick Dean, Arco E&P Technology,
> rhd at arco.com.  They arise from multiphase flow modeling of oil
> reservoirs,..."
> Thanks,
> Hong
> > At the meanwhile, unfortunately PETSC-3.5 hasn't been installed on my
> server
> > due to some technical problems. I hope technicians can get it done as
> soon
> > as possible. I will update you when I have any new results. Thanks so
> much.
> > Best regards,
> > Jifeng
> > On Wed, Jul 30, 2014 at 2:53 PM, jifeng zhao
> > <jifengzhao2015 at u.northwestern.edu> wrote:
> >> Hello Hong,
> >> Thanks a lot. The result makes sense, but I think I will need higher
> >> accuracy (smaller tolerance). I will take a try myself at the meanwhile.
> >> Best regards,
> >> Jifeng Zhao
> >> On Wed, Jul 30, 2014 at 1:16 PM, hong at aspiritech.org <
> >> wrote:
> >>> Jifeng,
> >>> Using petsc-3.5 and slepc-3.5 (maint branch), I tested your matrices
> >>> mpiexec -n 32 ./ex7 -f1 $data/zhao/petsc_stiff20.dat -f2
> >>> $data/zhao/petsc_mass20.dat -mat_view ascii::ascii_info -mat_type aij
> >>> -eps_gen_hermitian -eps_type krylovschur -eps_target -0.1 -st_ksp_type
> >>> minres -st_pc_type bjacobi -st_sub_pc_type icc -st_ksp_rtol 1.e-2
> >>> -eps_tol 1.e-2 -eps_nev 40 -st_type sinvert -log_summary |& tee
> >>> log.mat20.ex7.np32.tol-2
> >>> The output is attached.
> >>> When using '-mat_type sbaij', I got same error as reported, which
> >>> might be a bug in our libraries. I'll investigate it.
> >>> Switching to '-mat_type aij' works (I'm not sure if the computed
> >>> eigenvalues are meaningful though), but the linear solver
> >>> minres/bjacobi/icc converges very slow, takes around 500 - 1000 linear
> >>> iterations for each eps iteration. You may experiment with stronger
> >>> pc_type, e.g., '-pc_type asm' etc.
> >>> I'll let you know why sbaij crashes.
> >>> Hong
> >>> On Mon, Jul 28, 2014 at 4:52 PM, Jose E. Roman <jroman at dsic.upv.es>
> >>> wrote:
> >>> > El 28/07/2014, a las 23:48, jifeng zhao escribió:
> >>> >> Hi Barry,
> >>> >> Thanks for the reply. I see. I am still testing it and looking for
> the
> >>> >> bug.
> >>> >> It is pretty weird that the error appears, since the code I am
> running
> >>> >> is ex7 and I didn't change anything.
> >>> >> My matrices are assembled in binary files separately. As I explained
> >>> >> earlier, I have a series of matrices to solve, each of them have
> the same
> >>> >> patterns but with different values. The way I assembly the matrix
> has proven
> >>> >> to be correct for all the other cases. Only for this one, when the
> matrix
> >>> >> has an zero eigenvalue, ex7 failed to solve it.
> >>> >> In fact, I don't understand why this "Out of range" error could
> >>> >> possibly appear? 1. my matrices have the correct parrellel lay up.
> 2. In
> >>> >> ex7, I am not explicitly accessing to any elements at all! All I
> did is
> >>> >> EPSSolve();
> >>> >> Any ideas?
> >>> >> Best regards,
> >>> >> Jifeng Zhao
> >>> > Tomorrow we will release slepc-3.5. I would suggest trying with the
> new
> >>> > version. If the problem persist we can help to track down the
> problem.
> >>> > Jose
> >> Jifeng Zhao
> >> PhD candidate at Northwestern University, US
> >> Theoretical and Applied Mechanics Program
> > Jifeng Zhao
Jifeng Zhao
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140805/d16d76e4/attachment.html>
