[petsc-users] eps_target malloc issue
hong at aspiritech.org hong at aspiritech.org
Mon Aug 4 23:18:33 CDT 2014
jifeng :
> I just want to check with you if there is any updates on why the code
> crashes under -sbaij?
It is a bug in petsc. I've fixed it in the brach hzhang/mataxpy-bugfix:
https://bitbucket.org/petsc/petsc/branch/hzhang/mataxpy-bugfix
which will be merged to 'next' branch for tests, then patch to petsc-3.5.
You can use this branch if you like.
Again, I like to add your matrices into petsc matrix collection.
Can you give me a short sentence describing your matrices, e.g.,
"The following matrices come from Rick Dean, Arco E&P Technology,
rhd at arco.com.  They arise from multiphase flow modeling of oil
reservoirs,..."
Hong
> At the meanwhile, unfortunately PETSC-3.5 hasn't been installed on my server
> due to some technical problems. I hope technicians can get it done as soon
> as possible. I will update you when I have any new results. Thanks so much.
> Best regards,
> Jifeng
> On Wed, Jul 30, 2014 at 2:53 PM, jifeng zhao
> <jifengzhao2015 at u.northwestern.edu> wrote:
>> Hello Hong,
>> Thanks a lot. The result makes sense, but I think I will need higher
>> accuracy (smaller tolerance). I will take a try myself at the meanwhile.
>> Best regards,
>> Jifeng Zhao
>> On Wed, Jul 30, 2014 at 1:16 PM, hong at aspiritech.org <hong at aspiritech.org>
>> wrote:
>>> Jifeng,
>>> Using petsc-3.5 and slepc-3.5 (maint branch), I tested your matrices
>>> mpiexec -n 32 ./ex7 -f1 $data/zhao/petsc_stiff20.dat -f2
>>> $data/zhao/petsc_mass20.dat -mat_view ascii::ascii_info -mat_type aij
>>> -eps_gen_hermitian -eps_type krylovschur -eps_target -0.1 -st_ksp_type
>>> minres -st_pc_type bjacobi -st_sub_pc_type icc -st_ksp_rtol 1.e-2
>>> -eps_tol 1.e-2 -eps_nev 40 -st_type sinvert -log_summary |& tee
>>> log.mat20.ex7.np32.tol-2
>>> The output is attached.
>>> When using '-mat_type sbaij', I got same error as reported, which
>>> might be a bug in our libraries. I'll investigate it.
>>> Switching to '-mat_type aij' works (I'm not sure if the computed
>>> eigenvalues are meaningful though), but the linear solver
>>> minres/bjacobi/icc converges very slow, takes around 500 - 1000 linear
>>> iterations for each eps iteration. You may experiment with stronger
>>> pc_type, e.g., '-pc_type asm' etc.
>>> I'll let you know why sbaij crashes.
>>> Hong
>>> On Mon, Jul 28, 2014 at 4:52 PM, Jose E. Roman <jroman at dsic.upv.es>
>>> wrote:
>>> > El 28/07/2014, a las 23:48, jifeng zhao escribió:
>>> >> Hi Barry,
>>> >> Thanks for the reply. I see. I am still testing it and looking for the
>>> >> bug.
>>> >> It is pretty weird that the error appears, since the code I am running
>>> >> is ex7 and I didn't change anything.
>>> >> My matrices are assembled in binary files separately. As I explained
>>> >> earlier, I have a series of matrices to solve, each of them have the same
>>> >> patterns but with different values. The way I assembly the matrix has proven
>>> >> to be correct for all the other cases. Only for this one, when the matrix
>>> >> has an zero eigenvalue, ex7 failed to solve it.
>>> >> In fact, I don't understand why this "Out of range" error could
>>> >> possibly appear? 1. my matrices have the correct parrellel lay up. 2. In
>>> >> ex7, I am not explicitly accessing to any elements at all! All I did is
>>> >> EPSSolve();
>>> >> Any ideas?
>>> >> Best regards,
>>> >> Jifeng Zhao
>>> > Tomorrow we will release slepc-3.5. I would suggest trying with the new
>>> > version. If the problem persist we can help to track down the problem.
>>> > Jose
>> Jifeng Zhao
>> PhD candidate at Northwestern University, US
>> Theoretical and Applied Mechanics Program
> Jifeng Zhao
