[petsc-users] Problem with DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
TAY wee-beng zonexo at gmail.com
Sat Apr 19 10:49:29 CDT 2014
On 19/4/2014 11:39 PM, Matthew Knepley wrote:
> On Sat, Apr 19, 2014 at 10:16 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     On 19/4/2014 10:55 PM, Matthew Knepley wrote:
>>     On Sat, Apr 19, 2014 at 9:14 AM, TAY wee-beng <zonexo at gmail.com
>>         On 19/4/2014 6:48 PM, Matthew Knepley wrote:
>>>         On Sat, Apr 19, 2014 at 4:59 AM, TAY wee-beng
>>>         <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>             On 19/4/2014 1:17 PM, Barry Smith wrote:
>>>                 On Apr 19, 2014, at 12:11 AM, TAY wee-beng
>>>                     On 19/4/2014 12:10 PM, Barry Smith wrote:
>>>                         On Apr 18, 2014, at 9:57 PM, TAY wee-beng
>>>                         wrote:
>>>                             On 19/4/2014 3:53 AM, Barry Smith wrote:
>>>                                    Hmm,
>>>                                        Interface DMDAVecGetArrayF90
>>>                                          Subroutine
>>>                                 DMDAVecGetArrayF903(da1, v,d1,ierr)
>>>                                  USE_DM_HIDE
>>>                                            DM_HIDE da1
>>>                                            VEC_HIDE v
>>>                                  PetscScalar,pointer :: d1(:,:,:)
>>>                                  PetscErrorCode ierr
>>>                                          End Subroutine
>>>                                     So the d1 is a F90 POINTER. But
>>>                                 your subroutine seems to be treating
>>>                                 it as a “plain old Fortran array”?
>>>                                 real(8), intent(inout) ::
>>>                                 u(:,:,:),v(:,:,:),w(:,:,:)
>>>                     Hi,
>>>                     So d1 is a pointer, and it's different if I
>>>                     declare it as "plain old Fortran array"? Because
>>>                     I declare it as a Fortran array and it works w/o
>>>                     any problem if I only call DMDAVecGetArrayF90
>>>                     and DMDAVecRestoreArrayF90 with "u".
>>>                     But if I call DMDAVecGetArrayF90 and
>>>                     DMDAVecRestoreArrayF90 with "u", "v" and "w",
>>>                     error starts to happen. I wonder why...
>>>                     Also, supposed I call:
>>>                     call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>>>                         call
>>>                     DMDAVecGetArrayF90(da_v,v_local,v_array,ierr)
>>>                         call
>>>                     DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)
>>>                     u_array ....
>>>                     v_array .... etc
>>>                     Now to restore the array, does it matter the
>>>                     sequence they are restored?
>>>                     No it should not matter. If it matters that is a
>>>                 sign that memory has been written to incorrectly
>>>                 earlier in the code.
>>>             Hi,
>>>             Hmm, I have been getting different results on different
>>>             intel compilers. I'm not sure if MPI played a part but
>>>             I'm only using a single processor. In the debug mode,
>>>             things run without problem. In optimized mode, in some
>>>             cases, the code aborts even doing simple initialization:
>>>                 call DMDAVecGetArrayF90(da_v,v_local,v_array,ierr)
>>>                 call DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)
>>>                 call DMDAVecGetArrayF90(da_p,p_local,p_array,ierr)
>>>                 u_array = 0.d0
>>>                 v_array = 0.d0
>>>                 w_array = 0.d0
>>>                 p_array = 0.d0
>>>                 call DMDAVecRestoreArrayF90(da_p,p_local,p_array,ierr)
>>>                 call DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)
>>>                 call DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr)
>>>                 call DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr)
>>>             The code aborts at call
>>>             DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr),
>>>             giving segmentation error. But other version of intel
>>>             compiler passes thru this part w/o error. Since the
>>>             response is different among different compilers, is this
>>>             PETSc or intel 's bug? Or mvapich or openmpi?
>>>         We do this is a bunch of examples. Can you reproduce this
>>>         different behavior in src/dm/examples/tutorials/ex11f90.F?
>>         Hi Matt,
>>         Do you mean putting the above lines into ex11f90.F and test?
>>     It already has DMDAVecGetArray(). Just run it.
>     Hi,
>     It worked. The differences between mine and the code is the way
>     the fortran modules are defined, and the ex11f90 only uses global
>     vectors. Does it make a difference whether global or local vectors
>     are used? Because the way it accesses x1 only touches the local
>     region.
> No the global/local difference should not matter.
>     Also, before using DMDAVecGetArrayF90, DMGetGlobalVector must be
>     used 1st, is that so? I can't find the equivalent for local vector
>     though.
> DMGetLocalVector()
Ops, I do not have DMGetLocalVector and DMRestoreLocalVector in my code.
Does it matter?
If so, when should I call them?
Thanks.
>    Matt
>     Thanks.
>>        Matt
>>         Thanks
>>         Regards.
>>>            Matt
>>>                     As in w, then v and u?
>>>                     call
>>>                     call
>>>                     call
>>>                     thanks
>>>                                     Note also that the beginning and
>>>                                 end indices of the u,v,w, are
>>>                                 different for each process see for
>>>                                 example
>>>                                 http://www.mcs.anl.gov/petsc/petsc-3.4/src/dm/examples/tutorials/ex11f90.F
>>>                                  (and they do not start at 1). This
>>>                                 is how to get the loop bounds.
>>>                             Hi,
>>>                             In my case, I fixed the u,v,w such that
>>>                             their indices are the same. I also
>>>                             checked using DMDAGetCorners and
>>>                             DMDAGetGhostCorners. Now the problem
>>>                             lies in my subroutine treating it as a
>>>                             “plain old Fortran array”.
>>>                             If I declare them as pointers, their
>>>                             indices follow the C 0 start convention,
>>>                             is that so?
>>>                             Not really. It is that in each process
>>>                         you need to access them from the indices
>>>                         indicated by DMDAGetCorners() for global
>>>                         vectors and DMDAGetGhostCorners() for local
>>>                         vectors.  So really C or Fortran doesn’t
>>>                         make any difference.
>>>                             So my problem now is that in my old MPI
>>>                             code, the u(i,j,k) follow the Fortran 1
>>>                             start convention. Is there some way to
>>>                             manipulate such that I do not have to
>>>                             change my u(i,j,k) to u(i-1,j-1,k-1)?
>>>                            If you code wishes to access them with
>>>                         indices plus one from the values returned by
>>>                         DMDAGetCorners() for global vectors and
>>>                         DMDAGetGhostCorners() for local vectors then
>>>                         you need to manually subtract off the 1.
>>>                            Barry
>>>                             Thanks.
>>>                                    Barry
>>>                                 On Apr 18, 2014, at 10:58 AM, TAY
>>>                                     Hi,
>>>                                     I tried to pinpoint the problem.
>>>                                     I reduced my job size and hence
>>>                                     I can run on 1 processor. Tried
>>>                                     using valgrind but perhaps I'm
>>>                                     using the optimized version, it
>>>                                     didn't catch the error, besides
>>>                                     saying "Segmentation fault (core
>>>                                     dumped)"
>>>                                     However, by re-writing my code,
>>>                                     I found out a few things:
>>>                                     1. if I write my code this way:
>>>                                     call
>>>                                     call
>>>                                     call
>>>                                     u_array = ....
>>>                                     v_array = ....
>>>                                     w_array = ....
>>>                                     call
>>>                                     call
>>>                                     call
>>>                                     The code runs fine.
>>>                                     2. if I write my code this way:
>>>                                     call
>>>                                     call
>>>                                     call
>>>                                     call
>>>                                     uvw_array_change(u_array,v_array,w_array)
>>>                                     -> this subroutine does the same
>>>                                     modification as the above.
>>>                                     call
>>>                                     call
>>>                                     call
>>>                                     -> error
>>>                                     where the subroutine is:
>>>                                     subroutine uvw_array_change(u,v,w)
>>>                                     u ...
>>>                                     v...
>>>                                     w ...
>>>                                     end subroutine uvw_array_change.
>>>                                     The above will give an error at :
>>>                                     call
>>>                                     3. Same as above, except I
>>>                                     change the order of the last 3
>>>                                     lines to:
>>>                                     call
>>>                                     call
>>>                                     call
>>>                                     So they are now in reversed
>>>                                     order. Now it works.
>>>                                     4. Same as 2 or 3, except the
>>>                                     subroutine is changed to :
>>>                                     u(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>                                     v(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>                                     w(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>                                     u ...
>>>                                     v...
>>>                                     w ...
>>>                                     The start_indices and
>>>                                     end_indices are simply to shift
>>>                                     the 0 indices of C convention to
>>>                                     that of the 1 indices of the
>>>                                     Fortran convention. This is
>>>                                     necessary in my case because
>>>                                     most of my codes start array
>>>                                     counting at 1, hence the "trick".
>>>                                     However, now no matter which
>>>                                     order of the
>>>                                     DMDAVecRestoreArrayF90 (as in 2
>>>                                     or 3), error will occur at "call
>>>                                     So did I violate and cause
>>>                                     memory corruption due to the
>>>                                     trick above? But I can't think
>>>                                     of any way other than the
>>>                                     "trick" to continue using the 1
>>>                                     indices convention.
>>>                                     Thank you.
>>>                                     Yours sincerely,
>>>                                     TAY wee-beng
>>>                                     On 15/4/2014 8:00 PM, Barry
>>>                                     Smith wrote:
>>>                                            Try running under
>>>                                         valgrind
>>>                                         http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>                                         On Apr 14, 2014, at 9:47 PM,
>>>                                         TAY wee-beng
>>>                                         wrote:
>>>                                             Hi Barry,
>>>                                             As I mentioned earlier,
>>>                                             the code works fine in
>>>                                             PETSc debug mode but
>>>                                             fails in non-debug mode.
>>>                                             I have attached my code.
>>>                                             Thank you
>>>                                             Yours sincerely,
>>>                                             TAY wee-beng
>>>                                             On 15/4/2014 2:26 AM,
>>>                                             Barry Smith wrote:
>>>                                                    Please send the
>>>                                                 code that creates
>>>                                                 da_w and the
>>>                                                 declarations of w_array
>>>                                                    Barry
>>>                                                 On Apr 14, 2014, at
>>>                                                 9:40 AM, TAY wee-beng
>>>                                                   wrote:
>>>                                                     Hi Barry,
>>>                                                     I'm not too sure
>>>                                                     how to do it.
>>>                                                     I'm running mpi.
>>>                                                     So I run:
>>>                                                       mpirun -n 4
>>>                                                     ./a.out
>>>                                                     -start_in_debugger
>>>                                                     I got the msg
>>>                                                     below. Before
>>>                                                     the gdb windows
>>>                                                     appear (thru
>>>                                                     x11), the
>>>                                                     program aborts.
>>>                                                     Also I tried
>>>                                                     running in
>>>                                                     another cluster
>>>                                                     and it worked.
>>>                                                     Also tried in
>>>                                                     the current
>>>                                                     cluster in debug
>>>                                                     mode and it
>>>                                                     worked too.
>>>                                                     mpirun -n 4
>>>                                                     ./a.out
>>>                                                     -start_in_debugger
>>>                                                     An MPI process
>>>                                                     has executed an
>>>                                                     operation
>>>                                                     involving a call
>>>                                                     to the
>>>                                                     "fork()" system
>>>                                                     call to create a
>>>                                                     child process.
>>>                                                      Open MPI is
>>>                                                     currently
>>>                                                     operating in a
>>>                                                     condition that
>>>                                                     could result in
>>>                                                     memory corruption or
>>>                                                     other system
>>>                                                     errors; your MPI
>>>                                                     job may hang,
>>>                                                     crash, or
>>>                                                     produce silent
>>>                                                     data corruption.
>>>                                                      The use of
>>>                                                     fork() (or
>>>                                                     system() or
>>>                                                     other calls that
>>>                                                     create child
>>>                                                     processes) is
>>>                                                     strongly
>>>                                                     discouraged.
>>>                                                     The process that
>>>                                                     invoked fork was:
>>>                                                        Local host:
>>>                                                      n12-76 (PID 20235)
>>>                                                      MPI_COMM_WORLD
>>>                                                     rank: 2
>>>                                                     If you are
>>>                                                     *absolutely
>>>                                                     sure* that your
>>>                                                     application will
>>>                                                     successfully
>>>                                                     and correctly
>>>                                                     survive a call
>>>                                                     to fork(), you
>>>                                                     may disable this
>>>                                                     warning
>>>                                                     by setting the
>>>                                                     mpi_warn_on_fork
>>>                                                     MCA parameter to 0.
>>>                                                     [2]PETSC ERROR:
>>>                                                     PETSC: Attaching
>>>                                                     gdb to ./a.out
>>>                                                     of pid 20235 on
>>>                                                     display
>>>                                                     localhost:50.0
>>>                                                     on machine n12-76
>>>                                                     [0]PETSC ERROR:
>>>                                                     PETSC: Attaching
>>>                                                     gdb to ./a.out
>>>                                                     of pid 20233 on
>>>                                                     display
>>>                                                     localhost:50.0
>>>                                                     on machine n12-76
>>>                                                     [1]PETSC ERROR:
>>>                                                     PETSC: Attaching
>>>                                                     gdb to ./a.out
>>>                                                     of pid 20234 on
>>>                                                     display
>>>                                                     localhost:50.0
>>>                                                     on machine n12-76
>>>                                                     [3]PETSC ERROR:
>>>                                                     PETSC: Attaching
>>>                                                     gdb to ./a.out
>>>                                                     of pid 20236 on
>>>                                                     display
>>>                                                     localhost:50.0
>>>                                                     on machine n12-76
>>>                                                     [n12-76:20232] 3
>>>                                                     more processes
>>>                                                     have sent help
>>>                                                     message
>>>                                                     help-mpi-runtime.txt
>>>                                                     / mpi_init:warn-fork
>>>                                                     [n12-76:20232]
>>>                                                     Set MCA
>>>                                                     parameter
>>>                                                     "orte_base_help_aggregate"
>>>                                                     to 0 to see all
>>>                                                     help / error
>>>                                                     messages
>>>                                                       1
>>>                                                     [1]PETSC ERROR:
>>>                                                     [1]PETSC ERROR:
>>>                                                     Caught signal
>>>                                                     number 11 SEGV:
>>>                                                     Segmentation
>>>                                                     Violation,
>>>                                                     probably memory
>>>                                                     access out of range
>>>                                                     [1]PETSC ERROR:
>>>                                                     Try option
>>>                                                     -start_in_debugger
>>>                                                     or
>>>                                                     -on_error_attach_debugger
>>>                                                     [1]PETSC ERROR:
>>>                                                     or see
>>>                                                     http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC
>>>                                                     ERROR: or try
>>>                                                     http://valgrind.org
>>>                                                       on GNU/linux
>>>                                                     and Apple Mac OS
>>>                                                     X to find memory
>>>                                                     corruption errors
>>>                                                     [1]PETSC ERROR:
>>>                                                     configure using
>>>                                                     --with-debugging=yes,
>>>                                                     recompile, link,
>>>                                                     and run
>>>                                                     [1]PETSC ERROR:
>>>                                                     to get more
>>>                                                     information on
>>>                                                     the crash.
>>>                                                     [1]PETSC ERROR:
>>>                                                     User provided
>>>                                                     function() line
>>>                                                     0 in unknown
>>>                                                     directory
>>>                                                     unknown file (null)
>>>                                                     [3]PETSC ERROR:
>>>                                                     [3]PETSC ERROR:
>>>                                                     Caught signal
>>>                                                     number 11 SEGV:
>>>                                                     Segmentation
>>>                                                     Violation,
>>>                                                     probably memory
>>>                                                     access out of range
>>>                                                     [3]PETSC ERROR:
>>>                                                     Try option
>>>                                                     -start_in_debugger
>>>                                                     or
>>>                                                     [3]PETSC ERROR:
>>>                                                     or see
>>>                                                     http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[3]PETSC
>>>                                                     ERROR: or try
>>>                                                     http://valgrind.org
>>>                                                       on GNU/linux
>>>                                                     and Apple Mac OS
>>>                                                     X to find memory
>>>                                                     corruption errors
>>>                                                     [3]PETSC ERROR:
>>>                                                     configure using
>>>                                                     recompile, link,
>>>                                                     and run
>>>                                                     [3]PETSC ERROR:
>>>                                                     to get more
>>>                                                     information on
>>>                                                     the crash.
>>>                                                     [3]PETSC ERROR:
>>>                                                     User provided
>>>                                                     function() line
>>>                                                     0 in unknown
>>>                                                     directory
>>>                                                     unknown file (null)
>>>                                                     Thank you.
>>>                                                     Yours sincerely,
>>>                                                     TAY wee-beng
>>>                                                     On 14/4/2014
>>>                                                     9:05 PM, Barry
>>>                                                     Smith wrote:
>>>                                                            Because
>>>                                                         IO doesn’t
>>>                                                         always get
>>>                                                         flushed
>>>                                                         immediately
>>>                                                         it may not
>>>                                                         be hanging
>>>                                                         at this
>>>                                                         point.  It
>>>                                                         is better to
>>>                                                         use the
>>>                                                         option
>>>                                                         -start_in_debugger
>>>                                                         then type
>>>                                                         cont in each
>>>                                                         debugger
>>>                                                         window and
>>>                                                         then when
>>>                                                         you think it
>>>                                                         is “hanging”
>>>                                                         do a control
>>>                                                         C in each
>>>                                                         debugger
>>>                                                         window and
>>>                                                         type where
>>>                                                         to see where
>>>                                                         each process
>>>                                                         is you can
>>>                                                         also look
>>>                                                         around in
>>>                                                         the debugger
>>>                                                         at variables
>>>                                                         to see why
>>>                                                         it is
>>>                                                         “hanging” at
>>>                                                         that point.
>>>                                                             Barry
>>>                                                            This
>>>                                                         routines
>>>                                                         don’t have
>>>                                                         any parallel
>>>                                                         communication in
>>>                                                         them so are
>>>                                                         unlikely to
>>>                                                         hang.
>>>                                                         On Apr 14,
>>>                                                         2014, at
>>>                                                         6:52 AM, TAY
>>>                                                         wee-beng
>>>                                                           wrote:
>>>                                                             Hi,
>>>                                                             My code
>>>                                                             hangs
>>>                                                             and I
>>>                                                             added in
>>>                                                             mpi_barrier
>>>                                                             and
>>>                                                             print to
>>>                                                             catch
>>>                                                             the bug.
>>>                                                             I found
>>>                                                             that it
>>>                                                             hangs
>>>                                                             after
>>>                                                             printing
>>>                                                             "7". Is
>>>                                                             it
>>>                                                             because
>>>                                                             I'm
>>>                                                             doing
>>>                                                             something wrong?
>>>                                                             I need
>>>                                                             to
>>>                                                             access
>>>                                                             the
>>>                                                             u,v,w
>>>                                                             array so
>>>                                                             I use
>>>                                                             DMDAVecGetArrayF90.
>>>                                                             After
>>>                                                             access,
>>>                                                             I use
>>>                                                             DMDAVecRestoreArrayF90.
>>>                                                              call
>>>                                                              call
>>>                                                             MPI_Barrier(MPI_COMM_WORLD,ierr);
>>>                                                              if
>>>                                                             (myid==0) print
>>>                                                             *,"3"
>>>                                                              call
>>>                                                              call
>>>                                                              if
>>>                                                             (myid==0) print
>>>                                                             *,"4"
>>>                                                              call
>>>                                                              call
>>>                                                              if
>>>                                                             (myid==0) print
>>>                                                             *,"5"
>>>                                                              call
>>>                                                             I_IIB_uv_initial_1st_dm(I_cell_no_u1,I_cell_no_v1,I_cell_no_w1,I_cell_u1,I_cell_v1,I_cell_w1,u_array,v_array,w_array)
>>>                                                              call
>>>                                                              if
>>>                                                             (myid==0) print
>>>                                                             *,"6"
>>>                                                              call
>>>                                                              !must
>>>                                                             be in
>>>                                                             reverse
>>>                                                             order
>>>                                                              call
>>>                                                              if
>>>                                                             (myid==0) print
>>>                                                             *,"7"
>>>                                                              call
>>>                                                              call
>>>                                                              if
>>>                                                             (myid==0) print
>>>                                                             *,"8"
>>>                                                              call
>>>                                                             Thank you.
>>>                                                             Yours
>>>                                                             sincerely,
>>>                                                             TAY wee-beng
>>>                                             <code.txt>
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140419/c1fd808d/attachment-0001.html>
