[petsc-users] Problem with DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
Sat Apr 19 12:02:04 CDT 2014
On Sat, Apr 19, 2014 at 10:49 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  On 19/4/2014 11:39 PM, Matthew Knepley wrote:
>  On Sat, Apr 19, 2014 at 10:16 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>  On 19/4/2014 10:55 PM, Matthew Knepley wrote:
>>  On Sat, Apr 19, 2014 at 9:14 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>  On 19/4/2014 6:48 PM, Matthew Knepley wrote:
>>>  On Sat, Apr 19, 2014 at 4:59 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>  On 19/4/2014 1:17 PM, Barry Smith wrote:
>>>>> On Apr 19, 2014, at 12:11 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>>  On 19/4/2014 12:10 PM, Barry Smith wrote:
>>>>>>> On Apr 18, 2014, at 9:57 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>>>>  On 19/4/2014 3:53 AM, Barry Smith wrote:
>>>>>>>>>    Hmm,
>>>>>>>>>        Interface DMDAVecGetArrayF90
>>>>>>>>>          Subroutine DMDAVecGetArrayF903(da1, v,d1,ierr)
>>>>>>>>>            USE_DM_HIDE
>>>>>>>>>            DM_HIDE da1
>>>>>>>>>            VEC_HIDE v
>>>>>>>>>            PetscScalar,pointer :: d1(:,:,:)
>>>>>>>>>            PetscErrorCode ierr
>>>>>>>>>          End Subroutine
>>>>>>>>>     So the d1 is a F90 POINTER. But your subroutine seems to be
>>>>>>>>> treating it as a “plain old Fortran array”?
>>>>>>>>> real(8), intent(inout) :: u(:,:,:),v(:,:,:),w(:,:,:)
>>>>>>>>  Hi,
>>>>>> So d1 is a pointer, and it's different if I declare it as "plain old
>>>>>> Fortran array"? Because I declare it as a Fortran array and it works w/o
>>>>>> any problem if I only call DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
>>>>>> with "u".
>>>>>> But if I call DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90 with "u",
>>>>>> "v" and "w", error starts to happen. I wonder why...
>>>>>> Also, supposed I call:
>>>>>> call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>>>>>>     call DMDAVecGetArrayF90(da_v,v_local,v_array,ierr)
>>>>>>     call DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)
>>>>>> u_array ....
>>>>>> v_array .... etc
>>>>>> Now to restore the array, does it matter the sequence they are
>>>>>> restored?
>>>>>     No it should not matter. If it matters that is a sign that memory
>>>>> has been written to incorrectly earlier in the code.
>>>>>   Hi,
>>>> Hmm, I have been getting different results on different intel
>>>> compilers. I'm not sure if MPI played a part but I'm only using a single
>>>> processor. In the debug mode, things run without problem. In optimized
>>>> mode, in some cases, the code aborts even doing simple initialization:
>>>>      call DMDAVecGetArrayF90(da_p,p_local,p_array,ierr)
>>>>     u_array = 0.d0
>>>>     v_array = 0.d0
>>>>     w_array = 0.d0
>>>>     p_array = 0.d0
>>>>     call DMDAVecRestoreArrayF90(da_p,p_local,p_array,ierr)
>>>>     call DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)
>>>>     call DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr)
>>>>     call DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr)
>>>>  The code aborts at call
>>>> DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr), giving segmentation
>>>> error. But other version of intel compiler passes thru this part w/o error.
>>>> Since the response is different among different compilers, is this PETSc or
>>>> intel 's bug? Or mvapich or openmpi?
>>>  We do this is a bunch of examples. Can you reproduce this different
>>> behavior in src/dm/examples/tutorials/ex11f90.F?
>>> Hi Matt,
>>> Do you mean putting the above lines into ex11f90.F and test?
>>  It already has DMDAVecGetArray(). Just run it.
>> Hi,
>> It worked. The differences between mine and the code is the way the
>> fortran modules are defined, and the ex11f90 only uses global vectors. Does
>> it make a difference whether global or local vectors are used? Because the
>> way it accesses x1 only touches the local region.
>  No the global/local difference should not matter.
>>  Also, before using DMDAVecGetArrayF90, DMGetGlobalVector must be used
>> 1st, is that so? I can't find the equivalent for local vector though.
>  DMGetLocalVector()
> Ops, I do not have DMGetLocalVector and DMRestoreLocalVector in my code.
> Does it matter?
> If so, when should I call them?
You just need a local vector from somewhere.
  Matt
> Thanks.
>     Matt
>>  Thanks.
>>     Matt
>>>  Thanks
>>> Regards.
>>>     Matt
>>>>   As in w, then v and u?
>>>>>> thanks
>>>>>>>      Note also that the beginning and end indices of the u,v,w, are
>>>>>>>>> different for each process see for example
>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-3.4/src/dm/examples/tutorials/ex11f90.F (and they do not start at 1). This is how to get the loop bounds.
>>>>>>>> Hi,
>>>>>>>> In my case, I fixed the u,v,w such that their indices are the same.
>>>>>>>> I also checked using DMDAGetCorners and DMDAGetGhostCorners. Now the
>>>>>>>> problem lies in my subroutine treating it as a “plain old Fortran array”.
>>>>>>>> If I declare them as pointers, their indices follow the C 0 start
>>>>>>>> convention, is that so?
>>>>>>>     Not really. It is that in each process you need to access them
>>>>>>> from the indices indicated by DMDAGetCorners() for global vectors and
>>>>>>> DMDAGetGhostCorners() for local vectors.  So really C or Fortran doesn’t
>>>>>>> make any difference.
>>>>>>>  So my problem now is that in my old MPI code, the u(i,j,k) follow
>>>>>>>> the Fortran 1 start convention. Is there some way to manipulate such that I
>>>>>>>> do not have to change my u(i,j,k) to u(i-1,j-1,k-1)?
>>>>>>>    If you code wishes to access them with indices plus one from the
>>>>>>> values returned by DMDAGetCorners() for global vectors and
>>>>>>> DMDAGetGhostCorners() for local vectors then you need to manually subtract
>>>>>>> off the 1.
>>>>>>>    Barry
>>>>>>>  Thanks.
>>>>>>>>>    Barry
>>>>>>>>> On Apr 18, 2014, at 10:58 AM, TAY wee-beng <zonexo at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>  Hi,
>>>>>>>>>> I tried to pinpoint the problem. I reduced my job size and hence
>>>>>>>>>> I can run on 1 processor. Tried using valgrind but perhaps I'm using the
>>>>>>>>>> optimized version, it didn't catch the error, besides saying "Segmentation
>>>>>>>>>> fault (core dumped)"
>>>>>>>>>> However, by re-writing my code, I found out a few things:
>>>>>>>>>> 1. if I write my code this way:
>>>>>>>>>> u_array = ....
>>>>>>>>>> v_array = ....
>>>>>>>>>> w_array = ....
>>>>>>>>>> The code runs fine.
>>>>>>>>>> 2. if I write my code this way:
>>>>>>>>>> call uvw_array_change(u_array,v_array,w_array) -> this subroutine
>>>>>>>>>> does the same modification as the above.
>>>>>>>>>> call DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr) -> error
>>>>>>>>>> where the subroutine is:
>>>>>>>>>> subroutine uvw_array_change(u,v,w)
>>>>>>>>>> u ...
>>>>>>>>>> v...
>>>>>>>>>> w ...
>>>>>>>>>> end subroutine uvw_array_change.
>>>>>>>>>> The above will give an error at :
>>>>>>>>>> 3. Same as above, except I change the order of the last 3 lines
>>>>>>>>>> to:
>>>>>>>>>> So they are now in reversed order. Now it works.
>>>>>>>>>> 4. Same as 2 or 3, except the subroutine is changed to :
>>>>>>>>>> u(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>>>>>>>> v(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>>>>>>>> w(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>>>>>>>> u ...
>>>>>>>>>> v...
>>>>>>>>>> w ...
>>>>>>>>>> The start_indices and end_indices are simply to shift the 0
>>>>>>>>>> indices of C convention to that of the 1 indices of the Fortran convention.
>>>>>>>>>> This is necessary in my case because most of my codes start array counting
>>>>>>>>>> at 1, hence the "trick".
>>>>>>>>>> However, now no matter which order of the DMDAVecRestoreArrayF90
>>>>>>>>>> (as in 2 or 3), error will occur at "call
>>>>>>>>>> DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr) "
>>>>>>>>>> So did I violate and cause memory corruption due to the trick
>>>>>>>>>> above? But I can't think of any way other than the "trick" to continue
>>>>>>>>>> using the 1 indices convention.
>>>>>>>>>> Thank you.
>>>>>>>>>> Yours sincerely,
>>>>>>>>>> TAY wee-beng
>>>>>>>>>> On 15/4/2014 8:00 PM, Barry Smith wrote:
>>>>>>>>>>>    Try running under valgrind
>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>>> On Apr 14, 2014, at 9:47 PM, TAY wee-beng <zonexo at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>  Hi Barry,
>>>>>>>>>>>> As I mentioned earlier, the code works fine in PETSc debug mode
>>>>>>>>>>>> but fails in non-debug mode.
>>>>>>>>>>>> I have attached my code.
>>>>>>>>>>>> Thank you
>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>> TAY wee-beng
>>>>>>>>>>>> On 15/4/2014 2:26 AM, Barry Smith wrote:
>>>>>>>>>>>>>    Please send the code that creates da_w and the declarations
>>>>>>>>>>>>> of w_array
>>>>>>>>>>>>>    Barry
>>>>>>>>>>>>> On Apr 14, 2014, at 9:40 AM, TAY wee-beng
>>>>>>>>>>>>>   wrote:
>>>>>>>>>>>>>  Hi Barry,
>>>>>>>>>>>>>> I'm not too sure how to do it. I'm running mpi. So I run:
>>>>>>>>>>>>>>   mpirun -n 4 ./a.out -start_in_debugger
>>>>>>>>>>>>>> I got the msg below. Before the gdb windows appear (thru
>>>>>>>>>>>>>> x11), the program aborts.
>>>>>>>>>>>>>> Also I tried running in another cluster and it worked. Also
>>>>>>>>>>>>>> tried in the current cluster in debug mode and it worked too.
>>>>>>>>>>>>>> An MPI process has executed an operation involving a call to
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> "fork()" system call to create a child process.  Open MPI is
>>>>>>>>>>>>>> currently
>>>>>>>>>>>>>> operating in a condition that could result in memory
>>>>>>>>>>>>>> corruption or
>>>>>>>>>>>>>> other system errors; your MPI job may hang, crash, or produce
>>>>>>>>>>>>>> silent
>>>>>>>>>>>>>> data corruption.  The use of fork() (or system() or other
>>>>>>>>>>>>>> calls that
>>>>>>>>>>>>>> create child processes) is strongly discouraged.
>>>>>>>>>>>>>> The process that invoked fork was:
>>>>>>>>>>>>>>    Local host:          n12-76 (PID 20235)
>>>>>>>>>>>>>>    MPI_COMM_WORLD rank: 2
>>>>>>>>>>>>>> If you are *absolutely sure* that your application will
>>>>>>>>>>>>>> successfully
>>>>>>>>>>>>>> and correctly survive a call to fork(), you may disable this
>>>>>>>>>>>>>> warning
>>>>>>>>>>>>>> by setting the mpi_warn_on_fork MCA parameter to 0.
>>>>>>>>>>>>>> [2]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20235
>>>>>>>>>>>>>> on display localhost:50.0 on machine n12-76
>>>>>>>>>>>>>> [0]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20233
>>>>>>>>>>>>>> [1]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20234
>>>>>>>>>>>>>> [3]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20236
>>>>>>>>>>>>>> [n12-76:20232] 3 more processes have sent help message
>>>>>>>>>>>>>> help-mpi-runtime.txt / mpi_init:warn-fork
>>>>>>>>>>>>>> [n12-76:20232] Set MCA parameter "orte_base_help_aggregate"
>>>>>>>>>>>>>> to 0 to see all help / error messages
>>>>>>>>>>>>>>   1
>>>>>>>>>>>>>> [1]PETSC ERROR:
>>>>>>>>>>>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>>> [1]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>>>> [1]PETSC ERROR: or see
>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSCERROR: or try
>>>>>>>>>>>>>> http://valgrind.org
>>>>>>>>>>>>>>   on GNU/linux and Apple Mac OS X to find memory corruption
>>>>>>>>>>>>>> errors
>>>>>>>>>>>>>> [1]PETSC ERROR: configure using --with-debugging=yes,
>>>>>>>>>>>>>> recompile, link, and run
>>>>>>>>>>>>>> [1]PETSC ERROR: to get more information on the crash.
>>>>>>>>>>>>>> [1]PETSC ERROR: User provided function() line 0 in unknown
>>>>>>>>>>>>>> directory unknown file (null)
>>>>>>>>>>>>>> [3]PETSC ERROR:
>>>>>>>>>>>>>> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>>>> [3]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>>> [3]PETSC ERROR: or see
>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[3]PETSCERROR: or try
>>>>>>>>>>>>>> http://valgrind.org
>>>>>>>>>>>>>> errors
>>>>>>>>>>>>>> [3]PETSC ERROR: configure using --with-debugging=yes,
>>>>>>>>>>>>>> [3]PETSC ERROR: to get more information on the crash.
>>>>>>>>>>>>>> [3]PETSC ERROR: User provided function() line 0 in unknown
>>>>>>>>>>>>>> Thank you.
>>>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>>>> TAY wee-beng
>>>>>>>>>>>>>> On 14/4/2014 9:05 PM, Barry Smith wrote:
>>>>>>>>>>>>>>     Because IO doesn’t always get flushed immediately it may
>>>>>>>>>>>>>>> not be hanging at this point.  It is better to use the option
>>>>>>>>>>>>>>> -start_in_debugger then type cont in each debugger window and then when you
>>>>>>>>>>>>>>> think it is “hanging” do a control C in each debugger window and type where
>>>>>>>>>>>>>>> to see where each process is you can also look around in the debugger at
>>>>>>>>>>>>>>> variables to see why it is “hanging” at that point.
>>>>>>>>>>>>>>>     Barry
>>>>>>>>>>>>>>>    This routines don’t have any parallel communication in
>>>>>>>>>>>>>>> them so are unlikely to hang.
>>>>>>>>>>>>>>> On Apr 14, 2014, at 6:52 AM, TAY wee-beng
>>>>>>>>>>>>>>>   wrote:
>>>>>>>>>>>>>>>  Hi,
>>>>>>>>>>>>>>>> My code hangs and I added in mpi_barrier and print to catch
>>>>>>>>>>>>>>>> the bug. I found that it hangs after printing "7". Is it because I'm doing
>>>>>>>>>>>>>>>> something wrong? I need to access the u,v,w array so I use
>>>>>>>>>>>>>>>> DMDAVecGetArrayF90. After access, I use DMDAVecRestoreArrayF90.
>>>>>>>>>>>>>>>>          call MPI_Barrier(MPI_COMM_WORLD,ierr);  if
>>>>>>>>>>>>>>>> (myid==0) print *,"3"
>>>>>>>>>>>>>>>> (myid==0) print *,"4"
>>>>>>>>>>>>>>>> (myid==0) print *,"5"
>>>>>>>>>>>>>>>>          call
>>>>>>>>>>>>>>>> I_IIB_uv_initial_1st_dm(I_cell_no_u1,I_cell_no_v1,I_cell_no_w1,I_cell_u1,I_cell_v1,I_cell_w1,u_array,v_array,w_array)
>>>>>>>>>>>>>>>> (myid==0) print *,"6"
>>>>>>>>>>>>>>>>          call
>>>>>>>>>>>>>>>> DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)  !must be in reverse order
>>>>>>>>>>>>>>>> (myid==0) print *,"7"
>>>>>>>>>>>>>>>>          call
>>>>>>>>>>>>>>>> (myid==0) print *,"8"
>>>>>>>>>>>>>>>>          call
>>>>>>>>>>>>>>>> Thank you.
>>>>>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>>>>>> TAY wee-beng
>>>>>>>>>>>>>>>>   <code.txt>
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140419/9ae1bb2a/attachment-0001.html>
