[petsc-users] Problem with DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
Sat Apr 19 10:39:46 CDT 2014
On Sat, Apr 19, 2014 at 10:16 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  On 19/4/2014 10:55 PM, Matthew Knepley wrote:
>  On Sat, Apr 19, 2014 at 9:14 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>  On 19/4/2014 6:48 PM, Matthew Knepley wrote:
>>  On Sat, Apr 19, 2014 at 4:59 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>  On 19/4/2014 1:17 PM, Barry Smith wrote:
>>>> On Apr 19, 2014, at 12:11 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>  On 19/4/2014 12:10 PM, Barry Smith wrote:
>>>>>> On Apr 18, 2014, at 9:57 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>>>  On 19/4/2014 3:53 AM, Barry Smith wrote:
>>>>>>>>    Hmm,
>>>>>>>>        Interface DMDAVecGetArrayF90
>>>>>>>>          Subroutine DMDAVecGetArrayF903(da1, v,d1,ierr)
>>>>>>>>            USE_DM_HIDE
>>>>>>>>            DM_HIDE da1
>>>>>>>>            VEC_HIDE v
>>>>>>>>            PetscScalar,pointer :: d1(:,:,:)
>>>>>>>>            PetscErrorCode ierr
>>>>>>>>          End Subroutine
>>>>>>>>     So the d1 is a F90 POINTER. But your subroutine seems to be
>>>>>>>> treating it as a “plain old Fortran array”?
>>>>>>>> real(8), intent(inout) :: u(:,:,:),v(:,:,:),w(:,:,:)
>>>>>>>  Hi,
>>>>> So d1 is a pointer, and it's different if I declare it as "plain old
>>>>> Fortran array"? Because I declare it as a Fortran array and it works w/o
>>>>> any problem if I only call DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
>>>>> with "u".
>>>>> But if I call DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90 with "u",
>>>>> "v" and "w", error starts to happen. I wonder why...
>>>>> Also, supposed I call:
>>>>> call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>>>>>     call DMDAVecGetArrayF90(da_v,v_local,v_array,ierr)
>>>>>     call DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)
>>>>> u_array ....
>>>>> v_array .... etc
>>>>> Now to restore the array, does it matter the sequence they are
>>>>> restored?
>>>>     No it should not matter. If it matters that is a sign that memory
>>>> has been written to incorrectly earlier in the code.
>>>>   Hi,
>>> Hmm, I have been getting different results on different intel compilers.
>>> I'm not sure if MPI played a part but I'm only using a single processor. In
>>> the debug mode, things run without problem. In optimized mode, in some
>>> cases, the code aborts even doing simple initialization:
>>>      call DMDAVecGetArrayF90(da_p,p_local,p_array,ierr)
>>>     u_array = 0.d0
>>>     v_array = 0.d0
>>>     w_array = 0.d0
>>>     p_array = 0.d0
>>>     call DMDAVecRestoreArrayF90(da_p,p_local,p_array,ierr)
>>>     call DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)
>>>     call DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr)
>>>     call DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr)
>>>  The code aborts at call
>>> DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr), giving segmentation
>>> error. But other version of intel compiler passes thru this part w/o error.
>>> Since the response is different among different compilers, is this PETSc or
>>> intel 's bug? Or mvapich or openmpi?
>>  We do this is a bunch of examples. Can you reproduce this different
>> behavior in src/dm/examples/tutorials/ex11f90.F?
>> Hi Matt,
>> Do you mean putting the above lines into ex11f90.F and test?
>  It already has DMDAVecGetArray(). Just run it.
> Hi,
> It worked. The differences between mine and the code is the way the
> fortran modules are defined, and the ex11f90 only uses global vectors. Does
> it make a difference whether global or local vectors are used? Because the
> way it accesses x1 only touches the local region.
No the global/local difference should not matter.
> Also, before using DMDAVecGetArrayF90, DMGetGlobalVector must be used 1st,
> is that so? I can't find the equivalent for local vector though.
DMGetLocalVector()
   Matt
> Thanks.
>     Matt
>>  Thanks
>> Regards.
>>     Matt
>>>   As in w, then v and u?
>>>>> thanks
>>>>>>      Note also that the beginning and end indices of the u,v,w, are
>>>>>>>> different for each process see for example
>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-3.4/src/dm/examples/tutorials/ex11f90.F (and they do not start at 1). This is how to get the loop bounds.
>>>>>>> Hi,
>>>>>>> In my case, I fixed the u,v,w such that their indices are the same.
>>>>>>> I also checked using DMDAGetCorners and DMDAGetGhostCorners. Now the
>>>>>>> problem lies in my subroutine treating it as a “plain old Fortran array”.
>>>>>>> If I declare them as pointers, their indices follow the C 0 start
>>>>>>> convention, is that so?
>>>>>>     Not really. It is that in each process you need to access them
>>>>>> from the indices indicated by DMDAGetCorners() for global vectors and
>>>>>> DMDAGetGhostCorners() for local vectors.  So really C or Fortran doesn’t
>>>>>> make any difference.
>>>>>>  So my problem now is that in my old MPI code, the u(i,j,k) follow
>>>>>>> the Fortran 1 start convention. Is there some way to manipulate such that I
>>>>>>> do not have to change my u(i,j,k) to u(i-1,j-1,k-1)?
>>>>>>    If you code wishes to access them with indices plus one from the
>>>>>> values returned by DMDAGetCorners() for global vectors and
>>>>>> DMDAGetGhostCorners() for local vectors then you need to manually subtract
>>>>>> off the 1.
>>>>>>    Barry
>>>>>>  Thanks.
>>>>>>>>    Barry
>>>>>>>> On Apr 18, 2014, at 10:58 AM, TAY wee-beng <zonexo at gmail.com>
>>>>>>>> wrote:
>>>>>>>>  Hi,
>>>>>>>>> I tried to pinpoint the problem. I reduced my job size and hence I
>>>>>>>>> can run on 1 processor. Tried using valgrind but perhaps I'm using the
>>>>>>>>> optimized version, it didn't catch the error, besides saying "Segmentation
>>>>>>>>> fault (core dumped)"
>>>>>>>>> However, by re-writing my code, I found out a few things:
>>>>>>>>> 1. if I write my code this way:
>>>>>>>>> u_array = ....
>>>>>>>>> v_array = ....
>>>>>>>>> w_array = ....
>>>>>>>>> The code runs fine.
>>>>>>>>> 2. if I write my code this way:
>>>>>>>>> call uvw_array_change(u_array,v_array,w_array) -> this subroutine
>>>>>>>>> does the same modification as the above.
>>>>>>>>> call DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr) -> error
>>>>>>>>> where the subroutine is:
>>>>>>>>> subroutine uvw_array_change(u,v,w)
>>>>>>>>> u ...
>>>>>>>>> v...
>>>>>>>>> w ...
>>>>>>>>> end subroutine uvw_array_change.
>>>>>>>>> The above will give an error at :
>>>>>>>>> 3. Same as above, except I change the order of the last 3 lines to:
>>>>>>>>> So they are now in reversed order. Now it works.
>>>>>>>>> 4. Same as 2 or 3, except the subroutine is changed to :
>>>>>>>>> u(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>>>>>>> v(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>>>>>>> w(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>>>>>>>>> u ...
>>>>>>>>> v...
>>>>>>>>> w ...
>>>>>>>>> The start_indices and end_indices are simply to shift the 0
>>>>>>>>> indices of C convention to that of the 1 indices of the Fortran convention.
>>>>>>>>> This is necessary in my case because most of my codes start array counting
>>>>>>>>> at 1, hence the "trick".
>>>>>>>>> However, now no matter which order of the DMDAVecRestoreArrayF90
>>>>>>>>> (as in 2 or 3), error will occur at "call
>>>>>>>>> DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr) "
>>>>>>>>> So did I violate and cause memory corruption due to the trick
>>>>>>>>> above? But I can't think of any way other than the "trick" to continue
>>>>>>>>> using the 1 indices convention.
>>>>>>>>> Thank you.
>>>>>>>>> Yours sincerely,
>>>>>>>>> TAY wee-beng
>>>>>>>>> On 15/4/2014 8:00 PM, Barry Smith wrote:
>>>>>>>>>>    Try running under valgrind
>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>> On Apr 14, 2014, at 9:47 PM, TAY wee-beng <zonexo at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>  Hi Barry,
>>>>>>>>>>> As I mentioned earlier, the code works fine in PETSc debug mode
>>>>>>>>>>> but fails in non-debug mode.
>>>>>>>>>>> I have attached my code.
>>>>>>>>>>> Thank you
>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>> TAY wee-beng
>>>>>>>>>>> On 15/4/2014 2:26 AM, Barry Smith wrote:
>>>>>>>>>>>>    Please send the code that creates da_w and the declarations
>>>>>>>>>>>> of w_array
>>>>>>>>>>>>    Barry
>>>>>>>>>>>> On Apr 14, 2014, at 9:40 AM, TAY wee-beng
>>>>>>>>>>>>   wrote:
>>>>>>>>>>>>  Hi Barry,
>>>>>>>>>>>>> I'm not too sure how to do it. I'm running mpi. So I run:
>>>>>>>>>>>>>   mpirun -n 4 ./a.out -start_in_debugger
>>>>>>>>>>>>> I got the msg below. Before the gdb windows appear (thru x11),
>>>>>>>>>>>>> the program aborts.
>>>>>>>>>>>>> Also I tried running in another cluster and it worked. Also
>>>>>>>>>>>>> tried in the current cluster in debug mode and it worked too.
>>>>>>>>>>>>> An MPI process has executed an operation involving a call to
>>>>>>>>>>>>> the
>>>>>>>>>>>>> "fork()" system call to create a child process.  Open MPI is
>>>>>>>>>>>>> currently
>>>>>>>>>>>>> operating in a condition that could result in memory
>>>>>>>>>>>>> corruption or
>>>>>>>>>>>>> other system errors; your MPI job may hang, crash, or produce
>>>>>>>>>>>>> silent
>>>>>>>>>>>>> data corruption.  The use of fork() (or system() or other
>>>>>>>>>>>>> calls that
>>>>>>>>>>>>> create child processes) is strongly discouraged.
>>>>>>>>>>>>> The process that invoked fork was:
>>>>>>>>>>>>>    Local host:          n12-76 (PID 20235)
>>>>>>>>>>>>>    MPI_COMM_WORLD rank: 2
>>>>>>>>>>>>> If you are *absolutely sure* that your application will
>>>>>>>>>>>>> successfully
>>>>>>>>>>>>> and correctly survive a call to fork(), you may disable this
>>>>>>>>>>>>> warning
>>>>>>>>>>>>> by setting the mpi_warn_on_fork MCA parameter to 0.
>>>>>>>>>>>>> [2]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20235
>>>>>>>>>>>>> on display localhost:50.0 on machine n12-76
>>>>>>>>>>>>> [0]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20233
>>>>>>>>>>>>> [1]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20234
>>>>>>>>>>>>> [3]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20236
>>>>>>>>>>>>> [n12-76:20232] 3 more processes have sent help message
>>>>>>>>>>>>> help-mpi-runtime.txt / mpi_init:warn-fork
>>>>>>>>>>>>> [n12-76:20232] Set MCA parameter "orte_base_help_aggregate" to
>>>>>>>>>>>>> 0 to see all help / error messages
>>>>>>>>>>>>>   1
>>>>>>>>>>>>> [1]PETSC ERROR:
>>>>>>>>>>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>> [1]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>>> [1]PETSC ERROR: or see
>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSCERROR: or try
>>>>>>>>>>>>> http://valgrind.org
>>>>>>>>>>>>>   on GNU/linux and Apple Mac OS X to find memory corruption
>>>>>>>>>>>>> errors
>>>>>>>>>>>>> [1]PETSC ERROR: configure using --with-debugging=yes,
>>>>>>>>>>>>> recompile, link, and run
>>>>>>>>>>>>> [1]PETSC ERROR: to get more information on the crash.
>>>>>>>>>>>>> [1]PETSC ERROR: User provided function() line 0 in unknown
>>>>>>>>>>>>> directory unknown file (null)
>>>>>>>>>>>>> [3]PETSC ERROR:
>>>>>>>>>>>>> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>>> [3]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>> [3]PETSC ERROR: or see
>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[3]PETSCERROR: or try
>>>>>>>>>>>>> http://valgrind.org
>>>>>>>>>>>>> errors
>>>>>>>>>>>>> [3]PETSC ERROR: configure using --with-debugging=yes,
>>>>>>>>>>>>> [3]PETSC ERROR: to get more information on the crash.
>>>>>>>>>>>>> [3]PETSC ERROR: User provided function() line 0 in unknown
>>>>>>>>>>>>> Thank you.
>>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>>> TAY wee-beng
>>>>>>>>>>>>> On 14/4/2014 9:05 PM, Barry Smith wrote:
>>>>>>>>>>>>>     Because IO doesn’t always get flushed immediately it may
>>>>>>>>>>>>>> not be hanging at this point.  It is better to use the option
>>>>>>>>>>>>>> -start_in_debugger then type cont in each debugger window and then when you
>>>>>>>>>>>>>> think it is “hanging” do a control C in each debugger window and type where
>>>>>>>>>>>>>> to see where each process is you can also look around in the debugger at
>>>>>>>>>>>>>> variables to see why it is “hanging” at that point.
>>>>>>>>>>>>>>     Barry
>>>>>>>>>>>>>>    This routines don’t have any parallel communication in
>>>>>>>>>>>>>> them so are unlikely to hang.
>>>>>>>>>>>>>> On Apr 14, 2014, at 6:52 AM, TAY wee-beng
>>>>>>>>>>>>>>   wrote:
>>>>>>>>>>>>>>  Hi,
>>>>>>>>>>>>>>> My code hangs and I added in mpi_barrier and print to catch
>>>>>>>>>>>>>>> the bug. I found that it hangs after printing "7". Is it because I'm doing
>>>>>>>>>>>>>>> something wrong? I need to access the u,v,w array so I use
>>>>>>>>>>>>>>> DMDAVecGetArrayF90. After access, I use DMDAVecRestoreArrayF90.
>>>>>>>>>>>>>>>          call MPI_Barrier(MPI_COMM_WORLD,ierr);  if
>>>>>>>>>>>>>>> (myid==0) print *,"3"
>>>>>>>>>>>>>>> (myid==0) print *,"4"
>>>>>>>>>>>>>>> (myid==0) print *,"5"
>>>>>>>>>>>>>>>          call
>>>>>>>>>>>>>>> I_IIB_uv_initial_1st_dm(I_cell_no_u1,I_cell_no_v1,I_cell_no_w1,I_cell_u1,I_cell_v1,I_cell_w1,u_array,v_array,w_array)
>>>>>>>>>>>>>>> (myid==0) print *,"6"
>>>>>>>>>>>>>>>          call
>>>>>>>>>>>>>>> DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)  !must be in reverse order
>>>>>>>>>>>>>>> (myid==0) print *,"7"
>>>>>>>>>>>>>>>          call
>>>>>>>>>>>>>>> (myid==0) print *,"8"
>>>>>>>>>>>>>>>          call
>>>>>>>>>>>>>>> Thank you.
>>>>>>>>>>>>>>> Yours sincerely,
>>>>>>>>>>>>>>> TAY wee-beng
>>>>>>>>>>>>>>>   <code.txt>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140419/041b1d3f/attachment-0001.html>
