[petsc-users] Intel Internal compiler error: segmentation violation signal raised
TAY wee-beng zonexo at gmail.com
Tue Apr 8 06:26:46 CDT 2014
On 8/4/2014 7:58 AM, Matthew Knepley wrote:
> On Mon, Apr 7, 2014 at 6:46 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     On 8/4/2014 12:40 AM, Matthew Knepley wrote:
>>     How about just including petsc.h90 so you get everything.
>>       Thanks,
>>          Matt
>     Sorry this is my 2nd email. See below for the 1st email. Using
>     petsc.h90 gave the error "... segmentation violation signal raised
> Right, the solution there is not to use a buggy compiler. I suggest
> gcc. It is also faster for a lot of code than Intel.
My impression was intel is mostly faster. However, does it apply to
gfortran too? Is it also faster for a lot of code than Intel fortran?
I'll give it a go if it's so. However, I remember changing a no. of
options to build and in the end, it was slower. that's a few yrs ago though.
>    Matt
>>     On Mon, Apr 7, 2014 at 5:19 AM, TAY wee-beng <zonexo at gmail.com
>>         Sorry I realised that
>>         *#include "finclude/petscdmda.h90"*
>>         *#include "finclude/petscksp.h90"*
>>         also gave errors:
>>         *//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
>>         error #5082: Syntax error, found ',' when expecting one of: (
>>         /**/          PetscInt, pointer :: array(:)/**/
>>         /**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
>>         error #5082: Syntax error, found END-OF-STATEMENT when
>>         expecting one of: ) ,/**/
>>         /**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(11):
>>         error #5082: Syntax error, found IDENTIFIER 'N' when
>>         expecting one of: ( % [ : . = =>/**/
>>         /**/          PetscInt  n/**/
>>         /**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(12):
>>         error #5082: Syntax error, found IDENTIFIER 'IERR' when
>>         /**/          PetscErrorCode ierr/**/
>>         /**//home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(13):
>>         error #5082: Syntax error, found IDENTIFIER 'V' when
>>         Thank you
>>         Yours sincerely,
>>         TAY wee-beng
>>         On 7/4/2014 6:16 PM, TAY wee-beng wrote:
>     Here's the 1st email:
>>>         Hi,
>>>         I encountered the error below when compiling my code using
>>>         intel fortran:
>>>         /tmp/ifortlPEDlK.i90: catastrophic error: **Internal
>>>         compiler error: segmentation violation signal raised**
>>>         Please report this error along with the circumstances in
>>>         which it occurred in a Software Problem Report.  Note: File
>>>         and line given may not be explicit cause of this error.
>>>         In the end, I realised that it is due to using *petsc.h90*:
>>>         module PETSc_solvers
>>>         use set_matrix
>>>         implicit none
>>>         contains
>>>         subroutine semi_momentum_simple_xyz(du,dv,dw)
>>>         *#include "finclude/petsc.h90"*
>>>         integer :: i,j,k,ijk,ierr,II !,ro...
>>>         If I use :
>>>         *#include "finclude/petsc.h"
>>>         or
>>>         Then there is no problem.
>>>         May I know why this is happening?
>>>         Although I can now compile and build successfully, is this
>>>         the right way to go?
>>>         Thank you
>>>         Yours sincerely,
>>>         TAY wee-beng
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140408/2d2879f6/attachment.html>
