[petsc-users] Intel Internal compiler error: segmentation violation signal raised
Tue Apr 8 06:32:14 CDT 2014
On Tue, Apr 8, 2014 at 6:26 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  On 8/4/2014 7:58 AM, Matthew Knepley wrote:
>  On Mon, Apr 7, 2014 at 6:46 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>  On 8/4/2014 12:40 AM, Matthew Knepley wrote:
>> How about just including petsc.h90 so you get everything.
>>    Thanks,
>>       Matt
>>  Sorry this is my 2nd email. See below for the 1st email. Using
>> petsc.h90 gave the error "... segmentation violation signal raised ....
>  Right, the solution there is not to use a buggy compiler. I suggest gcc.
> It is also faster for a lot of code than Intel.
> My impression was intel is mostly faster. However, does it apply to
> gfortran too? Is it also faster for a lot of code than Intel fortran? I'll
> give it a go if it's so. However, I remember changing a no. of options to
> build and in the end, it was slower. that's a few yrs ago though.
Anything is faster than a seg-faulting compiler. However, we have just run
a number of tests in which
gcc was faster.
   Matt
>      Matt
>>   On Mon, Apr 7, 2014 at 5:19 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>  Sorry I realised that
>>> *#include "finclude/petscdmda.h90"*
>>> *#include "finclude/petscksp.h90"*
>>> also gave errors:
>>> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
>>> error #5082: Syntax error, found ',' when expecting one of: ( % [ : . = =>*
>>> *          PetscInt, pointer :: array(:)*
>>> error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: )
>>> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(11):
>>> error #5082: Syntax error, found IDENTIFIER 'N' when expecting one of: ( %
>>> *          PetscInt  n*
>>> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(12):
>>> error #5082: Syntax error, found IDENTIFIER 'IERR' when expecting one of: (
>>> *          PetscErrorCode ierr*
>>> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(13):
>>> error #5082: Syntax error, found IDENTIFIER 'V' when expecting one of: ( %
>>> Thank you
>>> Yours sincerely,
>>> TAY wee-beng
>>>   On 7/4/2014 6:16 PM, TAY wee-beng wrote:
>> Here's the 1st email:
>>        Hi,
>>> I encountered the error below when compiling my code using intel fortran:
>>> /tmp/ifortlPEDlK.i90: catastrophic error: **Internal compiler error:
>>> segmentation violation signal raised** Please report this error along with
>>> the circumstances in which it occurred in a Software Problem Report.  Note:
>>> File and line given may not be explicit cause of this error.
>>> In the end, I realised that it is due to using *petsc.h90*:
>>> module PETSc_solvers
>>> use set_matrix
>>> implicit none
>>> contains
>>> subroutine semi_momentum_simple_xyz(du,dv,dw)
>>> *#include "finclude/petsc.h90"*
>>> integer :: i,j,k,ijk,ierr,II !,ro...
>>> If I use :
>>> *#include "finclude/petsc.h" or *
>>> Then there is no problem.
>>> May I know why this is happening?
>>> Although I can now compile and build successfully, is this the right way
>>> to go?
>>> Thank you
>>> Yours sincerely,
>>> TAY wee-beng
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140408/50d1be46/attachment-0001.html>
