[petsc-users] Intel Internal compiler error: segmentation violation signal raised
Mon Apr 7 20:08:15 CDT 2014
  Did you submit an Intel "Software Problem Report” as they requested? Perhaps they already have updates that fix the problem.
   Barry
On Apr 7, 2014, at 6:58 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Apr 7, 2014 at 6:46 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 8/4/2014 12:40 AM, Matthew Knepley wrote:
>> How about just including petsc.h90 so you get everything.
>>   Thanks,
>>      Matt
> Sorry this is my 2nd email. See below for the 1st email. Using petsc.h90 gave the error "... segmentation violation signal raised ....
> Right, the solution there is not to use a buggy compiler. I suggest gcc. It is also faster for a lot of code than Intel.
>    Matt
>> On Mon, Apr 7, 2014 at 5:19 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Sorry I realised that
>> #include "finclude/petscdmda.h90"
>> #include "finclude/petscksp.h90"
>> also gave errors:
>> /home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10): error #5082: Syntax error, found ',' when expecting one of: ( % [ : . = =>
>>           PetscInt, pointer :: array(:)
>> /home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ) ,
>> /home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(11): error #5082: Syntax error, found IDENTIFIER 'N' when expecting one of: ( % [ : . = =>
>>           PetscInt  n
>> /home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(12): error #5082: Syntax error, found IDENTIFIER 'IERR' when expecting one of: ( % [ : . = =>
>>           PetscErrorCode ierr
>> /home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(13): error #5082: Syntax error, found IDENTIFIER 'V' when expecting one of: ( % [ : . = =>
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
>> On 7/4/2014 6:16 PM, TAY wee-beng wrote:
> Here's the 1st email:
>>> Hi,
>>> I encountered the error below when compiling my code using intel fortran:
>>> /tmp/ifortlPEDlK.i90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
>>> In the end, I realised that it is due to using petsc.h90:
>>> module PETSc_solvers
>>> use set_matrix
>>> implicit none
>>> contains
>>> subroutine semi_momentum_simple_xyz(du,dv,dw)
>>> #include "finclude/petsc.h90"
>>> integer :: i,j,k,ijk,ierr,II !,ro...
>>> If I use :
>>> #include "finclude/petsc.h"
>>> or
>>> Then there is no problem.
>>> May I know why this is happening?
>>> Although I can now compile and build successfully, is this the right way to go?
>>> Thank you
>>> Yours sincerely,
>>> TAY wee-beng
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
> -- Norbert Wiener
