[petsc-users] Intel Internal compiler error: segmentation violation signal raised
Mon Apr 7 18:58:01 CDT 2014
On Mon, Apr 7, 2014 at 6:46 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>  On 8/4/2014 12:40 AM, Matthew Knepley wrote:
> How about just including petsc.h90 so you get everything.
>    Thanks,
>       Matt
>  Sorry this is my 2nd email. See below for the 1st email. Using petsc.h90
> gave the error "... segmentation violation signal raised ....
Right, the solution there is not to use a buggy compiler. I suggest gcc. It
is also faster for a lot of code than Intel.
   Matt
>  On Mon, Apr 7, 2014 at 5:19 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>  Sorry I realised that
>> *#include "finclude/petscdmda.h90"*
>> *#include "finclude/petscksp.h90"*
>> also gave errors:
>> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
>> error #5082: Syntax error, found ',' when expecting one of: ( % [ : . = =>*
>> *          PetscInt, pointer :: array(:)*
>> error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: )
>> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(11):
>> error #5082: Syntax error, found IDENTIFIER 'N' when expecting one of: ( %
>> *          PetscInt  n*
>> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(12):
>> error #5082: Syntax error, found IDENTIFIER 'IERR' when expecting one of: (
>> *          PetscErrorCode ierr*
>> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(13):
>> error #5082: Syntax error, found IDENTIFIER 'V' when expecting one of: ( %
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
>>   On 7/4/2014 6:16 PM, TAY wee-beng wrote:
> Here's the 1st email:
>        Hi,
>> I encountered the error below when compiling my code using intel fortran:
>> /tmp/ifortlPEDlK.i90: catastrophic error: **Internal compiler error:
>> segmentation violation signal raised** Please report this error along with
>> the circumstances in which it occurred in a Software Problem Report.  Note:
>> File and line given may not be explicit cause of this error.
>> In the end, I realised that it is due to using *petsc.h90*:
>> module PETSc_solvers
>> use set_matrix
>> implicit none
>> contains
>> subroutine semi_momentum_simple_xyz(du,dv,dw)
>> *#include "finclude/petsc.h90"*
>> integer :: i,j,k,ijk,ierr,II !,ro...
>> If I use :
>> *#include "finclude/petsc.h" or *
>> Then there is no problem.
>> May I know why this is happening?
>> Although I can now compile and build successfully, is this the right way
>> to go?
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140407/ab37a366/attachment-0001.html>
