[petsc-users] make all freezes
Analabha Roy hariseldon99 at gmail.com
Sun Sep 22 10:50:02 CDT 2013
Strangely enough, make all is now freezing in my desktop. Running "make
chk_upgrade" also hangs. Running "chk_makej" ok no problem.
This is the configure.log from my
desktop<https://dl.dropboxusercontent.com/u/2769707/configure.log.desktop>
Does "make chk_upgrade" run "${PETSC_DIR}/bin/petscnagupgrade.py" ?
 That's what ${PETSC_DIR}/conf/rules says, and this file is transcluded in
the root makefile
Running "petscnagupgrade.py" in the bin dir from shell also hangs with no
output.
I removed "chk_upgrade" from the root makefile and the compile worked!
I reinserted chk_upgrade and commented out the nag upgrade file in
conf/rules and "make all " worked. I commented out all instances of
"chk_upgrade" from /conf/rules and all compiles work.
Maybe a network problem???
On Wed, Sep 18, 2013 at 9:56 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 18 Sep 2013, Analabha Roy wrote:
> > On Sep 17, 2013 9:39 PM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> > > This doesn't make any sense..
> > > If the build is hanging - we'd like to know exactly where its hanging.
> > > [perhaps copy/paste]
> > It didn't dump any output, either to stdout or Stderr. There was nothing
> to
> > copy/paste.
> so you type in 'make all' and then see nothing on the screen?
> all: chk_makej
>         @${OMAKE}  PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR}
> chk_petscdir chk_upgrade | tee ${PETSC_ARCH}/conf/make.log
> The only thing I can think off is chk_upgrade perhaps misconfigured
> network is affecting it. [if the behavior is reproduceable - perhaps
> we can narrow it down by invoking these commands one at a time].
> > > If the run is hanging - we'd like to see the stack trace [via gdb] of
> the
> > > location of the hang.
> > > xorg-devel should'nt make a difference [from what we know]..
> > Doesn't it need xorg headers for rendering graphic output via petscdraw?
> > Maybe it was one of the dependencies of xorg devel that did the trick.
> If x11 includes/libs are not found - then petsc is configured without X11.
> > https://dl.dropboxusercontent.com/u/2769707/configure.log>(dropbox)
> The configure.log above confirms that it did not detect X11. [so none
> of the X11 stuff was enabled].
> Even if X11 was enabled - 'make test' does not run any X11 related tests.
> If some make target caused hang for both 'make all' and 'make test' -
> then running the examples manually might confirm this. [and then
> invoking the steps in 'make test' one at a time might narrow down to
> the location of the hang].
> Satish
*Analabha Roy*
C.S.I.R <http://www.csir.res.in>  Senior Research
Associate<http://csirhrdg.res.in/poolsra.htm>
Saha Institute of Nuclear Physics <http://www.saha.ac.in>
Section 1, Block AF
Bidhannagar, Calcutta 700064
India
*Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
*Webpage*: http://www.ph.utexas.edu/~daneel/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130922/51989111/attachment.html>
