[petsc-users] make all freezes
Sun Sep 22 12:06:26 CDT 2013
   Thanks for figuring this out.  Normally if there is no network available then the code below should just return quickly after trying to connect
    import urllib
    fd = urllib.urlopen("http://www.mcs.anl.gov/petsc/petsc-dev/include/petscversion.h")
    pv = fd.read()
    fd.close()
but for some reason it is hanging for you.  Could you try those lines in python and see if it hangs?
Then you could try
    import requests
    pv = requests.get("http://www.mcs.anl.gov/petsc/petsc-dev/include/petscversion.h")
 Does that hang?
   Barry
On Sep 22, 2013, at 10:50 AM, Analabha Roy <hariseldon99 at gmail.com> wrote:
> Strangely enough, make all is now freezing in my desktop. Running "make chk_upgrade" also hangs. Running "chk_makej" ok no problem.
> This is the configure.log from my desktop
> Does "make chk_upgrade" run "${PETSC_DIR}/bin/petscnagupgrade.py" ?
>  That's what ${PETSC_DIR}/conf/rules says, and this file is transcluded in the root makefile
> Running "petscnagupgrade.py" in the bin dir from shell also hangs with no output.
> I removed "chk_upgrade" from the root makefile and the compile worked!
> I reinserted chk_upgrade and commented out the nag upgrade file in conf/rules and "make all " worked. I commented out all instances of "chk_upgrade" from /conf/rules and all compiles work.
> Maybe a network problem???
> On Wed, Sep 18, 2013 at 9:56 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 18 Sep 2013, Analabha Roy wrote:
> > On Sep 17, 2013 9:39 PM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> > > This doesn't make any sense..
> > > If the build is hanging - we'd like to know exactly where its hanging.
> > > [perhaps copy/paste]
> > It didn't dump any output, either to stdout or Stderr. There was nothing to
> > copy/paste.
> so you type in 'make all' and then see nothing on the screen?
> all: chk_makej
>         @${OMAKE}  PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} chk_petscdir chk_upgrade | tee ${PETSC_ARCH}/conf/make.log
> The only thing I can think off is chk_upgrade perhaps misconfigured
> network is affecting it. [if the behavior is reproduceable - perhaps
> we can narrow it down by invoking these commands one at a time].
> > > If the run is hanging - we'd like to see the stack trace [via gdb] of the
> > > location of the hang.
> > > xorg-devel should'nt make a difference [from what we know]..
> > Doesn't it need xorg headers for rendering graphic output via petscdraw?
> > Maybe it was one of the dependencies of xorg devel that did the trick.
> If x11 includes/libs are not found - then petsc is configured without X11.
> > https://dl.dropboxusercontent.com/u/2769707/configure.log>(dropbox)
> The configure.log above confirms that it did not detect X11. [so none
> of the X11 stuff was enabled].
> Even if X11 was enabled - 'make test' does not run any X11 related tests.
> If some make target caused hang for both 'make all' and 'make test' -
> then running the examples manually might confirm this. [and then
> invoking the steps in 'make test' one at a time might narrow down to
> the location of the hang].
> Satish
> Analabha Roy
> C.S.I.R  Senior Research Associate
> Saha Institute of Nuclear Physics
> Section 1, Block AF
> Bidhannagar, Calcutta 700064
> India
> Emails: daneel at physics.utexas.edu, hariseldon99 at gmail.com
> Webpage: http://www.ph.utexas.edu/~daneel/
