[petsc-users] PETSc-dev and OpenMP
Danyang Su danyang.su at gmail.com
Fri Sep 20 17:01:07 CDT 2013
Hi Barry,
Thanks for following up. I just want some PETSc OpenMP example or user
guide. Looking forward to your work on superlu_mt.
Danyang
On 20/09/2013 6:17 AM, Barry Smith wrote:
>     Sorry I did not respond sooner. I've been trying to interface PETSc to superlu_mt for a couple of days but haven't completed it yet. I'll let you know if I get it working.
>     Barry
> On Sep 17, 2013, at 2:31 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi Barry,
>> Thanks so much.
>> Which solvers are current OpenMP parallel currently? Can I use the external package (e.g., SuperLU OpenMP version) with OpenMP through PETSc?
>> Is there any document or examples available for the usage of PETSc with OpenMP?
>> Thanks again,
>> Danyang
>> On 17/09/2013 11:21 AM, Barry Smith wrote:
>>>     You can utilize the "OpenMP version of PETSc" with your OpenMP program but not all the solvers are OpenMP parallel currently.
>>>     Use petsc-dev and configure PETSc with ./configure --with-mpi=0 --with-openmp   see http://www.mcs.anl.gov/petsc/developers/index.html
>>>     Barry
>>> On Sep 17, 2013, at 12:29 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>>> Hi All,
>>>> I have a parallel Fortran project utilizing OpenMP parallelism. Before porting to PETSc utilizing MPICH, I want to know if it is possible to use PETSc solver with OpenMP. There is some information for petsc-dev openmp benchmarking as can be found here, http://lists.mcs.anl.gov/pipermail/petsc-dev/2012-March/007817.html. If this is possible, I would like to have a OpenMP version of PETSc solver first, otherwise, the project will be ported to PETSc utilizing MPI. Could anybody give me some advice on this?
>>>> Thanks and regards,
>>>> Danyang
