[petsc-users] PETSc-dev and OpenMP
Fri Sep 20 08:17:19 CDT 2013
   Sorry I did not respond sooner. I've been trying to interface PETSc to superlu_mt for a couple of days but haven't completed it yet. I'll let you know if I get it working.
   Barry
On Sep 17, 2013, at 2:31 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi Barry,
> Thanks so much.
> Which solvers are current OpenMP parallel currently? Can I use the external package (e.g., SuperLU OpenMP version) with OpenMP through PETSc?
> Is there any document or examples available for the usage of PETSc with OpenMP?
> Thanks again,
> Danyang
> On 17/09/2013 11:21 AM, Barry Smith wrote:
>>    You can utilize the "OpenMP version of PETSc" with your OpenMP program but not all the solvers are OpenMP parallel currently.
>>    Use petsc-dev and configure PETSc with ./configure --with-mpi=0 --with-openmp   see http://www.mcs.anl.gov/petsc/developers/index.html
>>    Barry
>> On Sep 17, 2013, at 12:29 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>> Hi All,
>>> I have a parallel Fortran project utilizing OpenMP parallelism. Before porting to PETSc utilizing MPICH, I want to know if it is possible to use PETSc solver with OpenMP. There is some information for petsc-dev openmp benchmarking as can be found here, http://lists.mcs.anl.gov/pipermail/petsc-dev/2012-March/007817.html. If this is possible, I would like to have a OpenMP version of PETSc solver first, otherwise, the project will be ported to PETSc utilizing MPI. Could anybody give me some advice on this?
>>> Thanks and regards,
>>> Danyang
