[petsc-users] PETSc-dev and OpenMP
Danyang Su danyang.su at gmail.com
Tue Sep 17 14:31:29 CDT 2013
Hi Barry,
Thanks so much.
Which solvers are current OpenMP parallel currently? Can I use the
external package (e.g., SuperLU OpenMP version) with OpenMP through PETSc?
Is there any document or examples available for the usage of PETSc with
OpenMP?
Thanks again,
Danyang
On 17/09/2013 11:21 AM, Barry Smith wrote:
>     You can utilize the "OpenMP version of PETSc" with your OpenMP program but not all the solvers are OpenMP parallel currently.
>     Use petsc-dev and configure PETSc with ./configure --with-mpi=0 --with-openmp   see http://www.mcs.anl.gov/petsc/developers/index.html
>     Barry
> On Sep 17, 2013, at 12:29 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi All,
>> I have a parallel Fortran project utilizing OpenMP parallelism. Before porting to PETSc utilizing MPICH, I want to know if it is possible to use PETSc solver with OpenMP. There is some information for petsc-dev openmp benchmarking as can be found here, http://lists.mcs.anl.gov/pipermail/petsc-dev/2012-March/007817.html. If this is possible, I would like to have a OpenMP version of PETSc solver first, otherwise, the project will be ported to PETSc utilizing MPI. Could anybody give me some advice on this?
>> Thanks and regards,
>> Danyang
